Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-19-2013, 06:38 PM   #1
Andrew666
Drives: 86 GTS
Ethanol
Delete!
Andrew666 is offline   Reply With Quote
Old 07-20-2013, 12:38 AM   #2
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
why not just run non-ethanol fuel?
JP is offline   Reply With Quote
Old 07-20-2013, 07:06 AM   #3
cuddefred
Drives: Black 86 GT
Agree. Toyota recommend 98 Ron and the handbook states that 95 can be used without detriment to the engine if necessary but not sure how they will react if they know that 100 has been put in. Will be interesting to see how it works out.
cuddefred is offline   Reply With Quote
Old 07-20-2013, 08:42 AM   #4
KamalT
Drives: Pearl 86 GT
get flex fuel sensor. Issue resolved. I ran it on E85 from United for awhile and there was no issue.
Reason went back to 98. No map. really nice. Waiting for new E85 map.
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 07-21-2013, 09:59 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just curious, did the issue go away when you switch back to non-ethanol 98? Or is the damage irreversible and requires new HPFP?
Fizz is offline   Reply With Quote
Old 07-21-2013, 06:56 PM   #6
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
Originally Posted by Andrew666 View Post
If you read your manual mate (page 389) it states 98RON or higher!
The octane rating of fuel tells you how much the fuel can be compressed before it spontaneously ignites. When fuel ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine.
Higher octane "pump" fuel will not damage an engine (in Japan the fuel is of a much higher quality then the crap we get).....ethanol is the issue in this case.
i suggest you go back and check again because it implicitly states that 98 or higher is optimal however the engine can be run without detriment on 95 octane however it will not run at maximum performance.
I am also reasonably sure it states in there that fuel with up to 10% ethanol is fine to use too..
There are several boys in sydney running E85 without issue. The crickets on the other hand is a known issue even in circumstances where people havent touched ethanol.
Its just a coincidence IMO
RAN94A is offline   Reply With Quote
The Following 4 Users Say Thank You to RAN94A For This Useful Post:
coyote (07-21-2013), cuddefred (07-21-2013), DAEMANO (07-24-2013), DanVIIIVI (07-21-2013)
Old 07-22-2013, 08:20 AM   #7
ZZT86
ZZT86's Avatar
Drives: BR86
Personally I have never used any fuel mixed with ethanol, only Shell VPower, yet I still have the crickets and according to my Toyota tech "it is what it is" a Toyota designed HPFP & nothing can be done to correct the issue atm :/
I would also not recommend the use of ethanol mixed fuels due to a school of though amongst mechanics & technical experts that it accelerates corrosion of the fuel system !
ZZT86 is offline   Reply With Quote
Old 07-22-2013, 08:39 PM   #8
RAN94A
Grand PooBah
RAN94A's Avatar
What is wrong with you.. READ THE WORDs didn't say its an octane issue. No mention of performance loss...didn't expect to increase performance using it....didn't say the manual indicated if the 86 could or couldn't use ethanol fuel..... .....suggest you go back and read my message.
Except the topic of your thread is "dont use ethanol based fuel"....
My point is; why shouldnt people use ethanol blended fuel? Because you used it and had the cricket issue (that is already a known issue and as ZZT86 demonstrates, not neccessarily associated with ethanol in any way.)
The car is stated as fine to operate with fuels containing up to 10% ethanol which the united 100 octane does. Your thread as it stands is invalid.
Maybe you should look into the numerous "what is causing the cricket noise" threads before providing us with your expert diagnosis.
The Following User Says Thank You to RAN94A For This Useful Post:
Old 07-22-2013, 10:19 PM   #9
Andrew666
Drives: 86 GTS
RAN94B so sorry I was only repeating what the Toyota mechanic told me and two other mechanics that I spoke to. The SERVICE BULLETIN stated that "certain fuel temperatures or fuel formulations" cause the issue …. so thank you for providing us with your BULLSHIT expert diagnosis.
I will check with you first before I post next.
So how long have you suffered small D*** syndrome?
Old 07-22-2013, 10:25 PM   #10
Andrew666
Drives: 86 GTS
Deleted
Old 07-22-2013, 10:33 PM   #11
autogyro
Drives: Toyota 86 GTS
Want to delete tread?
Go drifting
autogyro is offline   Reply With Quote
The Following User Says Thank You to autogyro For This Useful Post:
RAN94A (07-23-2013)
Old 07-23-2013, 02:23 AM   #12
cuddefred
Drives: Black 86 GT
Go drifting
Old 07-23-2013, 02:32 AM   #13
cuddefred
Drives: Black 86 GT
Oh dear!
The Following User Says Thank You to cuddefred For This Useful Post:
RAN94A (07-23-2013)
Old 07-23-2013, 04:23 AM   #14
Panman
Panman's Avatar
Drives: 86 GTS
Well that went south quickly....
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
RAN94A (07-23-2013)
Why does the fuel pump not do well with ethanol? boredom.is.me Engine, Exhaust, Transmission 42 02-28-2019 06:21 PM
Where to get non ethanol fuel? mhigham Engine, Exhaust, Transmission 19 11-13-2012 11:27 AM
Ethanol fuel treatments JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-19-2012 11:42 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Website that locates ethanol-free fuel wbradley Issues | Warranty | Recalls / TSB 8 07-24-2012 12:47 AM
