#43 |
Drives: FRS
time to delete these graphs!! lol post up your new ones
#44 |
NASA SpecE30 Racer
The graphs are what they are. I still don't completely understand the offset in RPM, but I am sure that Gen has seen my latest graphs. I know he will eventually get his issues figured out and make a great number as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#45 | |
Drives: Attitude
EDIT: I see Mike posted. |
#46 |
Drives: Scion FR-S
Let's hope so... everyone that has looked at the car has struggled to find anything that is causing the low power output. Usually it comes down to "California gas is piss water".
#47 |
Grip>Slip
yep, i know it wasn't FI related, but was thinking perhaps OP's car had a similar lean condition at some point resulting in the same cat failure.
#48 |
Drives: Attitude
A lean condition could do that. Could be a materials defect, FOD, or anything else. With aftermarket tuning I'd suspect a lean condition.
#49 |
NASA SpecE30 Racer
The advantage we have is that most (should be all) forced induction guys are running AFR gauges, and if we see a lean condition we back it down immediately.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (07-15-2013) |
#50 |
Drives: 2013 Black FR-S
Even in the ecutek logs? Everything looks fine in there? hmmm must be something mechanically wrong with the kit? It should be making more power even on CA gas.
#51 | |
Drives: Scion FR-S
When I had the car dyno tuned, my tuner also did not see anything that caused concern. The installer of the kit has reviewed my logs and did not see anything that should cause the power loss. Personally, I just stare at the spreadsheet, stroke my chin, and pretend I know what I'm looking at, so I have no idea what the problem is. |
| The Following User Says Thank You to Gen For This Useful Post: | jamesm (07-16-2013) |
#52 | |
Drives: 2013 Asphalt FR-S
Your only hitting .37 bar boost (5.3 psi) are you still on the stock map sensor? (I assume so since it a 1.5bar sensor) long term fuel trim of +11%, what afr are you seeing on your wideband? Just looks like it's not pushing much air.. your only hitting 1.5 g/rev load and 180g/s air flow... if you go by the old 10 crank hp per lb/min .. thats a max of 230 crank hp.
~Namaste~ |
#53 | |
Drives: Scion FR-S
AFR at WOT on my wideband is right around 11.5. I'm not sure why airflow would be low--it's the standard Fullblown install so not sure where the restriction would be, unless you think the issue could be the MAF? Any thoughts? |
#54 |
NASA SpecE30 Racer
What boost level are you actually running and since EcuTek can't log it, what are you using to tell you what level?
- King Tut
#55 |
Drives: Scion FR-S
#56 |
Drives: Attitude
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Sportsguy83 (07-15-2013) |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Compilation of Dyno results somewhere??? | Scooby South | Engine, Exhaust, Transmission | 3 | 01-08-2013 06:51 PM |
| Pocket Dyno App Results | CBR600RR | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 09-12-2012 10:45 PM |
| My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 10:15 PM |
