Old 07-25-2013, 05:03 PM   #5867
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by popos1907 View Post
the numbers match yea I guess ima do that was looking forward to getting off and flashing my car
Is it a .bin file?
Sent from my Nexus 4 using Tapatalk 2
Foobar is offline
Old 07-25-2013, 05:08 PM   #5868
popos1907
popos1907's Avatar
Drives: 13' FRS, 95' Nissan 240SX
Yes ^^
popos1907 is offline
Old 07-25-2013, 05:11 PM   #5869
Foobar
SLO NO MO
Foobar's Avatar
Yes ^^
File might be corrupted. I agree with the suggestion to send a ticket in to John.
Foobar is offline
Old 07-25-2013, 05:22 PM   #5870
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Did you upgrade to latest version of Pro Ecu?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 07-25-2013, 05:37 PM   #5871
popos1907
popos1907's Avatar
Yup i sure did. Ima go try it one more time I waited till the sun went down a bit this Texas heat is ridiculous. I also made a ticket for John to look at
Old 07-25-2013, 06:02 PM   #5872
popos1907
popos1907's Avatar
So he sent me two files one is the stock tune and the other is the stage 1. When I open stage 1 it says file not supported. But when I open stock it lets me. I think they sent me the wrong one or something ?
Old 07-25-2013, 06:17 PM   #5873
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
It has happened to me before. John will need to resend you the file.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline
Old 07-25-2013, 06:29 PM   #5874
popos1907
popos1907's Avatar
Sucks I got to wait another day
Old 07-25-2013, 11:41 PM   #5875
popos1907
popos1907's Avatar
so I woke up not too long ago comes to find out john sent me another file and bam it worked right away I noticed the idle was ALOT smoother compared to before and also the car feels a lot better and more responsive
Old 07-26-2013, 12:48 AM   #5876
Sensisnow
Drives: 05 TSX & 13 BRZ
If you have a serious issue, he's on it immediately. When I read your last post, I knew that you wouldn't have to wait more than a few hours, even though you expected to wait another day. You chose the right tuner.
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline
Old 07-26-2013, 01:40 AM   #5877
popos1907
popos1907's Avatar
I just expected to wait another day because it was 5 o clock and I know most businesses close around that time so I thought they would resolve it tomorrow. But they surprised me. Thanks for the awesome support john
Old 07-26-2013, 09:09 AM   #5878
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Thought I'd share this.
So went for service at Toyota today, with the stock map loaded. They ran a software check and everything was fine, could not pick up Ecutek had been installed. They also ran diagnostic test, which gave readings.
Then those that have headers installed without any spacers, once you running on your stock map, the CEL comes on. I further ran readings from Torque Pro, and my Cat sensors were hitting temps of up to 750 degrees, which is 100 degrees above the normal operating temperatures I have recorded prior to installing header.
I fitted spacers today to both sensors on the header, no CEL came on while on stock map and my temperatures are back down to normal.
Loaded the STG2 tune back and damn the car feels a whole lot more power. I'm going to dyno to verify to ensure its not my imagination.
Hope this was helpful info.
Ryan86 is offline
Old 07-26-2013, 09:36 AM   #5879
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
You might not want to have a spacer on the primary O2 sensor since it effects fueling. It could cause the car to run poorly over time since the sensor reading may be a different AFR than actual. The spacer on the secondary sensor is fine though. I believe the CEL was triggered only by the catalyst inefficiency reading from the secondary sensor.
ATL BRZ is offline
Old 07-26-2013, 10:04 AM   #5880
Ryan86
Road Warrior
Ryan86's Avatar
Thanks, I was advised as you mentioned, just want to see the results before I take the one off if necessary.
So far the AFR readings from Torque are the same as I had before the spacer, so will keep an eye on it.
Ryan86 is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
