View Poll Results: Would you rock this type of exhaust on your BRZ/FRS?
YES 48 67.61%
NO 12 16.90%
Maybe 11 15.49%
Voters: 71. You may not vote on this poll
Old 07-24-2013, 10:43 AM   #15
topazsparrow
Drives: slow
Originally Posted by Ingen View Post
True that it's easier, but didn't at least one tuner company melt the bumper off their frs by removing the muffler without directing the exhaust out from under the car?
That's certainly a possibility. Positioning and orientation would be important factors for avoiding that kind of thing though.
topazsparrow is offline   Reply With Quote
Old 07-24-2013, 11:07 AM   #16
Asphalt~86
Drives: Asphalt AT
Do you know what kind of a pricepoint you would be looking at? I know others have favored your exhaust because of the pricing so I am wondering if we are going to be making a huge jump for something like this?
Asphalt~86 is offline   Reply With Quote
Old 07-24-2013, 11:41 AM   #17
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Originally Posted by Anthony View Post
But I'm just trying to go fast.
I'm afraid you're in the wrong car for that.
Admiral Ballsy is offline   Reply With Quote
The Following User Says Thank You to Admiral Ballsy For This Useful Post:
suaveflooder (07-24-2013)
Old 07-24-2013, 11:46 AM   #18
R3d
Drives: White FR-S
Originally Posted by JonMotoring View Post
Been having this idea of making an exhaust that can be quiet and loud with a touch of a button.
The exhaust pictured above is for Nissan R35 GTR. Here's a video of the difference in sound levels:
It's pretty much a dull exit design with an electronically controlled valve on one side.
The side with the electric valve is straight pipe with no muffler or restrictions.
The other side has a muffler to help quiet down the exhaust when you are just cruising thru town.
I plan to make the side with the muffler with a slightly smaller diameter piping and a well packed muffler to keep the noise level down.
On the electric valve side it will be a 2.75 inch piping (proven diameter to make power on a FRS/BRZ) and with either straight pipe or a high flow muffler.
What do you guys/gals think? If there's enough interest, we might just put this into production.
My only question : What does it weigh ! if its the same as original or less ill buy it right now!
R3d is offline   Reply With Quote
Old 07-24-2013, 12:06 PM   #19
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Nonsense!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 07-24-2013, 12:06 PM   #20
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by topazsparrow View Post
It would be a lot easier and cheaper to adapt an existing exhaust and put the dump before the axle back.
For example, you could put the cutout before the muffler on the Perin axle back and achieve the same results. Cutouts are illegal in most places anyway so I wouldn't worry about where the exhaust is being vented too much if that's a concern.
Or just use a Varex muffler I'm probably going to do just that after i get my header.
Old 07-24-2013, 12:50 PM   #21
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Aren't cutouts known to malfunction because of all the large heat fluctuations with exhaust pipes? I thought about getting a cutout when I had my WRX, but after doing a bit of research found out they can get stuck and stop working.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 07-24-2013, 01:18 PM   #22
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Most are put really close to the collector at the engine, or in the case of your WRX, in the down pipe. It will see much higher temperatures in those locations. Putting one at the back would, in theory, see lower and more stable temps. So it should last longer.
The Following User Says Thank You to Draco-REX For This Useful Post:
JonMotoring (07-24-2013)
Old 07-24-2013, 02:46 PM   #23
fang_gt86
FR Noob
fang_gt86's Avatar
I'm just curious. Is there any "sacrifice" in performance by having noise adjustable exhaust? I'm assuming that when the valve shuts-off, there would be some kind of trapped gas creating "un-even" flow. Will this affect anything as far as performance wise?
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 07-24-2013, 03:39 PM   #24
loogs
Drives: on cruise control
if it looks like that, ill take one
loogs is offline   Reply With Quote
Old 07-24-2013, 08:55 PM   #25
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
I would be interested in this. My car is multipurpose. So I want Auto X light weight and free flowing, but also want quiet for the wife and kids on a road trip. Quiet slipping back into the neighborhood.
This is the same reason our WRX wagon has this custom set up I built with the help of my local shop, and an XForce Varex muffler. Its heavier than what I would want for my BRZ, but is great for dual purpose Dr Jekyll and Mr. Hyde
[ame="http://youtu.be/cL1G22s2G5c"]http://youtu.be/cL1G22s2G5c[/ame]
turbocat is offline   Reply With Quote
Old 07-24-2013, 10:02 PM   #26
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Agreed, and titanium would be amazing, but spendy. Not afraid of cost if it can truly do dual purpose + light weight.
Old 09-26-2013, 06:54 PM   #27
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I want one
Hook me up please!!! I have a DD and want it loud, well, sometimes!! I'm so used to my motorcycles. I like hearing exhaust to be able to hear the RPM to shift, rev match, blip etc. It's hard to hear with stock exhaust.
DrDuquette is offline   Reply With Quote
Old 09-26-2013, 08:55 PM   #28
mad_sb
BTW, I went ahead with my custom varex catback. My advice, use a large resonator and a smaller can than what i used.
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
Electric Exhaust Cutout = Loud as %$#@ M-17 Engine, Exhaust, Transmission 44 05-05-2019 05:59 PM
Need a quiet exhaust setup for California Pneub Engine, Exhaust, Transmission 17 05-29-2013 03:34 AM
Looking for a loud exhaust Itssrayyxd Engine, Exhaust, Transmission 66 04-01-2013 03:53 PM
Quiet exhaust s2kdrew Engine, Exhaust, Transmission 21 06-25-2012 11:22 PM
