Old 07-26-2013, 05:22 AM   #1
Aaron_blatherwick
Twin charged, Innovate on top and AVO on bottom
Twin charged, Innovate on top and AVO on bottom.
I have heard people mention the idea of twin charging and most reactions have been its way overkill. But I think if set up correctly it might be possible. There is no real way to know until someone try's it. And it might not be as efficient as the standard FI for the BIG dyno numbers.
So my theory is that the positive displacement of the innovate twin screw supercharger would help reduce the boost lag and help with the on/off throttle response while spooling the turbo until it takes over. The supercharger putting out 5-10 psi and the turbo putting out 5-15 or more. At low RPM's the supercharger does it's job in the lower RPM's while at the same time spooling the turbo. Once into the higher RPM's the turbo is most efficient at this point in making power. The super charger will go into a bypass state allowing the boost pressure to pass the twin screws without resistance until the boost pressure is lowered again. The twin screws would be free floating ( not creating pressure but still spinning) at the higher boost levels. This would allow the best of both worlds together. Great instant throttle response of the twin screw and the higher hp and torque output in the higher RPM's with the turbo.
What do you guys think? Is it possible?
Aaron_blatherwick is offline   Reply With Quote
Old 07-26-2013, 06:31 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I in no way support or like such useless idea but if you'd consider such setup look for a big turbo to actually help spool it up don't use the smallest available turbo kit
Everythings possible but something's are not worth it
My 1 cent
Old 07-26-2013, 06:50 AM   #3
ft_sjo
Drives: GT86
The sprintex supercharger has a max flow rate specified.. It's able to achieve this with the right size pulley. Adding a turbocharger won't really give you anything, unless you're able to by-pass the supercharger. This kind of diverting requires complex control to be any good.
The AVO kit gives very good low down performance anyway, so probably wouldn't be the best match for the twin screw.
Old 07-26-2013, 06:54 AM   #4
regal
Exactly the throttle response difference between the AVO and the Innovate can't be much, think of how much more timing is pulled with an innovate tune.
OP needs to look at an LS1 swap for what he is trying to accomplish.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-26-2013, 07:02 AM   #5
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Could you not just pump 15 psi out of the innovate unit? I know they only sell a 7 and 10psi pulley or something, but custom pulleys can be made for both the charger and the crank wich would be way easier/cheaper then making a twin charged system work properly. I do forget what the limit of the innovate chager is tho.
WHITE is offline   Reply With Quote
Old 07-26-2013, 07:12 AM   #6
regal
Instead you would want to go to the next bigger displacement sprintex, its right in its efficiency zone at 7-10 psi. Just like Vortec under estimated the volumetric efficiency of the FA20 and had to go to the next size up centri., the innovate is also on the small size, but fine for what it is (+50 hp.)
The op is really off wall. It sounds like what he wants is some 500 hp monster. Just makes much more sense to swap in an LS1 or buy a camero.
Mods:
Old 07-26-2013, 07:15 AM   #7
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Brett Middleton with MRT is already doing the kit. Check his YouTube @Brett middleton
Ryaquinn is offline   Reply With Quote
Old 07-26-2013, 07:31 AM   #8
regal
He's turning down the boost of the sprintex dramatically and still using the sprintex intercooler.
So not a 500 hp monster, but interesting for a tuner challenge.
Mods:
Old 07-26-2013, 07:45 AM   #9
s2d4
s2d4's Avatar
Look up compound charging, the same theory applies.
Old 07-26-2013, 07:48 AM   #10
s2d4
s2d4's Avatar
Turning the boost down?
Also, any sane person would use two intercoolers as provided by the two kits, not one.
Fueling would be the bigger issue.
Old 07-26-2013, 08:01 AM   #11
regal
Yes the he custom lathed a huge pulley for the sprintex. It looks like more of a P.R. project than something commercially viable or practical.
Mods:
Old 07-26-2013, 08:13 AM   #12
ft_sjo
Drives: GT86
Mass flow is mass flow.
Old 07-26-2013, 08:57 AM   #13
nix
nix's Avatar
Drives: AVO BRZ
http://www.roh.com.au/toyota-86-project.php
That car looks great in person and the owner is a nice guy. He designed a new set of rims for his build, looks like 18x8+37.
nix is offline   Reply With Quote
Old 07-26-2013, 09:07 AM   #14
regal
221Hp for >$10k
Mods:
GRMN Gazoo Twin Charged 86 Concept (320hp) Revealed! KyShro Scion FR-S / Toyota 86 GT86 General Forum 151 01-04-2016 03:10 PM
Gazoo GRMN Sports FR Concept Twin Charged 325HP Teased Ahead of 2013 Tokyo Auto Salon vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 168 03-07-2014 08:37 AM
FA20CLUB Innovate Twin Screw Combo Now On Sale FA20Club.com Forced Induction 107 11-25-2013 10:48 AM
Twin Charged HKS set up! Evasive Motorsports Forced Induction 35 05-24-2013 05:54 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
