Old 07-01-2013, 02:01 AM   #239
robispec
Drives: Black frs project
Ran a ten lap wheel 2 wheel today in 117 degree heat
No issues no deacrease in power. Fastest lap was next to last.
Robi
robispec is offline   Reply With Quote
Old 07-01-2013, 08:06 AM   #240
swift996
swift996's Avatar
Actually I wouldn't be surprised at the ECU pulling timing based on various parameters, including oil temp. That should be easy to find in the ECU for those who can look. Oil temps most likely aren't the only thing increasing so I agree with the others that it's difficult to make that direct correlation as the sole cause of timing being pulled, etc.
This wouldn't be the first car to pull timing based on coolant and oil temp sensors though, assuming that's all the car does is just pull timing. I haz no idea.
Either way I just prefer my oil to run cooler and pull heat out of the rest of the components in the engine.
I looked through my logs. I'm running unichip which might cause a discrepancy on the measured values or the behavior but my timing doesn't look to be pulled back at all through the session.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-09-2013, 10:41 AM   #241
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
UPDATE- Mocal laminar flow oil/water cooler system-- I installed the cooler and so far it seems to be working great. (More later)
FITTING- I spliced the unit into the cool water hose out of the radiator (on the driver's side) and used an oil sandwich plate to feed the oil down to the cooler. It was a VERY tight fit with the medium size Mocal cooler (7" plus the length of the water fittings), and what's left of the original hose now only serves to link the cooler to the engine and the radiator-- acting more like couplers than anything else. The fit overall is nearly perfect, but it took me a while to get it just right. The trick was to cut the hose to allow for a short 90-degree link to the engine and a very, very short piece of hose with a 45-degree angle out of the radiator. I ordered the cooler with 1.5" slip-on water fittings and AN10 oil line fittings.
TESTING- I had noticed oil temps over 230-degrees before installation when running the car hard. In addition, on a 80-degree day I had temps of 218 while on the interstate. While I have not been to an auto-x since install, I've tried to simulate one and did repeated hard pulls in first and second gear, several high RPM runs and the oil temp never went over 212f. For interstate driving on a 90-degree day the car didn't go over 208! Even better, the oil temp seems to come down much faster than before once you stopped running the car hard. Within one mile of driving after a hard pull it went from 212 to 204f.
I saved anywhere from $100 to $150 over the installation of most of the oil/air coolers designed for the car, still have plenty of room for an intercooler if I ever go FI, and may well have a superior setup for auto-x and DD as I don't have to worry about the oil never being too cool or too hot.
mtimney is offline   Reply With Quote
The Following 2 Users Say Thank You to mtimney For This Useful Post:
8686 (07-14-2013), amram (07-11-2013)
Old 07-09-2013, 10:57 AM   #242
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Pics of it installed would be great
The Following User Says Thank You to ATL BRZ For This Useful Post:
swift996 (07-10-2013)
Old 07-09-2013, 03:02 PM   #243
wootwoot
Drives: FRS
Yes please! I have been researching this for a long time.
What size cooler did you get, small or medium? And what size barbs for the coolant hose? What size oil cooler lines?
Old 07-10-2013, 08:46 PM   #244
mtimney
mtimney's Avatar
[QUOTE=What size cooler did you get, small or medium? And what size barbs for the coolant hose? What size oil cooler lines?[/QUOTE]
If you read my last post you'll see I answered all your questions there.
I'll try to get a photo up in the next couple days.
Old 07-16-2013, 03:42 PM   #245
wootwoot
Drives: FRS
Where are those pics at yo?
Old 07-24-2013, 04:06 PM   #246
mtimney
mtimney's Avatar
LAMINOVA OIL COOLER
Sorry for the delay...thought I'd have my header in by now and take pictures from under the car too. BUT..it's not here, so you'll have to settle for these shots. See info on what/how I did this in my earlier posts on this thread.
Old 07-26-2013, 01:19 PM   #247
mtimney
mtimney's Avatar
Any thoughts on how often (and then how long) I would want the oil to get above 212 to cook off any water contamination in the oil?
Old 07-26-2013, 09:00 PM   #248
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My cooler started leaking tonight.. the core itself. Need to look into it tomorrow. Fun times.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-27-2013, 01:05 AM   #249
wootwoot
Drives: FRS
Bump for a great question.
Old 07-27-2013, 03:06 AM   #250
ft_sjo
Drives: GT86
As much as possible!
Old 07-27-2013, 05:11 PM   #251
mtimney
mtimney's Avatar
I've been reading a lot about oil temperatures and the variations in oil temp throughout an engine. In some applications, the oil is 50-degrees hotter at the pistons than the reading at the sensor (usually a sensor in the bottom of the oil pan).
From what I've read, the location of the temp sensor on the BRZ next to the filter is reportedly a good one in that it gives you an idea of oil temp before it goes into the engine.
So, If I'm getting oil temps above 200-degrees by the filter, then it seem likely that the oil is getting hotter inside the major, working parts of the engine. Soooooo....I'm guessing that the oil does go above 212-degrees on a fairly regular basis, which means that water is probably being boiled off.
Any thoughts from someone with a mechanical or engineering background?
Old 07-28-2013, 02:57 AM   #252
ft_sjo
Drives: GT86
The evaporation mainly occurs in the crank case, and goes out through the breather system.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
