Old 07-15-2013, 11:23 AM   #85
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@lbroskee, here are my thoughts on the ACT 6 puck clutch.
Pedal feel is actually LESS hard than mine. It felt light right after driving my car back to back.
The clutch engagement point is harsher than mine (kind of obvious but just to confirm). Even with that, it is not a hard clutch to use. You just need to modulate the RPMs to get it to grab. My clutch is a bit more forgiving. You can slip y clutch more to give you some room as to when to engage. The 6 puck wants to engage as soon as it touches, but again, I was able to drive Chris's car with no issues and the only time it almost died was the first time I let the clutch out but it didn't die. All other instances were smooth.
It's not a bad option at all. It was surprisingly easy to drive after reading a lot of people here complaint that it is so hard to drive.
I think you pretty much nailed it. The pedal pressure is less with the ACT pressure plate when compared to the Clutchmasters. The engagement point is much smaller with a 6 puck clutch than a full face regardless of manufacturer.
Sportsguy83 (07-15-2013)
Old 07-15-2013, 11:28 AM   #86
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I hate all the noise my act makes
Old 07-15-2013, 11:33 AM   #87
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There are other options. My recommendation is go back to the OEM flywheel and get an upgraded clutch that works with the OEM flywheel.
Old 07-15-2013, 11:35 AM   #88
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
What u have now?
Old 07-15-2013, 11:38 AM   #89
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What u have now?
I still have my AEM 6 puck with their lightest flywheel. I have the same noises everyone else has, but I have accepted them as having to pay to play. I like knowing I will never have to worry about the clutch slipping, and that I am getting better acceleration with the lighter flywheel.
Old 07-15-2013, 12:06 PM   #90
jamesm
i just pulled the trigger on an ACT with the full face disk and streetlite flywheel. getting installed at rev works friday. i'll post a review once it's broken in.
Old 07-15-2013, 12:51 PM   #91
lexusb3
Drives: FRS
i riped my clutch as soon as i put it in stalled out once and then str8 drifting ahhah thats just me tho but you should like the ACT its nice! not crazy rough!
lexusb3 is offline   Reply With Quote
Old 07-15-2013, 06:36 PM   #92
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
@King Tut @Sportsguy83, so basically to sum it up....
-Clutchmasters is heavier but more play room so less chance for mistake if not paying attention
-ACT is lighter but more precision is required
good to know. guess ill pay a lil more for more forgiveness when im exhausted from long days. plus still lighter then a GT500 or a Carrera(learned on this 1) and those r both easy. just wonder if it's as useful with a fast engagement wen racing for example
lbroskee is offline   Reply With Quote
Old 07-15-2013, 07:59 PM   #93
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, its as useful racing. Harder pressure plate is what will get your grip. The full face is what helps with the engagement .
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (07-15-2013)
Old 07-16-2013, 04:53 PM   #94
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not exactly. Let me outline the options:
ACT has a lighter pedal feel
Clutchmasters has a heavier pedal feel
ACT offers two lightweight flywheel options
Clutchmasters offers one lightweight flywheel option
ACT offers a 6 puck or a full face clutch disk
Clutchmasters offers a 6 puck or a full face clutch disk
ACT clutch/flywheel costs around $600
Clutchmasters clutch/flywheel costs over $800 I believe
The Following 3 Users Say Thank You to King Tut For This Useful Post:
gonzo (07-16-2013), Sportsguy83 (07-16-2013), whitefrs (07-16-2013)
Old 07-16-2013, 05:04 PM   #95
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Isnt CM like 1000 bucks
Old 07-19-2013, 10:03 PM   #96
jamesm
I had the ACT full face/street flywheel installed today. i've only driven it a bit, but i like it so far. it feels a lot more precise than the stock clutch, less mushy. the pedal is a little bit stiffer than stock, but not much. the downside is major noise.
Old 07-20-2013, 07:38 AM   #97
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Has anyone tried a Spec Clutch in one of the twins yet?
kmbkk is offline   Reply With Quote
Old 07-20-2013, 09:36 AM   #98
jamesm
I've read terrible things (with pics to prove lol) about spec clutches. I'd stick with act or cm.
The Following User Says Thank You to jamesm For This Useful Post:
civicdrivr (07-20-2013)
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
