Old 07-07-2013, 08:43 PM   #1
Bailey239
Bailey239's Avatar
Drives: Firestorm FR-S
Question clanking sound after Eibach pro install
I installed my "Eibach pro kit" today on my stock struts, I didn't really run into any problems during the install, I followed a DIY from the forum and used hand tools. When I turn my wheels left and right there are no weird sounds, while driving 35+ or slowly on smooth roads or only small bumps I don't hear any weird sounds, when when I drive slow over speed bumps, bad roads or potholes I hear a pretty noticeable clanking sound coming from my wheel area. I checked and I don't see any marks from metal contacting each other anywhere and all my bolts are torqued down, can anyone think of anything I might of overlooked or anything I should check? I know this is probably hard to diagnose with this little info, but i'm at a loss. I haven't noticed any weird noises from my rear struts at all. :/
I took a video it is kind of quiet and the audio doesn't really give it justice but you can kind of make out the abnormal sound's. [ame]http://youtu.be/OX4Q-hsjSKs[/ame]
Bailey239 is offline   Reply With Quote
Old 07-07-2013, 09:55 PM   #2
getbent
Drives: 2013 FR-S Blue MT
Double-check your swaybars and strut tophats.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 07-07-2013, 09:57 PM   #3
Bailey239
Bailey239's Avatar
What about the top hats? That they're tight? Wouldn't the swaybars be having an issue while turning more then just going over bumps? Or do you think they're knocking under the car?
Old 07-07-2013, 10:20 PM   #4
charged86
charged86's Avatar
I have zero problems with min dis assemble and make sure the strut mount is all the way down on the strut shaft there is a machined part of the strut shaft that stops the hat
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-07-2013, 10:28 PM   #5
Bailey239
Bailey239's Avatar
Aren't the front hats supposed to spin with the bearing? I guess ill have to take it off and see what you're talking about.
Old 07-07-2013, 10:30 PM   #6
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
you torque the bottom bolts on the strut enough?
bkblitzed is offline   Reply With Quote
Old 07-07-2013, 10:58 PM   #7
Bailey239
Bailey239's Avatar
What bolt are you talking about exactly? The strut to hub assembly Nuts?
Old 07-07-2013, 11:04 PM   #8
bkblitzed
is better than you
bkblitzed's Avatar
yea, when i didnt do it enough it loosened and made a clunk noise. But seems to me that you did it enough. Since it's not coilovers i doubt it'll be coil binding. Also since you dont have after market camber plates i doubt it'll be your top hats hitting the top of the fender. Can you physically feel the clunk in the car?
Old 07-07-2013, 11:12 PM   #9
Bailey239
Bailey239's Avatar
Just slightly. I'm going to check those two bolts after work tomorrow, hopefully that's all that's wrong. I'm open to any more ideas but ill post an update after I check them
Old 07-07-2013, 11:16 PM   #10
Bailey239
Bailey239's Avatar
Im going to pick up a new torque wrench after work, this one might be defective when going to higher foot pounds or something.
Old 07-07-2013, 11:46 PM   #11
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
How exactly did you break the top nut loose to remove the spring? If you didn't use an open-centered socket or the "special tool" to hold the shaft with a hex key, there is a chance you could have spun the shaft loose inside the shock. I'm speaking from experience, ruined one of my rear shocks this way.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 07-07-2013, 11:49 PM   #12
Bailey239
Bailey239's Avatar
Originally Posted by Moshpit37 View Post
How exactly did you break the top nut loose to remove the spring? If you didn't use an open-centered socket or the "special tool" there is a chance you could have spun the shaft loose inside the shock. I'm speaking from experience, ruined one of my rear shocks this way.
I used passthrough sockets and an allen wrench so I dont think thats the issue.
Old 07-08-2013, 07:34 PM   #13
Bailey239
Bailey239's Avatar
So I went to autozone got a new torque wrench, re torqued the bolts from the hub to strut, checked the other bolts and looked around for metal contacting and leaving marks. Reassembled everything and am sill hearing the noise, is it normal to hear some noise when going over things? I'm going to try to get a video of this sound but so far, no progress. Anyone have any other ideas? :/
Old 07-08-2013, 08:10 PM   #14
suaveflooder
Is it on all of them, or just one? If it's just one, you have a blown strut if that top bolt is tight. Put the stock springs back on and take it in and get it fixed under warranty.
suaveflooder is offline   Reply With Quote
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 10:09 AM
My Install from Simplicity in Sound jlu Electronics | Audio | NAV | Infotainment 3 06-05-2013 05:24 PM
clanking sound with idle wallace03 Issues | Warranty | Recalls / TSB 4 05-08-2013 05:19 PM
GT Sound Matt Install Neilus Scion FR-S / Toyota 86 GT86 General Forum 0 12-18-2012 06:32 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
