#57 | |
Drives: 2013 Subaru BR-Z Limited
#58 |
I have never dyno'd the car before this.
FA20 Upgraded my injectors & fuel pump added e-85 system & a catted header Current Mods before i got to FA20CLUB: Vortex Supercharger kit with Perrin Tuning Perrin Engine Mounts Perrin Crank Pulley Perrin Oil Cooler Perrin Master Cylinder Brace Perrin Rear Shifter Bushings Perrin Shorty Antenna 2” Perrin Catback exhaust with resonator Perrin Overpipe Perrin Front pipe with catalytic converter Perrin Transmisson Support Drive Shaft Shop Aluminum DS Whiteline Gearbox Positive Shift GrimmSpeed Hood Assist Struts Brakes-Hawk HPS pads Stoptech SS brake lines ATE blue brake fluid Springs-Eibach Pro Kit Clear Side Markers Dunlop Direzza Z2 Gram Lights 57 DR 17x9 +38 Rays Center Caps JDM Arm Rest Weather Tech Floor Liner Flossy Shift Knob Kicker Hideaway 5 Axis trunk spoiler Front Lip Side Skirt Rear Lip Rear JDM Fog Light LED conversion Diode Dynamics Interior LED Diode Dynamics Trunk LED Diode Dynamics License Plate LED Diode Dynamics Reverse Lights LED OBD2 Scanner Arkon Tablet Mount Nexus 7 Running Torque so you have two cats now??
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
| The Following User Says Thank You to charged86 For This Useful Post: | chadstyle (07-11-2013) |
#59 |
Drives: 2013 Black FR-S
No problem with 2 high flow cats. It gets rid of a lot of noise and rasp. I don't see it robbing anymore than 5 Hp. I guess for some that is hugely disastrous though. I will probably run two cats too.
I wonder if this is going to be the crutch all superchargers lean on to try to compete with turbo kits... /ducks for cover |
| The Following User Says Thank You to sw20kosh For This Useful Post: | charged86 (07-11-2013) |
#60 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
#61 | |
Yes this is the same dyno. I have the EL
#62 |
can we please have pics of supercharger kit with the header installed you can send em to my phone and ill post em if you do not wish to
#64 |
i'm headed out to a meet. will take pics at the meet then post for the board. maybe some video if i can get someone to ride along with me
#65 |
Drives: 22 BRZ
@FA20Club.com
Should I get fuel pump & injectors to achieve a similar 93 octane result? Have you tuned any other vortech cars with a flex fuel kit yet? E-85 is plentiful in Houston. ![]() Congrats on your tuning results!
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#66 |
#67 |
Drives: Asphalt Scion FR-S
Location: In deep meditation powersliding around a street corner
Hell yes!
I can't believe the header freed up that much power with the Vortech! I think this has almost sealed the deal on which header I'm going to buy lol. Now Innovate ![]() This is the first dyno I've seen close to 300whp on pump with a supercharger, which is my high-end goal for my car. Very good news. |
#68 |
Drives: FRS
#69 |
Drives: 2013 White Out FR-S
yes you will need pump and injectors this power exceeds stock supply
#70 | |
| The Following 3 Users Say Thank You to FA20Club.com For This Useful Post: |
| Tags |
| fa20club header, vortech |
| FA20CLUB Turbo Kit Results Are In...60 Trim Impressive | FA20Club.com | Forced Induction | 177 | 07-26-2013 04:49 PM |
| FA20CLUB 60 Trim Turbo 16 PSI Results Are In | FA20Club.com | Forced Induction | 148 | 07-22-2013 08:00 PM |
| FA20CLUB 4-1 HEADER VORTECH TEST RESULTS +40HP +30TQ | FA20Club.com | Engine, Exhaust, Transmission | 12 | 07-11-2013 04:52 PM |
| P&L Header Dyno and Fitment test-With my Vortech Test Kit | Huehuecoyotl | Engine, Exhaust, Transmission | 118 | 07-07-2013 10:26 PM |
| FA20CLUB.com Stage 1 ECUTEK Reflash Results | FA20Club.com | Engine, Exhaust, Transmission | 20 | 08-25-2012 07:02 PM |
