Old 07-29-2013, 10:17 AM   #15
topazsparrow
Drives: slow
Every-time the clutch rattle thread comes up everyone says "It's normal don't worry about it". The thing is, nobody every provides a reason WHY its considered normal. Nobody has provided a solution for it yet either.
topazsparrow is offline   Reply With Quote
Old 07-29-2013, 10:23 AM   #16
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Because they are mechanical parts with free play. Example, you can crawl under your car while it's stopped and rotate the driveshaft back and forth a bit, that's the free play, and that is only ONE of the reason the whole drivetrain is noisy, that and because this car has very little sound deadening. The drivetrain is under constant load and unload when you drive. The clutch has springs that are also under constant load and unload, that can also make noise.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
lantsalot (07-29-2013)
Old 07-29-2013, 01:05 PM   #17
topazsparrow
Drives: slow
Whats different about the FRS and BRZ when compared to all the other MT cars on the road that don't do this?
You mention the sound deadening but surely that would do little to hide the flywheel / clutch rattle these cars have.
And don't get me wrong. I'm not suggesting its defective or broken, I'm just saying it's odd. It's unusual for even the cheapest of new cars to make noises like this.
Old 07-29-2013, 01:19 PM   #18
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by pascalbrax View Post
Care to explain to a newbie like me what "this type of clutch" means?
I'm a newbie too when it comes to mechanical stuff. I'm just typing this from my memory. 1st to 3rd gears of this car have triple cone synchros. Better to have you Google it to find out what it is than I try to explain it. But this the cause of "jar of marbles" noise and it is normal.
Old 07-29-2013, 02:10 PM   #19
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
They all do this (standard transmission cars). Most cars on the roads are automatic transmission and are usually less noisy.
FWD also make less noise because they are drive-shaft less.
Old 07-29-2013, 02:50 PM   #20
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
This "rattle" noise is happening on mine as well every so often when I shift into Neutral. As it being normal on a RWD MT car I cant say as my previous 2 RWD MT cars didn't do that at all.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
Rayme (07-29-2013)
Old 07-29-2013, 03:05 PM   #21
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Yea but the MR2 is just a FWD drivetrain in the wrong side.
My 350Z made all the noise the FR-S did. The worst is on multiple speed bumps with lot's of clutch in and out.
Anybody familiar with clutch noise on some Ducatis?? Premium bikes with noisy drivetrain? It's just the way things are.
The Following 2 Users Say Thank You to Rayme For This Useful Post:
#maverick# (07-30-2014), lantsalot (07-29-2013)
Old 07-29-2013, 03:20 PM   #22
Shneegle
Shneegle's Avatar
I didn't mention a MR2. The car before this was a 240sx with an SR20DET swap. That car while being 20+ years old would rattle but did not have the same rattle from the drivetrain.
Old 07-29-2013, 03:20 PM   #23
topazsparrow
Drives: slow
My FRS is the 13'th car I've owned. The majority of which were standard transmissions. They all varied in age and condition. 4 of them were RWD.
I'm not unfamiliar with cars in the least.
None of them have made noises like this unless they where in need of repair. Your answer is a prime example of what I was saying. Lots of people pipe up and say "don't worry about it, it's normal" and I'm not arguing that. It's just that nobody can give me a specific reason (that isn't their own pure SPECULATION) as to what is causing the rattle and so far nobody has even given speculation as to what might remedy it.
Frankly I'm not concerned. I just think people should avoid saying "Don't worry about it, I heard it's normal" when they don't even really know the actual cause.
Old 07-29-2013, 03:27 PM   #24
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Well I explained it up there but hey, beleive what you want. Some vehicles are noisy from the factory, there isn't anything to "fix" them as per say.
Old 07-29-2013, 03:41 PM   #25
topazsparrow
Drives: slow
It'd be faster if you just said you're not sure what causes the rattle. If you knew, you would be able to identify the part or parts that could be re-worked / modified / replaced to eliminate the noise. It could be a tight clearance on a dust shield for all we know. I'd be interested to hear from the guys who have upgraded to a lightweight flywheel and aftermarket clutch.
This isn't a 15 year old jeep with a combination of parts that are a little sloppy that culminate in a problem you have a hard time diagnosing... this is a brand new car.
Old 07-29-2013, 04:07 PM   #26
Sigh-on-Rice
If you're talking about the noise that happens when you're in neutral, it might be the direct injection noise.
Old 07-29-2013, 04:14 PM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Sigh-on-Rice View Post
If yours is manual transmission, you're in 2nd gear at 10-15 mph (1250-1800 RPM), and step on the gas to accelerate, then yes, it will rattle. But it should happen regardless of your AC being on or off.
Originally Posted by ShowTime_DW View Post
I need to add something. The rattle happens when I am shift to Neutral .
MT, rattle after shift to neutral
Originally Posted by Mikem53 View Post
Normal.. Clutch chatter in these cars are normal at low rpm.. The drop in revs with the AC on will also make the engine vibrate and studder as the revs drop too low and then pick back up.
The last car I drove that had this .... "rattle", was a poorly tuned S15 SR20DET w/ 6-speed transmission swap into a 240SX.
Why was this important?
1) the poor tune resulted in the revs dropping too fast. The IACV (Idle Air Control Valve) was not keeping RPMs high enough and it dropped close to/below 600.
2) dual mass clutch/flywheel setup tend to make more noise, especially when the entire drivetrain is shaking abnormally (from a low idle)
My car makes this exact same noise. I know the low revs between shifts with the AC on is causing it... I'm just too lazy to take it to the dealer to have them fix the idle issue. If this is caused by RPMs too low after a shift into neutral, it's an ECU tune issue plain and simple.
And FWIW: my car's idle drops to "normal" about 10-15 seconds after an overnight cold startup.
-alex
Old 07-29-2013, 04:30 PM   #28
mav1178
mav1178's Avatar
In case you don't know what a dual mass flywheel is:
http://www.zf.com/brands/content/en/...dmf_SACHS.html
The root cause (if this is happening when shifting into neutral) is either a ECU tune (most likely), or a bad transmission/clutch design that is prone to noise when load input is changed suddenly (least likely).
-alex
Overpipe rattle? Kregar Engine, Exhaust, Transmission 36 09-06-2014 04:58 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
