Old 07-18-2013, 10:26 PM   #1597
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by mashal View Post
Rims are Moda MD11: 18x8", offset is et42, the centre bore is 72mm I believe (hub centric rings will fit them to any car)
Tires are Westlake SV308s: 225/40R/18 all-seasons
What do you guys think of that? I copied that of the ad.
Ok
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 07-18-2013, 10:27 PM   #1598
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Vic View Post
Hey guys, I'm new to this so Im trying to run a 17x9 with 20 offset square setup on a stock suspension (no drop, stock.).
I'm going with 245/40/17 tires on it. I'm just concerned with any rubbing issues if anyone has a similar setup.
Can someone recommend me good tires that doesn't reduce the handling feel of the fr-s with this setup? Thanks!! (I'm a noob at this)
Not ideal. 25-30mm front poke...
. Read this thread.
Old 07-19-2013, 12:33 AM   #1599
Vic
63 Auto Body
Vic's Avatar
Drives: 2013 SCION FR-S WHITEOUT
. Read this thread.
theres like 73 pages!!
what would be an ideal setup with 17x9's?
Vic is offline   Reply With Quote
Old 07-19-2013, 02:27 AM   #1600
ill86
ill86's Avatar
Drives: iG FR-S
35 - 40, much higher and you may rub the spring perch.
I was suggesting reading this thread (or even just a few pages back, or perhaps the post directly above yours..) as this has been asked numerous times. x9 is a popular size. No worries.
:happy0180:
Old 07-19-2013, 10:48 PM   #1601
OakmanSmalls
Drives: 2013 DGM BRZ
17x8.5 +30 215/40/17 lowered 1.2". Will I rub? And will I be mexiflush? A small amount of poke is fine but don't want to b way out there
OakmanSmalls is offline   Reply With Quote
Old 07-19-2013, 11:11 PM   #1602
Vic
63 Auto Body
Vic's Avatar
:happy0180:
I will be probably going with a 35 offset. Thanks man! haha sorry to bother you o' wise one. I will learn to use the power of the search button more.
The Following User Says Thank You to Vic For This Useful Post:
ill86 (07-20-2013)
Old 07-20-2013, 02:46 AM   #1603
ill86
ill86's Avatar
Drives: iG FR-S
Exclamation IMPORTANT - READ!
Take a look at these helpful posts a few pages back.
http://www.ft86club.com/forums/showp...postcount=1585
http://www.ft86club.com/forums/showp...postcount=1586
Be sure you understand how much poke a 9 +35 has at stock height and lowered with camber.
Old 07-20-2013, 03:21 AM   #1604
ill86
ill86's Avatar
Drives: iG FR-S
Very close to 9 +35 (~ 1mm)
See above post with links.
Old 07-27-2013, 08:51 AM   #1605
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Will it fit???
17x9 +20 offset
I have a 1" drop on stance coils. Planning a 235/40 front and 255/40 rear.
Ryaquinn is offline   Reply With Quote
Old 07-27-2013, 08:10 PM   #1606
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Ryaquinn View Post
Will it fit???
17x9 +20 offset
Front is approx an inch past the fender. Unless you are running a crap load of negative camber or going wide body it is not a good fit.
The Following User Says Thank You to ill86 For This Useful Post:
Ryaquinn (07-28-2013)
Old 07-27-2013, 08:26 PM   #1607
tinma
Drives: '13 BRZ
I am looking for a flush look but with stock ride height/suspension. What would b the most recommended tire and wheel specs that will not effect the speedometer much. (I would like 18" rims).
Sorry for such an open ended question... I'm just a big noob to this thing and want to start things off right :p I'm worried if I just go with whatever I'll end up rubbing at the fender or at the suspension
tinma is offline   Reply With Quote
Old 07-27-2013, 08:52 PM   #1608
86TruenoFRS
Drives: Rocket Bunny v1 FRS
I was considering running a staggered offset and not so much wheel size. I believe that the rear wheels should poke more than the front esp on a RWD car(looks wise) I was thinking of running 18x9.5 +42 front and 18x9.5 +30 rear. Im not concerned with the rear so much as I am the front. since the offset is high in the front will I have issues with the inside of the wheel or tire coming in contact with the suspension or fender well? I was planning on running a 225/40 up front. any insight would be greatly appreciated.
86TruenoFRS is offline   Reply With Quote
Old 07-27-2013, 09:55 PM   #1609
ill86
ill86's Avatar
Drives: iG FR-S
225/40-18
18x8 +35 - +45
tinma (07-27-2013)
Old 07-27-2013, 10:01 PM   #1610
ill86
ill86's Avatar
Drives: iG FR-S
Rear fitment is fine.
Front fitment is difficult/ not ideal for several reasons.
- A 9.5" wheel is very wide up front.
- It will poke past the fender.
- It is too much wheel for a 225 IMO. The add'l weight is unnecessary.
I would suggest an 8 - 8.5" up front for easier fitment.
If you are insisting on a square width/ staggered offset, consider 9" wheel.
I hope this helps some.
86TruenoFRS (07-27-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
