Old 07-15-2013, 12:34 PM   #43
lexusb3
Drives: FRS
I would not quote my numbers. As time has gone on, I have grown less confident in either of those dyno plots being correct due to RPM pickup issues. The RPM scale is not correct for either pull that was collected. I will have new dyno plots after July 12th.
time to delete these graphs!! lol post up your new ones
lexusb3 is offline   Reply With Quote
Old 07-15-2013, 01:21 PM   #44
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The graphs are what they are. I still don't completely understand the offset in RPM, but I am sure that Gen has seen my latest graphs. I know he will eventually get his issues figured out and make a great number as well.
Old 07-15-2013, 01:24 PM   #45
OrbitalEllipses
Drives: Attitude
Originally Posted by xjohnx View Post
was that @CSG Mike when he had the DI failure?
IIRC the DI problem OR the coil problem in one way or another caused a lean condition that destroyed the cats. Not FI related at all.
EDIT: I see Mike posted.
Old 07-15-2013, 01:39 PM   #46
Gen
Drives: Scion FR-S
Let's hope so... everyone that has looked at the car has struggled to find anything that is causing the low power output. Usually it comes down to "California gas is piss water".
Gen is offline   Reply With Quote
Old 07-15-2013, 01:44 PM   #47
xjohnx
Grip>Slip
xjohnx's Avatar
yep, i know it wasn't FI related, but was thinking perhaps OP's car had a similar lean condition at some point resulting in the same cat failure.
Old 07-15-2013, 01:56 PM   #48
OrbitalEllipses
Drives: Attitude
A lean condition could do that. Could be a materials defect, FOD, or anything else. With aftermarket tuning I'd suspect a lean condition.
Old 07-15-2013, 01:57 PM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The advantage we have is that most (should be all) forced induction guys are running AFR gauges, and if we see a lean condition we back it down immediately.
Sportsguy83 (07-15-2013)
Old 07-15-2013, 02:37 PM   #50
sw20kosh
Drives: 2013 Black FR-S
Even in the ecutek logs? Everything looks fine in there? hmmm must be something mechanically wrong with the kit? It should be making more power even on CA gas.
Old 07-15-2013, 02:55 PM   #51
Gen
Drives: Scion FR-S
LJ from fullblown is reviewing them today,however, on the basemap and revised map that LJ had sent me when I first put the kit on, I made less than 200 horsepower on a dyno dynamics. LJ had reviewed datalogs before then and didn't really make a note of anything terribly disturbing.
When I had the car dyno tuned, my tuner also did not see anything that caused concern. The installer of the kit has reviewed my logs and did not see anything that should cause the power loss. Personally, I just stare at the spreadsheet, stroke my chin, and pretend I know what I'm looking at, so I have no idea what the problem is.
The Following User Says Thank You to Gen For This Useful Post:
jamesm (07-16-2013)
Old 07-15-2013, 03:04 PM   #52
mad_sb
Drives: 2013 Asphalt FR-S
From looking at the logs you posted in whitefrs's thread....
Your only hitting .37 bar boost (5.3 psi) are you still on the stock map sensor? (I assume so since it a 1.5bar sensor)
long term fuel trim of +11%, what afr are you seeing on your wideband?
Just looks like it's not pushing much air.. your only hitting 1.5 g/rev load and 180g/s air flow... if you go by the old 10 crank hp per lb/min .. thats a max of 230 crank hp.
Old 07-15-2013, 03:12 PM   #53
Gen
Drives: Scion FR-S
Stock map sensor. I had purchased an omni 4 bar but I was advised not to use it...
AFR at WOT on my wideband is right around 11.5. I'm not sure why airflow would be low--it's the standard Fullblown install so not sure where the restriction would be, unless you think the issue could be the MAF? Any thoughts?
Old 07-15-2013, 03:16 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What boost level are you actually running and since EcuTek can't log it, what are you using to tell you what level?
Old 07-15-2013, 03:19 PM   #55
Gen
Drives: Scion FR-S
Wastegate has an 8 PSI spring. AEM failsafe reads boost from the manifold.
Old 07-15-2013, 03:21 PM   #56
OrbitalEllipses
Drives: Attitude
Those who aren't [running AFR gauges] deserve blown engines.
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
