Old 07-13-2013, 07:46 PM   #2535
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
I don't think it would make sense from a production standpoint to assemble the car outside of the Gumma plant. Especially taking the time to train the production line. Seems like they just installed LEDs at the Aichi plant
Originally Posted by FiRStsc10n View Post
Do you guys/gals think the 10 Series might of not been produced at the Subaru plant in Gunma. From the stickers we have seen it labels Final Assembly point Aichi, Japan. From what I've been able to gather from the interweb, the he Scion iQ, xD, and xB (not sure since 2006-present might of moved elsewhere) were all built in Aichi.
Maybe it was just the final location for badge install & electroluminescent dash considering the unique 10 series dash color/fiber are on all of the 10 series models.
projek_01 is offline   Reply With Quote
Old 07-13-2013, 09:13 PM   #2536
SpyderDan
Toyota hoarder
SpyderDan's Avatar
Drives: 10 Series FR-S, 05 xB, MR-S GT-300
Originally Posted by #944_10_Series_FRS View Post
Yes, I am able to unlock the door just to touch the handle.
Does your dash panel light up with the blue Scion logo when you open the doors? If not, my only other guess would be that the switch for that (under the steering wheel) is flipped off, and maybe the badges are disabled by that switch as well (since they all operate together).
SpyderDan is offline   Reply With Quote
The Following User Says Thank You to SpyderDan For This Useful Post:
#944_10_Series_FRS (07-13-2013)
Old 07-13-2013, 10:11 PM   #2537
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
That switch was disable previously and I believe you were the one who gave me the instruction to turn it on. So, it is on and the light on the panel is on.
I found the problem and it concurs with the other posts that 2 remotes have interfered signal with other. The emblem did not light up when it is in my garage because 1 key is in my pocket and 1 key is in my house. It light up earlier when I went to Starbucks.
#944_10_Series_FRS is offline   Reply With Quote
Old 07-14-2013, 01:24 AM   #2538
projek_01
projek_01's Avatar
I just came to a breakthrough in how to get the DRL LEDs to stay on with the HID headlights. I just need access to the Toyota EPC to get find the pigtails for the JDM lights. I will make a small harness that is reversible if the car needs to go into servicing.
I will do mock this up once I get my car (before august) and test it out depending on how much the oem connectors cost.
The Following 4 Users Say Thank You to projek_01 For This Useful Post:
FiRStsc10n (07-14-2013), jpky16 (07-15-2013), mush (07-14-2013), [[|==86==|]] (07-16-2013)
Old 07-14-2013, 01:49 AM   #2539
mush
mush's Avatar
Im interested!
Old 07-14-2013, 02:04 AM   #2540
Luis_GT
I was just thinking of getting the low voltage lead that powers the turn signal lights when the lights are powered on... it should be the missing 7th cable that goes to the headlight harness
Old 07-14-2013, 02:48 AM   #2541
projek_01
projek_01's Avatar
spot on.
1. just have to check that we dont exceed the current levels of the signal light fuse
2. isolate the circuit so we dont have voltage feedback going back into the DRL system when the HIDs are on. (may not be an issue but better safe than sorry)
3. make it fully reversible when going in for servicing
My solution is to get both the JDM male and female connectors and make necessary electrical modifications between the two for the headlight. The USDM plugs are different.
and low voltage shouldnt be needed. the LEDs operate with a full 12v
The Following 3 Users Say Thank You to projek_01 For This Useful Post:
Luis_GT (07-14-2013), mountainside (07-14-2013), sc10nFRS (07-14-2013)
Old 07-14-2013, 10:22 AM   #2542
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
spot on.
I like where this seems to be going. Keep us updated I remember seeing a post where Moto-P described USDM would be missing a 7th connection compared to JDM but he hadn't figured out why yet.
FiRStsc10n is offline   Reply With Quote
Old 07-14-2013, 02:05 PM   #2543
sc10nFRS
sc10nFRS's Avatar
Drives: 2013 Scion FR-S 10 Series
spot on.
PLEASE make a step by step guide when you het this figured out! I was kind of disappointed when I discovered that the DRLs really were daytime only.
sc10nFRS is offline   Reply With Quote
Old 07-14-2013, 02:08 PM   #2544
sc10nFRS
sc10nFRS's Avatar
Nice! Glad you were able to figure it out w/o having to take it in.
The Following User Says Thank You to sc10nFRS For This Useful Post:
#944_10_Series_FRS (07-14-2013)
Old 07-14-2013, 03:12 PM   #2545
Obsidiank
10 Series Fanatic
Drives: Scion FR-S 10
Did you get a different manual than I did? I got what seems to be the standard FR-S manual, which doesn't cover the 10 Series stuff. The extra papers covering the badges and light-up dash panel are essentially just wiring diagrams.
I never looked at the manual in the glove. I just signed up for scion owners site and downloaded from the website. attached for reference.
https://www.sugarsync.com/pf/D6122518_75457608_987514
Obsidiank is offline   Reply With Quote
The Following 4 Users Say Thank You to Obsidiank For This Useful Post:
FiRStsc10n (07-14-2013), mountainside (07-15-2013), NepeanFR-S (07-20-2013), SpyderDan (07-14-2013)
Old 07-14-2013, 05:29 PM   #2546
FiRStsc10n
FiRStsc10n's Avatar
There seems to be a portion missing from this. It ends at page 393. There is a headlight customization page 401 it says on pages 191/192 DRL Section. I wonder what settings can be customized. Anyone with the real manual have page 401?
Old 07-14-2013, 05:33 PM   #2547
Obsidiank
10 Series Fanatic
the online manual doesn't come as one pdf but rather 31 small ones. I merge them all together. maybe I missed one.
go to scion.com and sign up for owners lounge. It's free.
The Following 2 Users Say Thank You to Obsidiank For This Useful Post:
FiRStsc10n (07-14-2013), SpyderDan (07-14-2013)
Old 07-14-2013, 07:15 PM   #2548
tCsonfrs
Drives: 10 Series FR-S #207
Had no idea these cars came with auto lights, now I'm really excited for mine to arrive!!!
tCsonfrs is offline   Reply With Quote
2014, brz, fr-s, gt86
Limited edition WedSports GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-17-2013 02:03 AM
Limited Edition FT86 Oil Cap #127 phenom86 Engine, Exhaust, Bolt-Ons 2 12-12-2012 04:30 PM
Toyota TRD GT86 Special Edition Announced for UK Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 56 07-18-2012 11:23 AM
Limited Edition Colors? bambbrose Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 03:23 PM
