Old 07-11-2013, 11:48 AM   #281
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
And even then I believe you have to push the temperature of the injectors above 150 degrees Celsisus (so very aggressive driving for an extended period of time). We know this is possible because people are doing it and their injectors are failing.
That 150 degrees you are referencing was only raised with respect to the injector tips and potential durability damage to them at this temperature (see earlier Toyota quote in this thread). It has nothing to do with knock damaging the injector seals. There is no indication at this point that a 150+C DI tip temperature is a required condition for seal damage.
Sport-Tech is offline   Reply With Quote
Old 07-11-2013, 12:10 PM   #282
Mikem53
Drives: FR-S 6MT
Originally Posted by ayau View Post
Maybe Subaru was right from the beginning when they said they didn't want direct injection in their engine.
DI brings us 12.5:1 CR.. Would hate to lose that in this NA application..
Just some bugs to work out in this car.. Will take some time..
Mikem53 is offline   Reply With Quote
Old 07-11-2013, 12:33 PM   #283
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Where did they say that? EVERYONE is moving towards direct injection, more control translates to higher efficiency (and power if tuned properly), this partnership exists so Subaru can phase direct injection into their other vehicles using Toyota tech.
Unless you're talking about how Subaru's DI system wasn't up to the task before Toyota stepped in...
ineedyourdiddly
Old 07-11-2013, 01:06 PM   #284
ayau
Drives: Some rust bucket
I faintly remember reading an article stating that Subaru was opposed to using DI in this engine.
Old 07-11-2013, 01:51 PM   #285
DarkSunrise
DarkSunrise's Avatar
The FA20 would not hit 200 hp without DI. Toyota engineers mentioned the engine was around 150 hp before they implemented DI, raised the CR, and tuned it.
The only other way to hit 200 hp while staying NA is variable lift cams, but that would have probably caused problems packaging the engine so low and far rearward in the chassis.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
strat61caster (07-11-2013)
Old 07-11-2013, 02:01 PM   #286
ayau
Doesn't the FA20 have variable valve timing?
The FA also features direct injection (from Toyota) and Subaru AVCS variable valve timing system.
http://en.wikipedia.org/wiki/List_of...baru_FA_engine
Old 07-11-2013, 02:02 PM   #287
DarkSunrise
Variable valve timing, not variable lift. Basically VVT vs. VVTL.
2022 BRZ Build
2013 FR-S Build
ayau (07-11-2013)
Old 07-11-2013, 02:04 PM   #288
thill
Agreed, outside of turboing the engine DI was the best way to get the car up to 200hp. I think it was a win/win for Toyota and Subaru. Toyoyts needed the boxer engine to achieve their goals, and Subaru engineers got exposed to Toyota's DI technology and engineering.
Coming from a car that had a turbo, I am really enjoying the NA engine. So much so that I would not turbo this car. I would go the supercharger route if I really wanted more power if tune, exhaust, intake, filter are not enough for me.
The Following 2 Users Say Thank You to thill For This Useful Post:
sierra (07-13-2013), strat61caster (07-11-2013)
Old 07-11-2013, 02:16 PM   #289
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
The engine would have never gotten 200 hp without DI and the Toyota tuning the compression higher, would've been closer to 160 hp, if it hadn't put DI it wouldn't be a very good selling point or power from a power standpoint.
Old 07-11-2013, 02:18 PM   #290
FRSBRZGT86FAN
Smile
On the same wiki page:http://en.wikipedia.org/wiki/List_of...baru_FA_engine
It proves that subaru was able to make heeps of power with just DI and a turbo and lowering compression, future sti motor?
Old 07-11-2013, 02:22 PM   #291
thill
Yes, Subaru is going to phase out the 2.5 liter engine in favor of the 2.0.
http://blog.caranddriver.com/turbo-v...ower-next-wrx/
Old 07-11-2013, 02:24 PM   #292
DarkSunrise
Yeah it's a tough call between the fat torque curve of a turbo vs. the responsiveness of an NA engine. When I'm in my FR-S, I miss the low/midrange punch of the turbo in my GTI. Toyota/Subaru decided to give the FR-S a torque dip of all things. But when I'm in the GTI, I miss the instant response of the FR-S.
In the end though, If I had to choose, I'd probably go with the 2.0 TSI/K03. The difference in the torque curves is pretty staggering:
2022 BRZ Build
2013 FR-S Build
Old 07-11-2013, 02:25 PM   #293
FRSBRZGT86FAN
Smile
The CVT idea is stupid yea it gives great economy but the engine sound will change and the driver feel won't be as fun
Old 07-11-2013, 03:13 PM   #294
LS13
Drives: Toyota
Joy of first year ownership/test lab driver. But then again Subaru has left the ringland cast pistons issue on the STI since forever :\
LS13 is offline   Reply With Quote
regalsurinalpost
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
86 rentals - 2013 era bcj AUSTRALIA 11 04-23-2013 11:27 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 06:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 01:25 PM
