Old 07-11-2013, 08:31 AM   #43
Bailey239
Bailey239's Avatar
Drives: Firestorm FR-S
Originally Posted by getbent View Post
You are referring to the lower strut body/bracket bolts. He is referring to the bolts that connect the strut to the swaybar.
If the swaybar endlink bolts aren't snugged, it will rattle, particularly around corners.
Oh. Around corners it's fine. It's only when I'm going over bumpy or uneven roads it starts to rattle.
Bailey239 is offline   Reply With Quote
Old 07-11-2013, 08:41 AM   #44
getbent
Drives: 2013 FR-S Blue MT
Double-check your swaybar endlinks for play as well as the ball joint in the control arm.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 07-11-2013, 11:18 AM   #45
simpleisbest
Senior Citizen
Drives: Scion FR-S
Actually if going around corners it is quiet, then it is likely it IS you endlink bolts. They most likely stop rattling when the sway bar is loaded when in a turn. Make sure you use a box wrench and an Allen wrench to tighten. I used a long socket 10mm and a extension as a handle around the Allen wrench to get a better grip and really make sure that the endlink rod end dosent move while tightening.
simpleisbest is offline   Reply With Quote
Old 07-11-2013, 11:28 AM   #46
Bailey239
Bailey239's Avatar
This is the top bolt under the rubber dust cover?
Old 07-11-2013, 12:22 PM   #47
simpleisbest
Senior Citizen
Drives: Scion FR-S
No. That is your top mount shock bolt.
To tighten your endlink bolts you will need a lift or jack up the car. Removing the front wheels is recommended.
The end links are what connect your sway bar to the car. In our case, the car connection point are the front shocks. Look at your front sway bar's ends (pointed toward the front of the car). You will see that connecting the sway bar to the shock is a shaft looking thing with threaded screws pointing out on each end. That shaft thing is the end link. You want to tighten the nuts (2 per end link).
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 10:09 AM
My Install from Simplicity in Sound jlu Electronics | Audio | NAV | Infotainment 3 06-05-2013 05:24 PM
clanking sound with idle wallace03 Issues | Warranty | Recalls / TSB 4 05-08-2013 05:19 PM
GT Sound Matt Install Neilus Scion FR-S / Toyota 86 GT86 General Forum 0 12-18-2012 06:32 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
