#5867 |
SLO NO MO
#5868 |
Drives: 13' FRS, 95' Nissan 240SX
Yes ^^
#5869 |
SLO NO MO
#5870 |
Drives: 2013 Scion FR-S Raven
Did you upgrade to latest version of Pro Ecu?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#5871 |
Yup i sure did. Ima go try it one more time I waited till the sun went down a bit this Texas heat is ridiculous. I also made a ticket for John to look at
#5872 |
So he sent me two files one is the stock tune and the other is the stage 1. When I open stage 1 it says file not supported. But when I open stock it lets me. I think they sent me the wrong one or something ?
#5873 | |
Drives: 2013 BRZ limited SWP
Sent from my DROID RAZR using Tapatalk 2 |
#5874 |
Sucks I got to wait another day
#5875 |
so I woke up not too long ago comes to find out john sent me another file and bam it worked right away I noticed the idle was ALOT smoother compared to before and also the car feels a lot better and more responsive
#5876 | |
Drives: 05 TSX & 13 BRZ
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1 |
#5877 |
I just expected to wait another day because it was 5 o clock and I know most businesses close around that time so I thought they would resolve it tomorrow. But they surprised me. Thanks for the awesome support john
#5878 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Thought I'd share this.
So went for service at Toyota today, with the stock map loaded. They ran a software check and everything was fine, could not pick up Ecutek had been installed. They also ran diagnostic test, which gave Then those that have headers installed without any spacers, once you running on your stock map, the CEL comes on. I further ran readings from Torque Pro, and my Cat sensors were hitting temps of up to 750 degrees, which is 100 degrees above the normal operating temperatures I have recorded prior to installing header. I fitted spacers today to both sensors on the header, no CEL came on while on stock map and my temperatures are back down to normal. Loaded the STG2 tune back and damn the car feels a whole lot more power. I'm going to dyno to verify to ensure its not my imagination. Hope this was helpful info. |
#5879 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
You might not want to have a spacer on the primary O2 sensor since it effects fueling. It could cause the car to run poorly over time since the sensor reading may be a different AFR than actual. The spacer on the secondary sensor is fine though. I believe the CEL was triggered only by the catalyst inefficiency reading from the secondary sensor.
#5880 |
Road Warrior
Thanks, I was advised as you mentioned, just want to see the results before I take the one off if necessary.
So far the AFR readings from Torque are the same as I had before the spacer, so will keep an eye on it. |
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 02:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 07:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 01:42 PM |
