Old 07-20-2013, 08:24 PM   #645
ft86me
ft86me's Avatar
Drives: 2013 FRS
I've been working on Vortech stuff all week, so just a update I've come up with
Is this with the normal kit without the smaller pulley?!?!
ft86me is offline   Reply With Quote
Old 07-20-2013, 09:19 PM   #646
Visconti
Drives: 05 STi
Originally Posted by ft86me View Post
Is this with the normal kit without the pulley?!?!
yeah
Visconti is offline   Reply With Quote
The Following 2 Users Say Thank You to Visconti For This Useful Post:
charged86 (07-21-2013), Deepseadiver (07-22-2013)
Old 07-20-2013, 09:19 PM   #647
ft86me
ft86me's Avatar
Drives: 2013 FRS
yeah
Whoooaaa when are you releasing that?!?! I want I want lol
Old 07-21-2013, 10:13 AM   #648
Foobar
SLO NO MO
Foobar's Avatar
Looks like you fixed that craziness that was happening after 6.5K on the first round of Vortech basemaps. Good job!
Old 07-21-2013, 10:15 AM   #649
Visconti
Drives: 05 STi
Yeah , the HKS car I was working on was doing something similar just more drastic had a look at a few things and found the issue.
John
Old 07-21-2013, 10:28 AM   #650
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Sooo wish my dyno map looked more like this
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 07-22-2013, 10:14 AM   #651
nelsmar
So.... who else has this problem?
It is rare i ever see my airbox closed shut. If you just tap the airbox the winged clamps completely rotate loose... It is damaging my hood and i fear it slipping out and hitting my belt at this point. I don't know why simple bolts were not acceptable like most OEM's. =/ The entire setup just looks cheesy and low quality. I really wish the supercharger was just moved slightly or used a secondary belt instead of the main one.
edit: @Brian@Vortech i think you guys should add this to the manual of how to secure the air box ;D
My flickr - Canibeat
Local magazine scout
Old 07-22-2013, 10:40 AM   #652
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Pretty sure I have a bit of a boost leak. Pulling the front bumper tonight anyways so am going to check all the couplers and hopefully find it.
pheoxs is offline   Reply With Quote
Old 07-22-2013, 03:02 PM   #653
Foobar
SLO NO MO
Foobar's Avatar
I thought I was going to have this issue when I first saw the wing thingies (yes that's a technical term), but it has managed to stay shut on mine. One thing I might recommend is to make sure the rubber gasket material is sealing correctly against the filter box. You could probably even get thicker gasket material to make a better snug fit which should keep things in place.
Old 07-22-2013, 03:09 PM   #654
nelsmar
The whole "hatch" setup just looks cheap and low quality. It rattles a lot and has damaged the insulation under my hood. I am just surprised at how bad it was. It should have just been screws/bolts. I also have problems with all other bolts on my air box slowly backing them selves out. Everything else is fine on the car. I am wondering if it is due to the heat in my area causing slight warping?
Old 07-22-2013, 03:15 PM   #655
Foobar
SLO NO MO
Foobar's Avatar
Could be. You could replace then with regular screws/bolts - check out what charged86 did with some parts from Ace hardware:
http://www.ft86club.com/forums/showt...170#post944170
Old 07-26-2013, 02:15 PM   #656
Dezoris
Dezoris's Avatar
I had a talk with Brian yesterday and a few of their engineers about their new cast intake pipe. Going to be doing a follow up on the install and support impressions.
But needless to say, at this point I think despite some of the issues it has become clear, having stateside, support, engineering and manufacturing is critical. It's a smart move buying a kit from a company who's primary business is Superchargers. (More on this later)
At first I seriously questioned my choice with this kit but now working through it talking to other owners I no longer regret it.
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
Brian@Vortech (07-29-2013), civicdrivr (07-27-2013), kinryu (07-30-2013)
Old 07-26-2013, 02:45 PM   #657
Foobar
SLO NO MO
Foobar's Avatar
Welcome back to the dark side...
The Following 3 Users Say Thank You to Foobar For This Useful Post:
Brian@Vortech (07-29-2013), ft86me (07-26-2013), kinryu (07-30-2013)
Old 07-27-2013, 09:20 AM   #658
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
In for auto supercharger kit.
(No rush though guys because I can't afford it right now. But I will be watching!)
Nevermore is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
