Old 07-16-2013, 02:17 PM   #239
Hanakuso
Originally Posted by JackSmiley View Post
I installed my R2's yesterday, and noticed on low speeds on uneven pavement or going thru bumps i hear a thud on the fronts, my fronts are max low and still settling. Anyone having this issue?
I haven't noticed any noise from the front, but the rears still make noise.
I noticed the locking rings can easily get loose so make sure you tighten them.
Hanakuso is offline   Reply With Quote
Old 07-16-2013, 03:01 PM   #240
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by ayau View Post
I'll be installing my updated R2 this Thursday when my springs come. Just curious, is this the first time you've had aftermarket coilovers on your car?
Yeah, this would be the first time i've had coilovers for the FRS. I love the ride and how the car is more responsive to steering input, but the noise on low speeds kinda bother me. I've asked a couple of people about it and they said its normal. I'll be changing out my front and rear tophats soon, will redo the install and see if the noise is still present - if they still are, i'll just get used to it or buy a new set and sell they R2's for hella cheap.
I will check on this. I did the install with a friend and myself. I'll have a shop reinstall these and see if the noise is still present.
JackSmiley is offline   Reply With Quote
Old 07-16-2013, 04:28 PM   #241
RYU
RYU's Avatar
Drives: really slow...
I no longer have a dog in this fight but I think that's a common excuse many subscribe to. I've had track oriented coilovers that make noise and other track oriented coilovers that do not. I've also had "street" coilovers make noise and some that don't. I'm of the opinion that it's in the engineering of the components. I've also had pillowball top hats that make noise over time but not out of the box.
In any event, as long as everyone is happy. That's really what matters! Some have different tolerances for what's acceptable and what's not I guess.
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
CSG Mike (07-19-2013)
Old 07-18-2013, 12:34 AM   #242
tdoggy57
tdoggy57's Avatar
Drives: Asphalt Scion FR-S
Mine make a ton of noise I turn the music way up lol i need this update but have no idea when ill ever get to it
tdoggy57 is offline   Reply With Quote
Old 07-19-2013, 01:21 AM   #243
ayau
Drives: Some rust bucket
Just installed my updated R2. Just a few notes/concerns.
-At 1'' drop, the rear springs have no preload at full droop. The springs will just wiggle around. This probably isn't a big issue daily driving, but I'm not sure what will happen at the track if the rear wheel lifts and there's no load on the springs.
-At 1'' drop, the fronts are basically are on the last thread. I can't see this going lower than 1.25''.
-I'm not so sure if the update actually improved the ride quality, lol.
Old 07-19-2013, 01:25 AM   #244
OrbitalEllipses
Drives: Attitude
Full soft rebound, then report back. Wuss.
Old 07-19-2013, 01:26 AM   #245
ayau
Already did. Ride just feels bouncy.
The Following User Says Thank You to ayau For This Useful Post:
Old 07-19-2013, 05:42 AM   #246
JackSmiley
JackSmiley's Avatar
Are you running the off the shelf spring rates? Im on full soft with off the shelf rates and i dont feel the bounciness, very comfy ride IMO.
Old 07-19-2013, 10:25 AM   #247
ayau
Nah, I'm on 500/600 springs.
I think I'm more concerned about the rears having no load when it's at full droop.
Old 07-19-2013, 10:46 AM   #248
Racecomp Engineering
That's what a helper spring is for.
- Andy
ATL BRZ (07-19-2013)
Old 07-19-2013, 10:55 AM   #249
ayau
- Andy
Eibach removed the helpers to reduce noises as part of the update.
Old 07-19-2013, 11:32 AM   #250
That doesn't really make sense to me, but if it works then it works.
- Andy
RYU (07-19-2013), swift996 (07-19-2013)
Old 07-19-2013, 06:17 PM   #251
RYU
RYU's Avatar
- Andy
When I received my reworked set removing the helper did not solve the noise issue. I think it may have helped quiet it down a bit but it was not something very noticeable. I just couldn't take it anymore so I bit the bullet and sold mine salvaging whatever value out of them I could.
I would have preferred to keep the helper so at full droop the spring is still located on the top hat and perch properly but instead the solution was to insert an internal spacer to limit droop travel. Yet at full droop at a conservative 25mm drop the spring was still dancing around in there loose
So yes, it doesn't make sense to me too...
Old 10-20-2013, 03:55 AM   #252
jason t
Drives: '13 Outback 3.6R, '13 BRZ
I have installed the latest version of the R1 and the clunking in the front/rear is very annoying. Also seems the front end is very bouncy and yes I have played around with the rebound and the car is not riding on the bumpstops. The endlinks are secure and nothing else suspension wise has been changed. The rear is a set at a very moderate height maybe 1'' lower and it looks like I have a 1.5'' of travel before I hit the bumpstop-is this OK?
I have only ever run KW V3 or RCE T2 in any of my Subarus with Vorshlag/GTWorx camber plates and never had an issue with noise or driveability.
Hopefully Eibach can figure out the problems.
jason t is offline   Reply With Quote
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 01:32 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
