#827 | |
Drives: VW
![]() Although, pulling that stubborn halo off your head was worth it! Batteries can be ordered and shipped for free in the US, I will provide links, or sourced locally. |
#829 |
Drives: Pile of junk
@fenton none the less fi numbers asside I still like this idea. I'm big on brushless motors have a few rc boats running twin 11hp brushless motors 5000w each.
| The Following User Says Thank You to Frs300 For This Useful Post: | fenton (07-16-2013) |
#830 | |
Glad lots of people are interested, I'm having a lot of fun with my car now whereas I was yearning for more all the time pre supercharger. Sent from my HTC One using Tapatalk 2 |
#831 | |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Sent from my SGH-I727R using Tapatalk 2 |
#832 |
Drives: Black
http://www.scorpionsystem.com/catalo...0/HK_7050_340/ is where its at.
#833 | |
Drives: '13 GBS Subaru BRZ
http://www.ft86club.com/forums/showthread.php?t=41148
#834 |
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
Yeah... Rob should probably be trying to keep this aspect on the down-low.
![]() I went through a LOT of gas with mine as well. Not because the blower makes the engine less efficient or any such thing... but simply because it's too much fun so you find yourself at WOT a lot more than you otherwise would. I expect this probably abates after a few weeks once sanity is restored.
#835 | |
Drives: FR-S 10 #103 AT
I forget, did you set yours up for full wide open or 75% and up? I'm curious if 75% provides some of that throttle control we are hoping to get over on the open source thread.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#836 |
Technically, it would provide a little control but I have my doubts as to how noticeable it would be. The difference in the restriction of the TB between 75% and WOT is probably somewhat negligible compared to the difference in power you're going to get when the FTS kicks in. I think the bigger advantage will be simply in the feel of it. You won't have to feel like you're mashing the pedal to the floor to get the power boost you want.
| The Following User Says Thank You to Wild Weasel For This Useful Post: | neutron256 (07-17-2013) |
#837 |
I think what some of us are looking for is a little control at the edge. With the blower running full out, the throttle plate is the restriction, so for that last 25% of throttle opening, it really should behave like a bigger motor. It would be nice if that selection was more adjustable. If you wanted to bump up your electrical to handle it and put slightly larger batteries, you could tweak the switch point a little lower to get a little more throttle range under boost or if you wanted it to take longer to turn on, you could raise it a little. Making that engagement point more adjustable would resolve a lot of issues.
#838 |
Drives: Raven Black
I think it would be great if it was activated only at a select RPM. Say 4500rpm.
I do most of my putting arround below this RPM. it would be nice to be able to hit full throttle below this RPM or another selectable RPM and not have the e-charger kick in. but then once past the selected RPM... BOOM e-charger greatness (it would also feel kinda like v-tec kicking in - i loved how the b-18 engine felt in my old CRX) |
#839 | |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#840 | |
StatusLow
Drives: 2013 10 Series FRS
I just think it would be a good idea to have small switch somewhere to disable it.
Follow my instagram page @86_Nation
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
