#71 | |
This entire project is not to dog Vortech or shit on vendors or modifying it's to say it's not as "Hollywood" as most make it out to be. It's a lot of work and when things go wrong it turns from enjoying a hobby to the hobby owning you.
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | Sportsguy83 (07-09-2013), wootwoot (07-18-2013) |
#72 |
Drives: '11 535i
The removal of the exhaust hanger section in the video made me
| The Following 2 Users Say Thank You to PERRIN_Mladen For This Useful Post: | Dezoris (07-10-2013), Sportsguy83 (07-09-2013) |
#73 |
The secret is we did the entire install with that hammer!
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | ftc~brz (07-10-2013), PERRIN_Mladen (07-10-2013) |
#74 | |
Done
Drives: WRB BRZ
I've learned a lot from this forum and your work has been very informative and strait from the hip. I was very impressed with the vortech kit when I saw it installed on redallerts car and that was the direction I wanted to go with my dd. I knew turbo was not what I was looking for personally. Either way, any FI is scary when it's your own money going into your own car. Even more scary when it's your only car and all the risk is on your shoulders. I fell in love with the vortech kit when I saw it in action and I am interested to see what will come of it and the other kits out there in FI land. Thanks again for keeping it real. |
| The Following 6 Users Say Thank You to ftc~brz For This Useful Post: | akuhei (07-10-2013), Brian@Vortech (07-10-2013), Darryljr11 (07-17-2013), Dezoris (07-10-2013), F1point4 (07-10-2013), ultra (07-17-2013) |
#75 | |
Then the FR-S, I said the same thing not going to modify it. It's not my thing. Until the I started doing the track stuff with it watching Neons, mustangs, Focus, Mazdaspeed3s basically anything walk passed the car in a straight line. It's the core disappointment of having a "only if" car. I waited on the sidelines until I felt enough data had been published on the Vortech kit to go all in and tell the story about it. Never have I done aftermarket supercharging, so much to learn. In fact so much to learn I stopped karting and racing this year and doing a lot of the things I loved to work on this project. It's all for the experience to learn and to help others good and bad. With your project, you already have a head start, just try and know as much as you can about the car now so you can learn how it has changed and what is normal and not. Don't be afraid to ask and even piss people off if you are not getting the straight answers. Like you said, its $$$ and when its your only car it gets real very fast. We are putting a lot of trust in faith in the vendors who supply the parts that all the hype and promise is not just a road to misery namely when we are early adopters. In the end I chose Vortech given their long history of products and knew they could support the car when problems arose, and they have almost a year head start supercharging it. And so far most issues are transparently being handled. More importantly we now have many owners and a lot of data to share, helps not feeling so alone or clueless. Thanks for following this. I will be following your end too, and the products you use so we can figure out any issues and how to prevent them before they happen.
#76 |
Drives: FR-S Firestorm
Thanks for sharing your experience.
The conception of the vortech kit is not impressing me at all. Very disapointing.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
#77 | |
Thupercharged
Can you share what is disappointing to you?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#78 |
- The piping rubbing/touching almost everywhere ( Hood - frame - bracket ) with the engine vibration mouvements probably. ( Too tight of a fit )
- Piping rubbing with the belt problem. - The washer bottle that need to be cut for install. - The need of a grinder when installing to melt the metal on a bracket or something. - The instructions supplied with the kit that look vague not enough accurate. - The simple fact of mounting their intercooler look like it was a pita for him and should normally be an easy task. - The supercharge is not making enough noise for my personnal taste. When I watch this guy videos I dont see the difference with the sound inside the car before / after that make the car now feel like a totally new beast. When you go forced induction, it is fun when you can clearly hear your new investment like a turbo spooling sound or a whine sound coming from a supercharge. It look like the vortech is very quiet from the inside.
#79 |
Sideways and Smiling!
Drives: Scion FR-S
Hmm my vortech kit makes a nice whirring sound and i can hear the BOV make the whooshing sound when hard shifting.
I havent had any rubbing issues yet either but of course i had someone with experience with installing this kit put it on my car.
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
#80 | |
Thupercharged
The washer bottle does not need to be cut for the install. The plastic fill tube gets cut, however you can easily go back to stock by just using the rubber coupler they included to join the 2 halves back together. I get no rubbing/rattling of pipes anywhere, minus the slight dent it made in the hood insulation. The innovate kit has the same issue except with the blower pulley from what I gather. I had no problems with the instructions. The intercooler bolts sucked, but I was able to mount it by myself with no help. I can hear my supercharger from idle to about 2500rpm, after that my exhaust makes hearing anything at all pretty hard. The dramatic supercharger install video was dramatic and showcases potential issues installing the kit... which is what I am sure the purpose of the video was, to educate.... However it does not mean that you are going to have all of these problems, its just something to watch out for... in pretty much ANY aftermarket FI kit. I have not had to open the hood to adjust anything since the install, I personally had a very smooth install with no issues afterwards. I did install a louder (and less plastic) bypass valve, because I am a sucker(maybe even a ricer) for noises on throttle let-off ![]() I can really only speak from my standpoint though, everyone has different conditions/tools/experience/expectations
2013 FRS
| The Following User Says Thank You to DJCarbine For This Useful Post: | NoFear99 (07-17-2013) |
#81 |
Drives: 2013 Subaru BR-Z Limited
I just watched your video about the intake tube interference with the pulley (and alternator bracket and hood liner and...) and I had another question for you.
I've seen quite a few FI FA20s now and everyone of them seem to have bumper alignment issues. Some owners have complained of issues with the retaining clip brackets under the headlights and other owners say some ducting gets in the way and pushes the bumper down. Either way, the bumper seam between the fender and front bumper doesn't match up. Do you also have this problem with the Vortech kit installed?
#82 | |
| The Following User Says Thank You to Dezoris For This Useful Post: | chadstyle (07-17-2013) |
#83 |
SLO NO MO
My bumper was borked after two removals and before I went FI.
Sent from my Nexus 4 using Tapatalk 2 |
| The Following User Says Thank You to Foobar For This Useful Post: | chadstyle (07-17-2013) |
#84 |
Thupercharged
I'm pretty sure if I take off my bumper one more time, it will never go back on without cursing and zipties.
2013 FRS
| brz vortech supercharger install? | Sniper2606 | Forced Induction | 16 | 05-07-2013 03:31 PM |
| *PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) | PhastekSport | Forced Induction | 425 | 04-26-2013 10:06 AM |
