View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-24-2013, 07:38 AM   #2409
FR-S Matt
Originally Posted by denkigrve View Post
Mine went away after a few thousand miles. I'm at 10k+ now and it's completely gone.
8300 miles and my chirps have moved to a new stage. They're barely there at idle, but when I give it just a tiny amount of gas you'll hear them.
I'll probably just keep driving on this fuel pump and hope for the best rather than have Toyota mess with my car each time.
Old 07-24-2013, 08:00 AM   #2410
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Grishbok View Post
take what to the press? that your car makes noise? That will be front page on New York Times...
This is whats called a non-impacting issue. It does not affect performance or operation of the vehicle, no gurantee or promisory note was made as to the sound of the vehicle.
The vehicle has changed. The one you test drove and the one you took home were quiet and didn't sound like a 15 year old vehicle with knackered pulleys and drive belts.
What's more, for many people it transformed within a few hundred miles and is clearly very irritating and spoiling the car for them.
It was just a suggestion. We don't have the problem here.
sierra is offline   Reply With Quote
Old 07-24-2013, 04:24 PM   #2411
azburnin
azburnin's Avatar
Drives: 2013 Raven FR-S
Originally Posted by infinite012 View Post
I went back to my dealership and was told they would not replace the pump a third time without SOA's authorization and to contact SOA for further advice. I did so and now I've been asked to bring in OIL CHANGE RECEIPTS?! How does my oil change intervals affect the function of the high pressure FUEL PUMP!?!
This is kind of ridiculous, but I'll play ball...
Alright, Look up your Lemon Law for your state. Then get on this website
http://www.ncdsusa.org
They have a form you fill out and mail in, I received a phone call and email within two weeks. They're are a free organization that helps the car buyer through the faulty vehicle situation. Be organized and thorough with your receipts and learn up on your states lemon law.
I have an appointment with them and toyota to look through my car and determine what the next step is. Being told by toyota that "This is a year one car, you should expect this", is not a good enough reason to not have a fix.
azburnin is offline   Reply With Quote
Old 07-24-2013, 05:19 PM   #2412
thill
In my state there is no chance you could lemon law your car because of the crickets. It has to be a "substatial defect":
Be aware that the manufacturer does not have to make a refund or replace the vehicle if:
The problem does not substantially impair the use or market value of the vehicle; or,
The problem is the result of abuse, neglect or unauthorized modifications or alterations of the vehicle.
I don't see how you could imply that the crickets "substantially" impair the use of the car or market value.
Old 07-24-2013, 06:27 PM   #2413
Chee-Hu
Chee-Hu's Avatar
I have 12k+ on the BRZ and the crickets are still there, barely. It's hard to notice unless you listen for it.
Chee-Hu is offline   Reply With Quote
Old 07-24-2013, 08:28 PM   #2414
AR35
Drives: none
Whos to say its not a much larger problem that we just dont know about yet. Maybe 50k-100k down the road we are all like ooohhhhh thats why it was chirping and somthing BIG happens on the car. We all know it SHOULDNT be chirping. We didnt buy it with the chirp and we dont want the chirp. So i dont see how the lemon law doesnt fall into place. As long as you word it correctly anything falls into place. The lemon law only works for so many miles then your screwed. I plan on taking action with the lemon law if mine continues. They are obligated to give you a NEW car or all your money back. So we will see.
AR35 is offline   Reply With Quote
Old 07-24-2013, 10:06 PM   #2415
thill
I have been down the lemon law path before in Virginia with VW (car was in the shop more than 30 days within one year of ownership). It is not nearly as you are making out to seem and, again, you would have to prove that the crickets (at least in Minnesota, but most states are similar) were "substantially impairing" your ability to drive the vehicle, or the crickets would have to have "caused the complete failure of the steering or braking system and which is likely to cause death or serious bodily injury".
You can certainly try to go to arbitration for this, but good luck. I would not even waste my time.
I will definitely complain to both my dealer and Subaru America, but expecting to get Toyoya or Subaru to replace your car for something this minor is not being very realistic. Every car I have ever owned has had quirks. If the worst thing this car has is some intermittent crickets I will be happy.
A new car would be useless. All of the cars have this issue in the US (or the potential to have the issue). They all use the same HPFP.
Old 07-25-2013, 12:15 AM   #2416
Greg_Di
Drives: Scion FRS
Originally Posted by sierra View Post
My guess would be that you got some fuel with ethanol in a couple of weeks ago. If it goes in the tank by mistake they aren't likely to pump it out even if they know.
Why are you using 91 when the engine is designed and tuned for 93?
I know they say it can safely run on 91 but clearly 93 and higher is the fuel to use unless you get caught out somewhere with only low octane available.
Only the Shell 91 is Ethanol free here that is why I use it over the petro 94, 94 has 10% Ethanol. Sure it is designed for 93+ but I does say 91 is perfectly fine and I would rather run the 91 with no ethanol
Greg_Di is offline   Reply With Quote
Old 07-25-2013, 01:06 AM   #2417
sierra
Fair enough. I would do the same but it does mean the performance will be reduced.
Old 07-25-2013, 01:49 AM   #2418
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
Would there be any benefit to running an octane booster with 91-E0 gasoline; to help performance, or is that crazy talk? I will be filling up tomorrow for the second time after using E0 gas with no crickets. I love not having the crickets, but if performance is being lessened, it's a tough trade-off.
She's Gone....
Flickr Page
MadFRS is offline   Reply With Quote
Old 07-25-2013, 02:00 AM   #2419
sierra
I think the danger with octane booster is that it can block the cats.
If you can't feel the difference it can't be that much. What do they say, you can feel 10% but not 5%?
Keep moaning to the dealer.
Old 07-25-2013, 02:06 AM   #2420
MadFRS
MadFRS's Avatar
That is probably all of our best bets at this point. Unfortunately I don't think this is a fix the community can provide. The manufactures need to step up and solve the issue.
She's Gone....
Flickr Page
Old 07-25-2013, 03:12 AM   #2421
Ericbdrummin
Drives: Scion FR-S
So I just had my one yr anniversary with my car. It's a love, hate, relationship.
I haven't been on this site since Jan. I'm back because the crickets are back, for the third time !! I have 18XXX mi. Two ECU's, two fuel pumps, one rear taillight. Dealers been ok I guess, considering all the posts I just read. If I had to do it all over again, I wouldn't buy this car. I've owned, and do own, Lexus, Toyota, Scion. Never buying a Scion again.
Not looking forward to going through all this crap again. Toyota is about to lose a lifelong customer of 30 yrs, to Honda, if this doesn't get resolved.
Ericbdrummin is offline   Reply With Quote
Old 07-25-2013, 03:18 AM   #2422
Ericbdrummin
Drives: Scion FR-S
Its not the gas. Toyota should have known how 93 oct Chevron gas would have affected the fuel pump. That's most likely the best, most widely accessible gas, on the west coast of the U.S.
I think the construction of the fuel pump is the issue, IMHO.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
