Old 07-22-2013, 03:36 PM   #15
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Yeah mine does it and I have the Perrin inlet and the sound generator plugged off.....
It's only while accelerating in 6th over 75mph. Very quite thou.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-22-2013, 05:05 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by VABRZ View Post
My car started whistling at 80 mph and up. Took it to the dealer and insisted it was the fuel pump. They reluctantly replaced it. Now it, sometimes, starts whistling at 63 mph and up.
This guy... What gave you the idea that the whistling is from the fuel pump? Your dealer must be really nice, because I'm not seeing the relation between intake and fuel pump.
Many cars have the "whistle". It's just induction noise. The sound tube doesn't affect it either. I've heard it on nearly every type of vehicle.
Old 07-22-2013, 07:30 PM   #17
StormTrooper
Probably has to do with airflow through the snorkel....anyone with an after market intake with that removed care to chime in.
GR86 MT premium
Old 07-22-2013, 08:31 PM   #18
Yruyur
Yruyur's Avatar
Try putting it in neutral and coasting to see what happens. Also roll down the windows and see if you and a passenger can determine a side its coming from. Could always mount a go pro in different locations to narrow down the source.
I have a airaid with stock snorkel and dont hear anything.
Sent from a Motorola DynaTAC 8000X
Old 07-22-2013, 10:25 PM   #19
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
My car makes this noise. Its almost like a "digital" whistle, or high pitched hum when traveling on the highway at steady speeds. Ive been suspecting the sound tube, and will be removing it this week just to see.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-23-2013, 10:49 AM   #20
StormTrooper
It's not the sound tube....it goes away when you let off the gas in gear or out.
It's not very loud so I'd imagine the air raid covers it up .
GR86 MT premium
Old 07-23-2013, 08:50 PM   #21
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Exactly, when the throttle plate closes. Theres no air being sucked through the intake (well, there's a very small amount), so the air going through the sound tube is minimal.
Parting out HERE
Old 07-24-2013, 11:51 AM   #22
StormTrooper
I have mine removed and it still does it....
GR86 MT premium
Old 07-24-2013, 01:56 PM   #23
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Well that changes everything :p
Parting out HERE
Old 07-24-2013, 04:17 PM   #24
boredom.is.me
Custom User Title
At this moment in time, I think this thread is hopeless. This is only the second page and it already sounds (reads) like a broken record.
Old 07-24-2013, 05:51 PM   #25
empower-auto
Kouki-Monster
empower-auto's Avatar
put in a whiteline positive shift bushing and it gets even louder.
it's normal. gear noise
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-24-2013, 10:17 PM   #26
StormTrooper
I know lol....
GR86 MT premium
Old 11-17-2015, 09:46 AM   #27
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
I've been having the exact same noise you guys seem to be describing for the past few weeks.
A high pitch whistling noise that happens only when I'm on throttle in the 6th gear, between 3100-3600 rpm, and hits the peak at 3500 rpm and then goes away pretty quickly. In speed terms, around 73-74 mph the noise starts hits peak at 80 mph and goes away after that. Does anyone have any update on this?
It's not the noise tube for sure. I have a Perrin CatBack installed, but others on this thread having the same issue don't seem to have any exhausts installed. I recently changed my trans and diff fluid too, but the noise still persists.
@StormTrooper @Lydin any updates from you guys?
FYI - I have 42,000 miles on this vehicle. No other mods, everything else is stock.
ZeHeadBanger is offline   Reply With Quote
Old 04-04-2016, 12:18 AM   #28
sobrz
sobrz's Avatar
Same exact symptoms as @ZeHeadBanger.
35K miles now, everything stock except Perrin catback and plugged noise tube.
Sounds like transmission gear whine / nonexistent supercharger whine.
Feels like it's been getting louder over the last few k miles.
sobrz is offline   Reply With Quote
What's this noise? Nitesh31 Issues | Warranty | Recalls / TSB 3 12-19-2012 09:35 PM
Turbo Whistle v. Blower Whine SupraLove Forced Induction 34 11-21-2012 08:56 PM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 03:21 PM
