JonMotoring
Old 07-19-2013, 01:24 PM   #12573
Sivtec
Sivtec's Avatar
Originally Posted by sdemo View Post
I hate my torque dip less than I love my warranty.
True, and you definitely don't have to, but you do have the option to revert back to OEM and vice versa.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
-2013 Scion Raven FR-S
-2009 Honda Green/Black CBR600RR
Old 07-19-2013, 01:35 PM   #12574
nelsmar
There is no issue simply flashing back before going to the dealer. A lot of dealers are semi okay with it. The only time it is a problem is if your engine blows up due to a bad tune. Which NA is going to be more difficult to do vs say a wrx. I haven't had any issues with the dealer I go to. He'll I'm going in for a shifter replacement here soon. They just know to not touch my ecu. And if thy do it is read only and they report back to me.
My flickr - Canibeat
Local magazine scout
Old 07-19-2013, 02:13 PM   #12575
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by SpyderMS View Post
Sorry for my ignorance, but does your car need to be modified to get a tune? If not, is there a decent benefit of getting one without any other modification?
This is technically what a stage 1 tune is, a uniform tune built for a stock vehicle.
Jar is offline   Reply With Quote
The Following 2 Users Say Thank You to Jar For This Useful Post:
ronnBOi720 (07-19-2013), SpyderMS (07-19-2013)
Old 07-19-2013, 03:50 PM   #12576
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
We're talking about maybe 5hp here. At the wheels, maybe 2. We don't drive turbo vehicles on which a tune is actually useful. This is the ONLY N/A platform's forum on which I've seen tunes so highly recommended.
Adding an intake and exhaust are less expensive and more worthwhile. Sure, you wont get "maximum" gains out of them unless you update fuel trim, etc, but 90% of the gains are in the hardware.
I think you guys should be careful with promoting warranty voiding (and not very worthwhile) practices. In my opinion, the ECU is the absolute LAST part of the upgrading equation.
sdemo is offline   Reply With Quote
The Following User Says Thank You to sdemo For This Useful Post:
BugeyedWagon (07-19-2013)
Old 07-19-2013, 04:03 PM   #12577
Yruyur
Yruyur's Avatar
Not sure where you are getting 2-5hp gains from.
Stg 1 tunes on our platform are generally getting around 20 at the wheel. Plus more with ethanol.
Its not about the max hp anyways its more about the overall driveability of the car. But the extra kick in the seat sure is nice.
You are more than welcome to drive my car anytime.
I made sure to ask about warranty work though my dealer when I had it in for service multiple times. They didnt care care.
Sent from a Motorola DynaTAC 8000X
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
nelsmar (07-19-2013), ronnBOi720 (07-19-2013)
Old 07-19-2013, 04:06 PM   #12578
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
Haha yeah? I'm thinking about getting the cable and licence so i can do my own tunes. If i was in pheonix I'd ask you to better help me
Sent from my SCH-I535 using Tapatalk 4 Beta
Old 07-19-2013, 04:18 PM   #12579
sdemo
sdemo's Avatar
I think you're exaggerating a bit with your pump gas estimate and, to be fair, I'm marginalizing. It is not my contention that gains can't be had, it's that there is an inherent risk associated to modifying one's ECU. To me, it is the last thing that should be touched - after all hardware has been upgraded - and, most of all, the driver has become better than their vehicle.
The most gains are to be made in the driver's seat.
Old 07-19-2013, 04:40 PM   #12580
Yruyur
Yruyur's Avatar
Agreed that most gains can come from driver modification.
Ecu tuning can be safe as long as the afr ratios are kept within spec which most tuners are good about. Their base maps are safe while fine tuning is done via log. I just dont want people thinking that tunes are unsafe.
The Following User Says Thank You to Yruyur For This Useful Post:
Old 07-19-2013, 04:43 PM   #12581
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
While I wouldnt suggest a tune without atleast changing the intake/exhaust -- several tests have shown that you can get a decent amount of power (especially in the torque dip portion of the graph) while that wont increase your peak power much, a gain of 10-20tq in the torque dip can make a HUGE improvement in driving feel.
Even my lowly shit intake, the engineer that designed and tested it on my car said it wont realize its full potential without a tune. Since our ECUs are a clever self-learning type, the ECU literally tuned my car back to OEM power levels even after seeing decent gains on the first few dyno runs with the intake added.
Now since I only have an intake I said fuck it for now, but once any exhaust parts go on my car Im definitely getting a tune to take advantage of that. This ECU responds very well to slightly changes in its programming because it was tuned very very conservatively from the factory (likely to accommodate huge variances in gasoline across the nation).
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
The Following User Says Thank You to mattles For This Useful Post:
Old 07-19-2013, 04:43 PM   #12582
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
When it comes time I need me a good tune. Know anyone?
Old 07-19-2013, 04:46 PM   #12583
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
Even my lowly shit intake, the engineering that designed and tested it on my car said it wont realize its full potential without a tune. Now since I only have an intake I said fuck it for now, but once any exhaust parts go on my car Im definitely getting a tune to take advantage of that. This ECU responds very well to slightly changes in its programming because it was tuned very very conservatively from the factory (likely to accomodate huge variances in gasoline across the nation).
Do you know where a good time would be found
Old 07-19-2013, 04:56 PM   #12584
bignrichlll
Because Bacon
bignrichlll's Avatar
Arent there numbers you can call for that? or certain districts in the shady part of town..
Like a BOSS!!
The Following 3 Users Say Thank You to bignrichlll For This Useful Post:
ronnBOi720 (07-19-2013), SpyderMS (07-19-2013), WithNolock (07-19-2013)
Old 07-19-2013, 05:12 PM   #12585
Sivtec
Sivtec's Avatar
Although I agree with Yruyur (I do believe you get more than 5hp), I think the biggest reason to get a "stage 1" tune would to be get rid of our terrible torque curve. This way when you step on it, it doesn't take 3 days to respond. That would be MY biggest reason in getting it. Like I said I won't be getting mine till after I get the rest of my exhaust.
Like, comment and PM the guys from Dynocomp, we are trying to get them to be a local tuner which IMO is way better than an out of state one.
https://www.facebook.com/Dynocomp/posts/686162981398540
The Following User Says Thank You to Sivtec For This Useful Post:
Old 07-19-2013, 05:14 PM   #12586
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
LmFaO oh my that was a good one.
