#15 |
So what happens when a high pressure, cooled mass of air hits another compressor?
#16 |
Fueling would be the limiting factor here.
Engine internal is another but could be negated via higher octane fuel source. You are also not looking at outright HP in shoot out mode for a twincharge setup on a stock engine. The largest benefit would be area under the curve, build for higher torque through out the entire rev range.
![]() Last edited by s2d4; 07-26-2013 at 09:46 AM. |
#17 | |
Drives: GT86
I'm no expect on fluid dynamics, though, but i'm sure someone can chime in to talk about the friction aspect of it. |
#18 |
Drives: AVO BRZ
It's sponsored by a lot of aussie companies, sprintex/avo etc no idea how much its costs.
#19 |
if you're going to do something like that, you'd want to use a lot bigger turbo than that which comes with the avo kit.
| The Following User Says Thank You to jamesm For This Useful Post: | Murseman27 (08-18-2013) |
#20 | |
Drives: AVO BRZ
#21 | |
Drives: Scion FR-S/Toyota Yaris
Well its going to cost more than an Avo + Sprintex. Basically a $10k+ engine with the performance of a diesel, its a tuner competition for P.R. Nothing wrong with Aussie gearheaded fanatical compeiton but that's all it is. The fact that they aren't flow matching the two compressors says everything.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#22 | |
Sure the turbo could be much bigger, I would do the same thing though if I was going to fatten the area even further, not otherwise possible with both kits on their own.. Then again, I couldn't careless about peak HP but instead, how the engine makes power everywhere else.
#23 |
Drives: Scion FRS
Id rather pick one kit
And use the money id spend on the other kit and fabrication and build the motor. |
#24 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
#25 |
Fair enough, you would most likely need a pretty aggressive stroker kit to match the twinscrew. I would rather not deal with messing up the bore vs stroke ratio though.
#26 |
Thats pretty neat
Drives: LOADING......
I feel like anti lag with a turbo or a bigger posi displacement supercharger(since ours is at its limit apparently) would be a better option. our high comp motors cant really eat the boost #'s that twin charging is good for, its a waste of money to develop a true twin charger system just for a couple more psi. Now if you dropped to some low compression pistons and pushed 10 out of the super and 20+ out of the turbo itd be a reasonable investment....but thats just my opinion.
| The Following User Says Thank You to WHITE For This Useful Post: | nix (07-28-2013) |
#27 |
I got the idea from working on the newer twin turbo diesel truck engines and the older 8v92 2 stroke 8v twin charged engines.
Here's an article I found http://www.autozine.org/technical_sc...duction_5.html |
#28 | |
I also have a 4agze in the AW11 and have been looking at trying this too.
| GRMN Gazoo Twin Charged 86 Concept (320hp) Revealed! | KyShro | Scion FR-S / Toyota 86 GT86 General Forum | 151 | 01-04-2016 03:10 PM |
| Gazoo GRMN Sports FR Concept Twin Charged 325HP Teased Ahead of 2013 Tokyo Auto Salon | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 168 | 03-07-2014 08:37 AM |
| FA20CLUB Innovate Twin Screw Combo Now On Sale | FA20Club.com | Forced Induction | 107 | 11-25-2013 10:48 AM |
| Twin Charged HKS set up! | Evasive Motorsports | Forced Induction | 35 | 05-24-2013 05:54 PM |
| Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ | Innovate Motorsports | Forced Induction | 1987 | 03-13-2013 09:14 PM |
