Old 07-25-2013, 08:29 AM   #57
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by cf6mech View Post
Guess you haven't been there done that yet then. Doesn't matter DI or Port or any combination of the two,...eventually this 165whp engine is going to need more fuel volume once you double or tripled the fuel systems design limits...come on! It has all to do with power level when we are talking BIG power. And that big power level for this engine rides around 20 psi with E85. No blind faith here, just the acknowledgement of the fact that they have been at the forefront of these engines FI, have done the most test and tuning of them, do this for a living, and are not backyard tuning Bozo's.
Pretty sure they're talking about E85 on stock pump/injectors being used in the context of the Innovate Supercharger kit, so you're not going to see those crazy boost levels or power numbers.
Old 07-25-2013, 09:50 AM   #58
jamesm
i was simply making the point that how you utilize DI effects how big of injectors you need. Obviously if you disable DI entirely (as some do) you will need bigger port injectors to move the same mass of fuel. if you lean heavily on the DI you will need less.
Old 07-25-2013, 10:07 AM   #59
Archetype
Archetype's Avatar
Drives: 2013 BRZ Turbo, 2013 FRS
Are any of you guys going to make a trip to the 86 nationals in KY?
Archetype is offline   Reply With Quote
Old 07-25-2013, 10:19 AM   #60
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I am more than likely going. Working on finding someone to look after my dog for the weekend, then I will book the hotel.
Old 07-25-2013, 11:01 AM   #61
Frs300
Frs300's Avatar
Drives: Pile of junk
want me to watch the dog lol
Frs300 is offline   Reply With Quote
Old 07-25-2013, 11:04 AM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That will be a long drive each day. I would rather you take off work and come with me to 86 Nationals. It will remind you what it was like to own an FR-S, haha.
Old 07-25-2013, 11:05 AM   #63
Archetype
Archetype's Avatar
Hell I want you to come up too....I want to see the famous Frs300 motor, haha. I bet that thing is badass now.
Old 07-25-2013, 11:23 AM   #64
lexusb3
Drives: FRS
I want to win the performance prize lol but now @Frs300 is going to make me look like I'm stock !!
lexusb3 is offline   Reply With Quote
Old 07-25-2013, 11:30 AM   #65
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So any idea when will you be picking up??
Old 07-25-2013, 11:36 AM   #66
Frs300
Frs300's Avatar
no clue
Old 07-25-2013, 11:43 AM   #67
Frs300
Frs300's Avatar
funny guy
i would love to go but dunno if the car will be done or not
Old 07-28-2013, 08:37 AM   #68
cf6mech
Drives: FRS Silver LS1 swapped.
I do believe Crawford, Accelerated, I , and a few others have taken this engine past your horsepower level and found a weakness. Dynos all don't read the same and measure differently, to me there sole purpose is to see a gain from a baseline, my engine could very possible read 500 on your dyno,...don't know. If you haven't reached the limits on the stock fuel system above and beyond a change to the stock fuel pump in the tank, meaning,... having to go to a surge tank or a rising rate return system to make things safe, like I have,.. I know comparatively I'm making a lot more power than you regardless of horsepower claims, not because of the use of it, but because of the necessity of it.... I don't think this confusion over why some engines go boom and others don't is because of tuner issues,...I think its more of an issue of what guys are claiming for horsepower and the variances from one dyno to another and BHP versus WHP. Yes there are going to be a few bad tunes with resulting damage, but guys like Quirt Crawford, Visconti and Don at AP making rookie tuning mistakes?.....I just don't believe that. I'm believing once you reach 20psi boost,... stronger head studs,...which aren't available, and stronger more compliant aftermarket crank bearings,... which also aren't available, and a very serious look at forged rods and pistons is a must for the FA20...
The FRS being raced in the Pirelli Sports Car Challenge series has had rod bearing failures, now this is a fully built engine with I'm sure some factory Toyota support i.e. the TRD supercharger that no one can afford . Best case scenario they are running OEM bearings,...worse case is if they beefed them up and they still failed. This engine isn't as strong as some claim.
cf6mech is offline   Reply With Quote
Old 07-28-2013, 08:54 AM   #69
Frs300
Frs300's Avatar
there is an alternative for crank bearing havent seen anything for rod bearings yet. and dynosty has studs available case and head
Old 07-28-2013, 09:10 AM   #70
lexusb3
Drives: FRS
strong enough to push my car 12,000++ miles with abuse lol Pirelli needs to call tony lol
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
How reliable is a boosted FRS/BRZ? wootwoot Forced Induction 123 07-22-2016 03:18 PM
Most reliable F/I kit? official_george Forced Induction 103 05-14-2013 12:00 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
