#239 |
Drives: Black frs project
Ran a ten lap wheel 2 wheel today in 117 degree heat
No issues no deacrease in power. Fastest lap was next to last. Robi |
#240 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#241 |
Drives: 2013 BRZ Limited
![]() UPDATE- Mocal laminar flow oil/water cooler system-- I installed the cooler and so far it seems to be working great. (More later) FITTING- I spliced the unit into the cool water hose out of the radiator (on the driver's side) and used an oil sandwich plate to feed the oil down to the cooler. It was a VERY tight fit with the medium size Mocal cooler (7" plus the length of the water fittings), and what's left of the original hose now only serves to link the cooler to the engine and the radiator-- acting more like couplers than anything else. The fit overall is nearly perfect, but it took me a while to get it just right. The trick was to cut the hose to allow for a short 90-degree link to the engine and a very, very short piece of hose with a 45-degree angle out of the radiator. I ordered the cooler with 1.5" slip-on water fittings and AN10 oil line fittings. TESTING- I had noticed oil temps over 230-degrees before installation when running the car hard. In addition, on a 80-degree day I had temps of 218 while on the interstate. While I have not been to an auto-x since install, I've tried to simulate one and did repeated hard pulls in first and second gear, several high RPM runs and the oil temp never went over 212f. For interstate driving on a 90-degree day the car didn't go over 208! Even better, the oil temp seems to come down much faster than before once you stopped running the car hard. Within one mile of driving after a hard pull it went from 212 to 204f. I saved anywhere from $100 to $150 over the installation of most of the oil/air coolers designed for the car, still have plenty of room for an intercooler if I ever go FI, and may well have a superior setup for auto-x and DD as I don't have to worry about the oil never being too cool or too hot. Last edited by mtimney; 07-09-2013 at 10:48 AM. Reason: insertion of image |
#242 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Pics of it installed would be great
#243 |
Drives: FRS
#244 |
[QUOTE=What size cooler did you get, small or medium? And what size barbs for the coolant hose? What size oil cooler lines?[/QUOTE]
If you read my last post you'll see I answered all your questions there. I'll try to get a photo up in the next couple days. |
#245 |
Drives: FRS
Where are those pics at yo?
#246 |
LAMINOVA OIL COOLER
Sorry for the delay...thought I'd have my header in by now and take pictures from under the car too. BUT..it's not here, so you'll have to settle for these shots. See info on what/how I did this in my earlier posts on this thread. |
#247 |
Any thoughts on how often (and then how long) I would want the oil to get above 212 to cook off any water contamination in the oil?
#248 |
Site Moderator
Drives: Stuff
My cooler started leaking tonight.. the core itself. Need to look into it tomorrow. Fun times.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#249 |
Drives: FRS
#250 |
Drives: GT86
#251 |
I've been reading a lot about oil temperatures and the variations in oil temp throughout an engine. In some applications, the oil is 50-degrees hotter at the pistons than the reading at the sensor (usually a sensor in the bottom of the oil pan).
From what I've read, the location of the temp sensor on the BRZ next to the filter is reportedly a good one in that it gives you an idea of oil temp before it goes into the engine. So, If I'm getting oil temps above 200-degrees by the filter, then it seem likely that the oil is getting hotter inside the major, working parts of the engine. Soooooo....I'm guessing that the oil does go above 212-degrees on a fairly regular basis, which means that water is probably being boiled off. Any thoughts from someone with a mechanical or engineering background? |
#252 |
Drives: GT86
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 09:48 AM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
