go_a_way1
Old 07-16-2013, 03:15 PM   #827
Robftss
Drives: VW
Originally Posted by Wild Weasel View Post
And hey... he's gotta cover the cost of sending test units out to a hack like me. I'm pretty sure I've cost him a couple hundred in shipping costs now. Batteries ain't light, yo!
I think at the end of the day, the prices are pretty reasonable. And the more people that buy them and install them and post up "Holy crap! Those guys were right! This is fun!", the more people will realize that it's not a lot for what you're getting.
Ya, you were expensive
Although, pulling that stubborn halo off your head was worth it!
Batteries can be ordered and shipped for free in the US, I will provide links, or sourced locally.
Robftss is offline   Reply With Quote
Old 07-16-2013, 04:16 PM   #828
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
as other said, there is R&D cost insidie. don't cheap out that someone invested money and time.
Old 07-16-2013, 04:53 PM   #829
Frs300
Frs300's Avatar
Drives: Pile of junk
@fenton none the less fi numbers asside I still like this idea. I'm big on brushless motors have a few rc boats running twin 11hp brushless motors 5000w each.
Frs300 is offline   Reply With Quote
The Following User Says Thank You to Frs300 For This Useful Post:
fenton (07-16-2013)
Old 07-16-2013, 06:15 PM   #830
fenton
Wow that must be crazy!
Glad lots of people are interested, I'm having a lot of fun with my car now whereas I was yearning for more all the time pre supercharger.
Sent from my HTC One using Tapatalk 2
fenton is offline   Reply With Quote
Old 07-17-2013, 12:45 AM   #831
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
I can't stop driving, 3rd fill up since having this installed
Sent from my SGH-I727R using Tapatalk 2
Bu-Tang is offline   Reply With Quote
Old 07-17-2013, 02:16 AM   #832
BRS
Drives: Black
http://www.scorpionsystem.com/catalo...0/HK_7050_340/ is where its at.
BLACK BRZ SPORTEC
BRS is offline   Reply With Quote
Old 07-17-2013, 09:47 AM   #833
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by BRS View Post
Again stuff like this is better suited for the open source thread.
http://www.ft86club.com/forums/showthread.php?t=41148
Old 07-17-2013, 09:59 AM   #834
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
Yeah... Rob should probably be trying to keep this aspect on the down-low.
I went through a LOT of gas with mine as well. Not because the blower makes the engine less efficient or any such thing... but simply because it's too much fun so you find yourself at WOT a lot more than you otherwise would.
I expect this probably abates after a few weeks once sanity is restored.
Wild Weasel is offline   Reply With Quote
Old 07-17-2013, 10:06 AM   #835
mid_life_crisis
Drives: FR-S 10 #103 AT
I forget, did you set yours up for full wide open or 75% and up?
I'm curious if 75% provides some of that throttle control we are hoping to get over on the open source thread.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-17-2013, 10:25 AM   #836
Wild Weasel
Technically, it would provide a little control but I have my doubts as to how noticeable it would be. The difference in the restriction of the TB between 75% and WOT is probably somewhat negligible compared to the difference in power you're going to get when the FTS kicks in. I think the bigger advantage will be simply in the feel of it. You won't have to feel like you're mashing the pedal to the floor to get the power boost you want.
The Following User Says Thank You to Wild Weasel For This Useful Post:
neutron256 (07-17-2013)
Old 07-17-2013, 10:40 AM   #837
mid_life_crisis
I think what some of us are looking for is a little control at the edge. With the blower running full out, the throttle plate is the restriction, so for that last 25% of throttle opening, it really should behave like a bigger motor. It would be nice if that selection was more adjustable. If you wanted to bump up your electrical to handle it and put slightly larger batteries, you could tweak the switch point a little lower to get a little more throttle range under boost or if you wanted it to take longer to turn on, you could raise it a little. Making that engagement point more adjustable would resolve a lot of issues.
Old 07-17-2013, 10:52 AM   #838
CBR600RR
Drives: Raven Black
I think it would be great if it was activated only at a select RPM. Say 4500rpm.
I do most of my putting arround below this RPM. it would be nice to be able to hit full throttle below this RPM or another selectable RPM and not have the e-charger kick in.
but then once past the selected RPM... BOOM e-charger greatness (it would also feel kinda like v-tec kicking in - i loved how the b-18 engine felt in my old CRX)
Old 07-17-2013, 11:34 AM   #839
DJCarbine
Thupercharged
DJCarbine's Avatar
You could use a simple RPM window switch as used in nitrous applications for this
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-17-2013, 12:22 PM   #840
Dustin2JZ
StatusLow
Dustin2JZ's Avatar
Drives: 2013 10 Series FRS
I wouldn't want that personally. I like idea of having the power there if I wanted to pass someone on the interstate without down shifting.
I just think it would be a good idea to have small switch somewhere to disable it.
Follow my instagram page @86_Nation
Dustin2JZ is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
