| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#2395 |
1400 miles and finally got the crickets. Running 92 octane Sams Club gas. They are mild compared to the waste gate rattle in my 13 Gencoupe......
#2396 |
Drives: Scion FR-S
I had my fuel pump replaced July 12th. The crickets went away for 4-5 days, however, I'm sad to report that they are back with a vengeance. Take this for what you will, but, I'm using 91 Octane gas (93 isn't available in CO) which contains ethanol. I would try the 0 ethanol gas, however, there isn't a station remotely close to my area which has it.
My build thread:
http://www.ft86club.com/forums/showthread.php?t=63292 |
#2397 |
Drives: 2013 ft86
chirping
just about to break 300 miles and yes I have the same noise....
#2398 |
Drives: 2013 BRZ DMG manual Limited
#2399 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Some people don't have access to 93 just like some people don't have access to E0. There is literally no where in Wichita that sells 93.
| The Following User Says Thank You to DylanFRS For This Useful Post: | strat61caster (07-24-2013) |
#2400 |
Drives: Skoda Yeti DSG diesel 4x4
How about someone organising a register with all the chirpers, FRS and BRZ, on it with names and rego. Then contact Scion/Toyota and Subaru with the numbers and demand a resolution or you take it to the press?
It's been well over a year now and they've done nothing to solve the problem. |
#2401 | |
Maybe they should have set the car up specifically for 91 E10 for the US but then the lower official power output might have scared off customers? |
| The Following User Says Thank You to sierra For This Useful Post: | DylanFRS (07-23-2013) |
#2402 |
Keep in mind for folks in places like Colorado and Utah. They typically don't have access to higher octane gas in most locations because they are above sea level and air is thiner. Which means you have less air going into the cylinders. 91 octane above sea level is most likely the equivalent to 93+ octane gas @ sea level.
#2403 |
Drives: Frs argento
weird sound
i got 752 miles on my frs and i start hearing weird noise! is this normal or should i go back to dealership or wait for my first oil change service.. i need help thanks!
#2404 |
Weird noise like crickets when you are idling in the car with the windows down? If this is the noise, I would note it with the dealership but there is no known fix, so even if they give you a new high pressure fuel pump, you will most likely get them again. One solution to try is if you have access to 0 ethernol gasoline. Try filling up with that. I am going to give it a shot as well.
#2405 |
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
So after I switched from Petro Canada 94 to Shell 91, the chirping stopped, as I previously stated.
NOW.. they are back :/ I'm at 3500k sooo 2000 miles? It sounds like belts to me |
#2406 |
Drives: 2013 BRZ Limited
Chirp chirp chirp... reported to Subaru, waiting for permanent fix.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#2407 |
Random Internet dad
Drives: 2013 FRS and 2010 Mini Cooper
Mine went away after a few thousand miles. I'm at 10k+ now and it's completely gone.
#2408 | |
Volunteer Fire and Rescue
Drives: Ambulance... sideways.
take what to the press? that your car makes noise? That will be front page on New York Times... This is whats called a non-impacting issue. It does not affect performance or operation of the vehicle, no gurantee or promisory note was made as to the sound of the vehicle.
It's more fun to drive a slow car fast, than a fast car slow.
| The Following User Says Thank You to Grishbok For This Useful Post: | strat61caster (07-24-2013) |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 10:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 03:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
