Old 07-08-2013, 07:05 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
DME Lower Control Arms and DME Toe Arms - Review
Wanted to share this with you guys as another good option for rear end camber and toe correction.
NRG Innovations produces a line called DME and in that they have lower control arms and toe arms for the Scion FR-S, Subaru BRZ, and Toyota GT-86. These are an affordable solution that adds the camber and toe adjustment we need on our cars. An added bonus is they look good as well.
The LCA's have a solid bushing ( no pillow ball like Cusco ) so for some AutoX classes that is important. The Toe arms are pretty simple and offer more adjustment than a sane person should need. Same goes for the camber you can get enough camber to look like the DeLorean from Back to the Future if you choose to.
Anyway picture time!
Lower Control Arms
Toe Arms
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
RehabJeff86 (07-09-2013), Scooby South (07-12-2013)
Old 07-08-2013, 07:35 PM   #2
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Those control arms look pretty sweet. I especially like the two posts going across the top of the boxed arm for added rigidity.
omegared19 is offline
Old 07-09-2013, 12:35 AM   #3
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Are the rear arms the same spec as stock as far as height? Or do they lower the car a bit?
Do like these and they would look good on a Hot Lava.
Overland'n'5thGEN is offline
Old 07-09-2013, 12:47 AM   #4
E46toFT86
Drives: IB '05 E46 M3 ZCP
What's the pricing on these bad boys?
'05 Interlagos Blue
E46toFT86 is offline
Old 07-09-2013, 01:11 AM   #5
JDMSushi
JDMSushi's Avatar
Drives: JDM86
+1
JDMSushi is offline
Old 07-09-2013, 01:54 AM   #6
Overland'n'5thGEN
Originally Posted by JDMSushi View Post
+1
It's on their site.
Old 07-09-2013, 02:01 AM   #7
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Just curious on this comment, bushing vs pillowball, guess I don't understand the difference on how it works or changes things on the car? LCAs are last thing I haven't got yet...well that and coils...
OICU812 is offline
Old 07-09-2013, 06:38 AM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I like the color!
continuecrushing is offline
Old 07-09-2013, 11:03 PM   #9
empower-auto
Kouki-Monster
empower-auto's Avatar
steel control arms? looks great, except for being hell to adjust, like cusco's
Rich Anderson
EMPOWER AUTO
empower-auto is offline
Old 07-10-2013, 12:44 AM   #10
FT-86 SpeedFactory
Cuscos are super easy.... These will be as well.
Old 07-10-2013, 04:59 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Cuscos are super easy? If by easy you mean, having to drop the control arm from the subframe to adjust it.
King Tut is offline
Old 07-10-2013, 05:53 PM   #12
FT-86 SpeedFactory
If you set the adjustment out before you install it and then just use the one section to adjust it isn't bad at all. Easy to get a wrench in there.
If you leave it how they come out of the box, then yeah they are a pain.
Old 07-10-2013, 06:18 PM   #13
wheelhaus
wheelhaus's Avatar
Bushings are typically a very firm rubber or polyurethane and flex/squish when the joint bends. Soft rubber is used when NVH (noise, vibration, harshness) are not wanted, such as on a typical sedan or luxury car. This also reduces feedback, can make the car feel vague when driven hard because the suspension geometry distorts under high load, causing the wheel's alignment to give. A firm enough durometer can make a bushing feel much more responsive by maintaining suspension geometry under such loads. This mostly becomes an issue with high grip tires and other suspension upgrades.
Pillowball joints (a.k.a. heim joints) use a metal ball in a metal socket with a liner made of teflon or other material to act as a lubricant. This style of joint has zero flex and will not distort under load, so it's ideal for competition use, and provides the highest degree of feedback to the driver on exactly what the car is doing. However, it has the highest chance of transmitting NVH. Because it's a moving ball and socket, it has a higher potential for physical wear and deterioration. Typically these are reserved for track only cars, race cars, or other competition vehicles because of the NVH and exposure to the elements isn't ideal for a daily driver.
For autoX or other competition event that classifies cars into specific categories or classes, such an upgrade (to pillowball joints) could be considered an advantage and may be disallowed for certain classes.
Persionally I'd stick with firm bushings for ease of maintenance unless there's a pillowball system that's virtually indestructible and immune to any/all wear.
wheelhaus is offline
The Following 4 Users Say Thank You to wheelhaus For This Useful Post:
Brzzee (07-11-2013), OICU812 (07-10-2013), travelmonkey (07-10-2013), wparsons (02-24-2015)
Old 07-11-2013, 11:19 PM   #14
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
So do the pillow balls used by Cusco meet with your criterion?
Brzzee is offline
SPC Lower Control Arms(Old and New) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-10-2017 10:58 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 04:20 PM
WTB - Adjustable Rear Lower Control Arms swift996 Want-To-Buy Requests 0 06-12-2013 01:23 PM
FS: SPC Adjustable Lower Control Arms kenward Brakes, Suspension, Chassis 2 04-29-2013 09:58 AM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 06:28 PM
