#2535 | |
Drives: 1996 ST204, Series 10 FR-S
I don't think it would make sense from a production standpoint to assemble the car outside of the Gumma plant. Especially taking the time to train the production line. Seems like they just installed LEDs at the Aichi plant
#2536 |
Toyota hoarder
Drives: 10 Series FR-S, 05 xB, MR-S GT-300
Does your dash panel light up with the blue Scion logo when you open the doors? If not, my only other guess would be that the switch for that (under the steering wheel) is flipped off, and maybe the badges are disabled by that switch as well (since they all operate together).
| The Following User Says Thank You to SpyderDan For This Useful Post: | #944_10_Series_FRS (07-13-2013) |
#2537 | |
Drives: 2013 10 series FRS #944
I found the problem and it concurs with the other posts that 2 remotes have interfered signal with other. The emblem did not light up when it is in my garage because 1 key is in my pocket and 1 key is in my house. It light up earlier when I went to Starbucks. ![]() |
#2538 |
I just came to a breakthrough in how to get the DRL LEDs to stay on with the HID headlights. I just need access to the Toyota EPC to get find the pigtails for the JDM lights. I will make a small harness that is reversible if the car needs to go into servicing.
I will do mock this up once I get my car (before august) and test it out depending on how much the oem connectors cost. |
| The Following 4 Users Say Thank You to projek_01 For This Useful Post: |
#2539 | |
#2540 | |
#2541 | |
1. just have to check that we dont exceed the current levels of the signal light fuse 2. isolate the circuit so we dont have voltage feedback going back into the DRL system when the HIDs are on. (may not be an issue but better safe than sorry) 3. make it fully reversible when going in for servicing My solution is to get both the JDM male and female connectors and make necessary electrical modifications between the two for the headlight. The USDM plugs are different. and low voltage shouldnt be needed. the LEDs operate with a full 12v |
| The Following 3 Users Say Thank You to projek_01 For This Useful Post: |
#2542 | |
Canadian FR-S Member
Drives: FR-S '10 Series'
#2543 | |
Drives: 2013 Scion FR-S 10 Series
#2544 | |
| The Following User Says Thank You to sc10nFRS For This Useful Post: | #944_10_Series_FRS (07-14-2013) |
#2545 | |
10 Series Fanatic
Drives: Scion FR-S 10
https://www.sugarsync.com/pf/D6122518_75457608_987514 |
| The Following 4 Users Say Thank You to Obsidiank For This Useful Post: |
#2546 | |
#2547 |
10 Series Fanatic
the online manual doesn't come as one pdf but rather 31 small ones. I merge them all together. maybe I missed one.
go to scion.com and sign up for owners lounge. It's free. |
| The Following 2 Users Say Thank You to Obsidiank For This Useful Post: | FiRStsc10n (07-14-2013), SpyderDan (07-14-2013) |
#2548 |
Drives: 10 Series FR-S #207
Had no idea these cars came with auto lights, now I'm really excited for mine to arrive!!!
| Tags |
| 2014, brz, fr-s, gt86 |
| Limited edition WedSports | GH05T | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-17-2013 02:03 AM |
| Limited Edition FT86 Oil Cap #127 | phenom86 | Engine, Exhaust, Bolt-Ons | 2 | 12-12-2012 04:30 PM |
| Toyota TRD GT86 Special Edition Announced for UK | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 07-18-2012 11:23 AM |
| Limited Edition Colors? | bambbrose | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-30-2011 03:23 PM |
