Old 07-15-2013, 02:48 AM   #1
BRS
Drives: Black
Tire chirp, four wheel slides
People. The ones who upgraded their tires already.
Are you still getting rubber chirp shifting into second gear?
Secondly,
Does your grip set-up cause induced forces high enough to bend any suspension parts?
Ether from negative acceleration or centripetal.
If so, what bent and must be upgraded?
Neck problems anyone?
BLACK BRZ SPORTEC
BRS is offline   Reply With Quote
Old 07-15-2013, 05:28 AM   #2
jshadeck
jshadeck's Avatar
Yes still chirps into 2nd but not nearly as much.
As for suspension/neck issues... No matter what tires, its still only 150hp.. No issues there
jshadeck is offline   Reply With Quote
Old 07-15-2013, 11:57 PM   #3
troek
troek's Avatar
Drives: 2012 Toyota 86
i think it takes a f1 car to pull enough g's in a turn to hurt your neck...
troek is offline   Reply With Quote
Old 07-16-2013, 08:38 AM   #4
d1ck
Drives: Black 2013 FRS
Secondly,
Yes.
No way. Not even R-Comps will do this.
See Above.
Not unless your neck is made from spaghetti.
d1ck is offline   Reply With Quote
Old 07-16-2013, 09:20 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You're such a d1ck...
Toyobaru expected much more than just wheel modifications when they designed the triplets. This won't do a thing. I think it would have a higher chance of damaging the diff (which is unlikely) than it has of damaging the suspension components or your neck.
boredom.is.me is online now   Reply With Quote
Old 07-16-2013, 10:06 AM   #6
Drftfan
Drives: Argento FR-S
Yes.
See Above.
This is your first performance car?
Drftfan is offline   Reply With Quote
Old 07-16-2013, 11:26 AM   #7
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
only people with neck problems are the people staring as I drive by
dori. is offline   Reply With Quote
Old 07-16-2013, 06:15 PM   #8
BRS
Drives: Black
Slicks it is then. This may be the only upgrade I ever do to the car. For the track of course
People wasting money on upgraded control arms. Surly cannot be only for their adjustability. Hope its not for the half an ounce weight savings.
BLACK BRZ SPORTEC
Old 07-16-2013, 06:25 PM   #9
OrbitalEllipses
Drives: Attitude
I find it much harder to chirp 2nd gear with my Michelin Pilot Super Sports. Can still do it in VSC Sport, but really have to try.
Old 07-16-2013, 06:26 PM   #10
BRS
Drives: Black
Maybe its a clutch thing. Some seem to offer spring dampening while others are just solid. I wonder if those springs could help the initial engagement enough to keep traction in second gear.
Going down a mountain for some would be all about hard braking and pulling your cheeks from the door glass.
BLACK BRZ SPORTEC
Old 07-16-2013, 06:35 PM   #11
wheelhaus
wheelhaus's Avatar
Upgraded suspension is stiffer and has adjustability, stiffer bushings or pillowballs make noticable improvements for cars with much grippier tires... Such as r-comps..
With R-Comps, you might notice that the huge amounts of grip you get (over the stock tires) will expose other elements that then need attention. Huge grip can cause brakes to overheat, since they might no longer have the ability to induce ABS, you always want your brakes to be stronger than your traction). You may find excessive body roll and tire wear from excessive suspension slop (soft bushings mentioned earlier will allow the wheel to "squish" out of alignment under high lateral load).
If you're going with much grippier tires, I would recommend you at least upgrade your brake pads to something capable of handling the track, and flush with high temp fluid at minimum.
Old 07-16-2013, 06:59 PM   #12
BRS
Drives: Black
Cant find the thank button.
BLACK BRZ SPORTEC
Old 07-17-2013, 04:14 AM   #13
Panman
Panman's Avatar
Drives: 86 GTS
Need more posts
Panman is offline   Reply With Quote
Old 07-17-2013, 09:24 AM   #14
DarkSunrise
DarkSunrise's Avatar
If you're getting R-comps, make sure to get high quality wheels (in addition to upgraded brakes). There's a video of a Porsche on R-comps breaking the spokes off his aftermarket wheels on a fast sweeper at the track. Scary to watch.
And yes still get the 1-2 chirp on Sumi HTR ZIII.
2022 BRZ Build
2013 FR-S Build
Random Chirp while moving. NOT idle chirp. Stephens Issues | Warranty | Recalls / TSB 18 08-14-2013 12:02 PM
Tire/Wheel Set PSJohnDoe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-17-2013 03:16 AM
WTB: 1 OEM wheel with or without tire #87 Wheels and Tires 11 01-31-2013 01:21 AM
wheel/tire purchase help sitandspin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-18-2012 12:08 AM
Right rear tire chirp FRiSson Scion FR-S / Toyota 86 GT86 General Forum 5 08-05-2012 01:30 PM
