Old 07-15-2013, 03:33 PM   #57
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Gen View Post
Wastegate has an 8 PSI spring. AEM failsafe reads boost from the manifold.
It can also log boost, AFR, and RPM. That is what I used to produce my boost/afr plots. Have you pulled data off the gauge yet?
Old 07-15-2013, 03:40 PM   #58
Gen
Drives: Scion FR-S
Wasn't actually aware of that. Let me mess around with it when I get home and see.
Gen is offline   Reply With Quote
Old 07-16-2013, 11:38 AM   #59
Gen
Drives: Scion FR-S
Doesn't look like the gauge was logging. When I plugged it in there was no log to pull. I'll need to play around with it to see if I can get it to start.
Old 07-16-2013, 04:43 PM   #60
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It should be logging the last 3 hours of your car running. Then when you open it up in the AEM viewer it will show a seperate segment for each time your car was running. It takes about 5 minutes to download the entire 3 hours of data.
whataboutbob (07-16-2013)
Old 07-18-2013, 06:29 PM   #61
Gen
Drives: Scion FR-S
It's getting checked out now. Exhaust was fine, but they're thinking there may be a defect with the turbo itself causing it to operate too far out of its efficiency range.
Old 07-18-2013, 10:30 PM   #62
Gen
Drives: Scion FR-S
No reason for the power loss found. They suspect there may be some tolerance issues with the turbo, but there's no other symptoms that would support that (increased IATs, etc.)
I brought up the lower mass airflow. My tuner stated that you can't rely on that number when comparing one tune to another due to the way a specific tuner modifies the maps. He advised to use MAF voltage, which was 4.4 at WOT. LJ at fullblown indicates he sees 4.5 at 10 psi.
Smoke test was fine, boost leak test was fine, back pressure test on the exhaust was fine. I've got no idea.
Old 07-18-2013, 10:41 PM   #63
jamesm
That's no fun. I hope you get it worked out soon. It'll be worth it in the end.
The Following User Says Thank You to jamesm For This Useful Post:
Gen (07-18-2013)
Old 07-18-2013, 10:45 PM   #64
Gen
Drives: Scion FR-S
Thanks! Unfortunately, it gets expensive when I'm paying by the hour to take wild guesses.
The Following User Says Thank You to Gen For This Useful Post:
whataboutbob (07-19-2013)
Old 07-18-2013, 11:51 PM   #65
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Just checked my logs from tonight:
1.86 Bar (12.5 psi)
4050 RPM
3.7 Volts
1.77 Bar (11.2 psi)
7867 RPM
4.42 Volts
There are some variances in there. My max voltage was 4.64, but it was an outlier.
Old 07-19-2013, 12:18 AM   #66
Gen
Drives: Scion FR-S
1.86 Bar (12.5 psi)
4050 RPM
3.7 Volts
1.77 Bar (11.2 psi)
7867 RPM
4.42 Volts
Appreciate it... I haven't a clue what could be wrong. Everything seems to be in order aside from the dyno.
Old 07-19-2013, 06:46 AM   #67
xjohnx
Grip>Slip
xjohnx's Avatar
out of curiosity, have you thrown some logs through virtual dyno?
Old 07-19-2013, 10:48 AM   #68
Gen
Drives: Scion FR-S
I haven't... not something I am familiar with
Old 07-19-2013, 12:53 PM   #69
xjohnx
Grip>Slip
xjohnx's Avatar
Take a look here -> http://www.virtualdyno.net/
basically, go make a pull. from 2 or 3k-redline in 3rd or 4th gear, datalog it, toss it in this program (after telling it what kind of car you have, passenger weight, etc) and it will give you a pretty consistent "virtual" dyno. The numbers may not match up to chassis dynos perfectly, but i've found them to be pretty damn close. The results are also pretty repeatable (given the same temperature, road, fuel level, etc).
The numbers won't mean a ton to anyone else as their road conditions (incline, elevation etc) will all vary from user to user, but as long your numbers are repeatable for you it can be a good tool in comparing the car after a change has been applied to help confirm the good old butt dyno.
Old 07-19-2013, 03:07 PM   #70
Gen
Drives: Scion FR-S
Think I did something wrong.... 1121 HP and 964 torque. I figured out my problem; my car is so powerful the dyno just can't accurately read it. I'll tinker around with it
toekneehair (12-14-2013)
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
