Old 07-14-2013, 02:04 AM   #43
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Thank you David for your review! This is the kind of stuff I was hoping for. I've been on the fence for a while with the AVO kit. Now that I can get a UEL header for the FA20 kit, and them being close, my decision has been even more difficult.
rupert is offline   Reply With Quote
The Following 2 Users Say Thank You to rupert For This Useful Post:
lbroskee (07-14-2013), Sportsguy83 (07-14-2013)
Old 07-14-2013, 02:06 AM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by gdrider77 View Post
Not trying to start anything here, but for sake of argument and to clarify. I did the install in my own garage, with jack stands. When i had it tuned, the shop noticed the issue and they were the original ones to point it out to me on the lift. They air hammered it slightly, and even went as far as to remove it completely and reinstall. So technically it was installed on both jack stands and on a lift. And problem is there from both times.
Once again, not trying to start anything, just stating that it was there both in garage and shop under different circumstances. In the shop they tried a different (perrin) pipe that they had to rule out the pipe i had, and same issue. So that led us to believe it was more in the angle of the turbo discharge pipe causing the problem.
Just trying to get information out for others to be informed, not to bash anything or anyone.
I was in the same boat. Just trying to be honest, put information out there and save other people headaches. Heck, I LOVE my turbo kit and once the that issue was resolved, I don't even think about it anymore. I know we are not the only ones, but no one writes about it....
Old 07-14-2013, 02:25 AM   #45
AVOturboworld
Hey,
I appreciate the feedback, the good and the bad. It's difficult to say exactly what's going on with the discharge pipes - we assemble the exhaust manifold/turbo/discharge in a jig, and theoretically, they should all be the same. Out of 60 odd kits out there, I've heard of a few fitment issues with the discharge pipe - notably, yes, sportsguy and gdrider. I've also seen about 10 installs where it went off without a hitch. So at this time, I'm unsure if it's at the factory side, if it's installer error, or just part and parcel of exhaust installs.
The problem with the FR-S/BRZ exhaust is that it has quite a few pieces in it - exhaust manifold, crossover, front pipe, mid-pipe, mufflers - and when they are all flanged it can be quite a chore to get them all lined up properly. A little bit off at one end can mean quite a bit off at the other end. When we throw in a turbo system and a larger crossover pipe that has to go through a relatively small hole, minor issues can get magnified quite quick.
Doesn't mean we'll ignore all this, I'll talk to engineering and see if there is any better way we can ease this issue. Because we do give it the ability to bolt up to a stock exhaust system, though, we are somewhat limited in what we can do.
Regards,
Paul Hansen
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
armythug (07-14-2013), levifig (07-15-2013), lexusb3 (07-14-2013), Sportsguy83 (07-14-2013)
Old 07-14-2013, 02:35 AM   #46
Sportsguy83
Drives: Limited BRZ
Originally Posted by AVOturboworld View Post
Hey,
Regards,
Paul Hansen
Didn't expect less from you Paul. Courteous, calm, collected. Didn't intend AT ALL to bash, just inform and share my experience. Thanks for everything!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 07-14-2013, 04:24 AM   #47
Calum
That Guy
Drives: 2013 asphalt FRS MT
Well, I missed the drama. Can't say I'm disappointed in that, though.
Great thread Sportsguy83. Thanks so much for sharing and being frank.
It's just a shame your torque curve didn't turn out flatter. :P
The Following User Says Thank You to Calum For This Useful Post:
Old 07-14-2013, 09:55 AM   #48
jamesm
So what I'm reading here is that FA20Club is the tuner to go to. Looks like his base map was considerably better performing and safer than a visconti tune with 16 revisions. Could the knock issues with the Visconti tune have something to do with his completely disabling the direct injection? Is this why fa20club seems to be more successful with the tunes?
I don't need a tune, my car runs fine. Ill be making the trip to see tony regardless, just to see what he can do with a rev works kit. Excellent work, and thanks for the detailed review.
Old 07-14-2013, 10:00 AM   #49
Sportsguy83
Drives: Limited BRZ
Thanks!! I am almost certain the reports that Visconti does not use the DI are inaccurate. That just just some testing being done trying to pinpoint an issue with a car, so he alternated between using 100% DI and 100% Port.
There are little not talked about details in each of their tunes that make a difference. (All tuners keep those little details to themselves and are things that not normally show on a log).
I honestly have no idea why there was so much knock correction, it was crazy. The worst part was seeing new tunes with the same results......
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
jamesm (07-14-2013), lexusb3 (07-14-2013), pmccut (08-01-2013)
Old 07-14-2013, 12:34 PM   #50
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
@Sportsguy83, Great thread and thanks for sharing your experience!!
I'm still waiting for my AVO kit
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Old 07-14-2013, 12:39 PM   #51
Sportsguy83
Drives: Limited BRZ
Mine was about a two and a half month delay. Hang in there, it will be worth it!
Draco_PR23 (07-14-2013)
Old 07-14-2013, 02:28 PM   #52
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Mounts if going 250+ WTQ
O RLY?
Old 07-14-2013, 02:32 PM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by lexusb3 View Post
It was good seeing you again and meeting @kingtut and hope we can all get together with all the frs family minus that dam dog at the dyno :/
I liked the dog, but he definitely liked you, or at least your leg more.
Old 07-14-2013, 02:38 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I just wanted to post and say that the facts are that any of the turbo kits out there can hit these numbers. AVO's kit is using an unequal length manifold and the smallest turbo of any of the kits and still made the numbers. It really all comes down to which turbo kit you prefer. Maybe price point is most important, maybe Boxer rumble is most important, and maybe professionalism is most important.
The thing to really be taken away from this is that getting a proper tune is where the power will be made and the drivability and reliability will come from.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Old 07-14-2013, 02:45 PM   #55
lexusb3
Drives: FRS
Dam dog lol
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
Old 07-14-2013, 02:54 PM   #56
Sportsguy83
Drives: Limited BRZ
O RLY?
Yeah, was tired trying to come up with numbers. You can give a more educated opinion on the matter
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 12:12 PM
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience King Tut Forced Induction 196 09-04-2016 10:47 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 06:30 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 02:49 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
