Old 07-17-2013, 11:09 AM   #211
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by trippinbillies40 View Post
Second what Andrew said. Talked to Sam yesterday about getting a front bar. He was very up front with me about my options while he worked through the issues with the bad batch. EXCELLENT customer service!
I completely agree!
G_Ride is offline   Reply With Quote
Old 07-17-2013, 12:36 PM   #212
simpleisbest
Senior Citizen
Drives: Scion FR-S
Preferably, I would like to run the bar with stock endlinks. Supposedly, shortening the endlinks can stiffen the bar some (by how much, who knows?). Hopefully there will be a corrected version soon. Looking forward to trying Sam's bar, but will be testing another 22mm tubular bar this weekend to get a comparison.
simpleisbest is offline   Reply With Quote
Old 07-17-2013, 02:40 PM   #213
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Um, found some time to drop in, and thank you to Andrew for posting for me.
First, I want to apologize. We've been making bars for cars for years (Corvette, Mustang, Camaro) and have never had these issues. But those bars are bigger, thicker walled and easier to bend without kinking, etc. What really drives me batty is the fact at least 3 from the last run report no issue, and one from the run before which is confusing to say the least.
As for the shorter links making the bar stiffer. Um.... no, the bar is what the bar is. That said as you get very near full lock the shorter links will cause more flex in the bar which does stiffen it vs. less flex. But all bars do this, and it happens to some degree with any link. You can't quantify it, and frankly we don't tend to turn at full lock anyway. Finally, since my bar isn't 25mm, or solid, etc it would actually have less gain than other bars.
Sam Strano is offline   Reply With Quote
Old 07-17-2013, 04:46 PM   #214
Dezoris
Dezoris's Avatar
Did you ever figure out a better option for those aluminum collars?
I switched to hose clamps which is ghetto but works.
Old 07-17-2013, 05:01 PM   #215
Sam Strano
Sam Strano's Avatar
Um, no. Lots of bars use split collars.
Old 07-17-2013, 05:14 PM   #216
Dezoris
Dezoris's Avatar
Sam, I know you work hard etc. But have to just point out the fact that the split collars you are using are grinding into the metal support frame as collar rotates as we discussed and they are much too large to fit any type aftermarket overripe setup.
Most people who have been asking me about the bar, I highly recommend it but am honest about the issues because you never responded.
Old 07-17-2013, 05:16 PM   #217
qoncept
qoncept's Avatar
Can you tell us what it is about these bars that makes them require collars? I've never had collars on any other car.
qoncept is offline   Reply With Quote
Old 07-17-2013, 05:23 PM   #218
Sam Strano
Sam Strano's Avatar
the collars are to locate the bar laterally. Some folks freaked that it might walk, even though it can't go anywhere so we included collars. This is not uncommon, lots of aftermarket bars use split collars. In fact the stock bar has some metal wrapped around it inboard of the bushings to do exactly that.
If the aluminum of the collar is touching the metal that surrounds/holds the bushing in place, knock the corners off of it (it's soft aluminum). Or you can buy various round split collars that might be smaller in diameter.
The Following User Says Thank You to Sam Strano For This Useful Post:
qoncept (07-17-2013)
Old 07-17-2013, 05:29 PM   #219
qoncept
qoncept's Avatar
So... can we skip them? I'm fairly certain I can hear them occasionally and I'd rather just take them off than file them if they aren't necessary.
Old 07-17-2013, 05:30 PM   #220
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
It is more common than you think. For every bar I had on my Miata, I had a set of shaft collars. The front swaybar mounts are known to be weak on those cars, and the shaft collars were one way to help keep them from cracking and breaking. I never had one crack even with 7 years of auto-x on that car.
Also worth noting is that the stock bar on the twins has shaft collars on it. Because the bar is attached to the strut, which rotates when steering, it has a tendency to want to shift back and forth. The collars stop this from happening.
Of course, if they'd only made the bar attach to the control arm instead of the strut, we would not have had this issue.
neurokinetik is offline   Reply With Quote
The Following User Says Thank You to neurokinetik For This Useful Post:
Old 07-17-2013, 05:43 PM   #221
Dezoris
Dezoris's Avatar
The bar walks under load, and turns. As it turns the collar can spin on the metal frame, that's where I have the etching. I can grind it but it will still etch.
I guess the point was, why should I have to grind, or source replacements at all Sam?
Send me something that will work.
Old 07-17-2013, 06:01 PM   #222
Sam Strano
Sam Strano's Avatar
Well, you are the only one complaining about it. I sent you something that works... If you want to tweak it, tweak it.
All bars walk and rotate as they load and the wheels turn. I originally had the bar turn right out of the bushings to hold it, and the complaint was it was too tight. I didn't want the collars at all but I had much more call to widen the bar and run collars.
Old 07-17-2013, 06:29 PM   #223
Dezoris
Dezoris's Avatar
I see, then the problems I have don't exist. And the photo I attached was made up.
I get why you did it, I appreciate your talent and experience. I even think the bar helped transformed the car. I am glad you are offering it.
But, I am not complaining to complain, I am asking you for a solution.
Your answer is this: "Grind them down so I don't have to deal with a one off issue."
And frankly it's not good enough for me. Want to talk more about it, PM or call me.
The Following User Says Thank You to Dezoris For This Useful Post:
simpleisbest (07-18-2013)
Old 07-17-2013, 07:22 PM   #224
simpleisbest
Senior Citizen
Drives: Scion FR-S
Found these online from Misumi (Japan's version of McMaster-Carr):
Part Number: SCSPJ20-8
https://docs.google.com/viewer?url=h...%2Fp1_0233.pdf
They're shaft collars are round and seem low profile. I might give them a try once I get the replacement bar from Sam.
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 09:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 07:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 07:52 PM
