Old 07-14-2013, 12:11 AM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Drift-Office View Post
I didn't say it was your fault now did I? I merely said it might be something in the way the afflicted part might have been installed.
[/B]
Yes Bob, it was my fault for installing it on jack stands in my garage and the only two people with the issue are me and @gdrider77 because we are lazy asses and installed ourselves, didn't use a lift or pay a "professional" to install it....
Ok there you have it. Happy???? Yes? Good! now go sleep well.
P.S.
(Nevermind that I TOOK IT TO A SHOP after I couldn't get it fixed at home and that shop ON A LIFT had to HAMMER my Overpipe because it would just NOT clear the frame...)
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (07-14-2013)
Old 07-14-2013, 12:18 AM   #30
FA20Club.com
Drives: 2013 White Out FR-S
Great job Tony BTW.
Same to you Bob...Just because i have my own products doesnt means i dont tune the competition to run great as well. I dont play favorites when it comes to the tuning. On monday should have our FBM tunes posted as well from this week.
FA20Club.com is offline   Reply With Quote
The Following 4 Users Say Thank You to FA20Club.com For This Useful Post:
Drift-Office (07-14-2013), lbroskee (07-14-2013), lexusb3 (07-14-2013), mxsled (07-14-2013)
Old 07-14-2013, 12:22 AM   #31
lexusb3
Drives: FRS
you changing the game man!! Shit I might get another frs and do it all over again !! Great experience
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
Sportsguy83 (07-14-2013)
Old 07-14-2013, 12:24 AM   #32
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
There's been talk about doing one of your kits here. Like I tell all my customers and like you, we're equal-opportunity installers. Doing a Vortech setup now, and looks like someone else came thru with an Innovate kit too!
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 07-14-2013, 12:28 AM   #33
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
So by the powers invested in you, will you now go delete the unwanted threads?
posts*
lbroskee is offline   Reply With Quote
Old 07-14-2013, 12:29 AM   #34
Sportsguy83
Drives: Limited BRZ
You learn something new everyday Bob, so here is your lesson of the day!
I am the SE Region moderator (as my title states right below my name ).
That means that I am not able to modify, delete, move, create etc.. ANYTHING outside of the SE region. So no, I can't touch these threads (posts).
Old 07-14-2013, 12:30 AM   #35
lbroskee
lbroskee's Avatar
but u can both delete ur own posts....
Old 07-14-2013, 12:31 AM   #36
Sportsguy83
Drives: Limited BRZ
Its ok, won't be the first or last thread to go to shit here lately. It's all good.
There is valuable info in the first 4 posts. That's good enough for me :happy0180:
Old 07-14-2013, 12:39 AM   #37
lexusb3
Drives: FRS
I love how In the beginning alot ppl were at the 8psi range and 10psi was like OMG alot of boost and now everyone is at 12psi and pushing it higher and higher lol slowly but surely I thought is never get past 10 without doing crazy work just saying
Old 07-14-2013, 12:50 AM   #38
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Hmmm. That alone could be the issue you guys are seeing ~ a lowered set of mounts might make the difference in the overpipe contacting the cross member... All our setups only used the stock mounts.
I am having the issue right now with my stock mounts. have not upgraded those yet.
The over pipe i have is a FA20club pipe. I have also tried a Perrin pipe i had access to and same alignment issue.
gdrider77 is offline   Reply With Quote
The Following 2 Users Say Thank You to gdrider77 For This Useful Post:
Drift-Office (07-14-2013), Sportsguy83 (07-14-2013)
Old 07-14-2013, 12:57 AM   #39
Carwhisperer
Drives: A lot of supercars.
My local friend did as well.
Carwhisperer is offline   Reply With Quote
The Following User Says Thank You to Carwhisperer For This Useful Post:
Old 07-14-2013, 01:00 AM   #40
gdrider77
gdrider77's Avatar
P.S.
Dont take the MEME personal, just found it funny.
Not trying to start anything here, but for sake of argument and to clarify. I did the install in my own garage, with jack stands. When i had it tuned, the shop noticed the issue and they were the original ones to point it out to me on the lift. They air hammered it slightly, and even went as far as to remove it completely and reinstall. So technically it was installed on both jack stands and on a lift. And problem is there from both times.
Once again, not trying to start anything, just stating that it was there both in garage and shop under different circumstances. In the shop they tried a different (perrin) pipe that they had to rule out the pipe i had, and same issue. So that led us to believe it was more in the angle of the turbo discharge pipe causing the problem.
Just trying to get information out for others to be informed, not to bash anything or anyone.
Old 07-14-2013, 01:01 AM   #41
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
@AVOturboworld
Could you elaborate your connection with Drift Office? As a customer considering your product, what Drift Office was doing in this thread was quite unprofessional as a vendor that I associate with the kits you sell (due to initial US testing). What is even worse is that he was not secure enough to keep his posts here. He deleted them so people could not see how he acted.
rupert is offline   Reply With Quote
Old 07-14-2013, 01:04 AM   #42
Drift-Office
Originally Posted by rupert View Post
@AVOturboworld
We're separate entities. Funny there's no mention of the OP and his behavior but I suppose that's to be expected...
Urm. It was suggested that I delete the posts...
Cheers,
Last edited by Drift-Office; 07-14-2013 at 01:09 AM. Reason: Putting the quote in...
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience King Tut Forced Induction 196 09-04-2016 09:47 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
