Old 07-10-2013, 11:45 AM   #57
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by whitefrs View Post
I didnt know they did e-tunes and i never used their basemap as John told me that the basemap was not safe at all
The basemap is definitely safe at the wastegate pressure of 7 to 8 psi. It starts getting a little less safe at 10 psi, but it is still safe to run. I have logs from both, and John told me a similar story.
whitefrs (07-10-2013)
Old 07-10-2013, 12:30 PM   #58
Gen
Drives: Scion FR-S
Originally Posted by JP View Post
Why did you not go with the turbo kit manufacturer's tune in the first place?
I have an FBM kit and received a base map and a revised tune and while it was drivable, it wasn't particularly pleasant. That's what I expect from an etune. It's far better to actually get on a dyno.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Old 07-10-2013, 01:26 PM   #59
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Thanks for your honesty. Our maps are always improving with Ecutek's constant updates. Along with all the logs that our customers have been shooting over to us.
I agree, it is always better to have the car dialed in on a dyno. That is why we do not charge for E-tunes or basemaps ,what ever you want to call it
If you need help or have any questions/concerns, please shoot them over to us along with a log.
Fullblownmotors@gmail.com
FullBlown is offline   Reply With Quote
Old 07-10-2013, 01:42 PM   #60
xxscaxx
Drives: 2013 SWP BRZ
While I agree to a point with you on this, your statement isn't entirely true.
Before I got this car, I thought the same thing basically. But a base tune and an etune are completely different.
Base tune - kind of like a cobb OTS tune, a generic "one size fits all" tune.
etune - datalogs back and forth with a tuner, who is specifically changing certain parameters for your particular car.
I am still a huge fan in a dyno tune and having someone dial it in on a dyno...but after owning this car and having etunes done, and recently getting my girlfriends stage 2 wrx etuned from torqued performance, I feel confident in having it done and the car driving as intended.
My girlfriends car feels better than many wrx/sti's ive been in with protunes on the dyno.
xxscaxx is offline   Reply With Quote
Old 07-10-2013, 02:16 PM   #61
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Just clearing something up here
LJ didnt just gave me a base map.
We went back and forth with datalogs and all till we got a good tune for 7.5 psi than we started again at 11 till he told me that we were all good and safe to drive
Old 07-10-2013, 02:28 PM   #62
xxscaxx
My post had nothing to do with your postings, and I didn't mean to come off like he sent you a base map with your final tuning solution you are running right now. BUT, FBM DOES send a "base" map for everyone who buys the kit, which is exactly what I was describing.
Old 07-10-2013, 02:30 PM   #63
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Gotcha
Sorry for misunderstanding
Old 07-10-2013, 02:39 PM   #64
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Glad your car is finally feeling better Will. You have been through a fair share of headaches!!
Old 07-10-2013, 02:39 PM   #65
mad_sb
Drives: 2013 Asphalt FR-S
Fuel trims are not perfect at all..... Idle still hits -27 cruise it swings between -20 and +35.. not even close to perfect. It may go into boost ok and start ok, but considering it still idles at 950 rpm hot and the trims are absolutely all over place your tune and your car are far from done man.
I think you should have kept working with Toni to sort it out. And you still have a mechanical issue.
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (07-10-2013)
Old 07-10-2013, 02:42 PM   #66
Sportsguy83
Drives: Limited BRZ
I saw that on some logs, but my tuning knowledge does not go that far. I just knew it was weird and so so different than what my logs showed.
Old 07-10-2013, 02:44 PM   #67
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
David
The logs u got are from Toni
I didnt email you the ones from LJ
Old 07-10-2013, 02:46 PM   #68
mad_sb
Originally Posted by FA20Club.com View Post
Considering I've spent the last week helping you check over your entire car without even beginning the tuning process beyond send you a start up calibration the feedback is much appreciated. This is exactly why i told you what to check before you sent me a di
me cause customers with issues always quick to place blame. Sending you numerous licenses through the process answering your text and call early in the morning late at night. Thanks for the opportunity and the post much valued. I'll leave it at that
So.. sorry for the referral man lol
Anyway, He still has the same issues. I think he was hitting boost cut on your base map (he was boosting .7 - .8 bar on your base map) before you had a chance to dial it in for him
Idle is still 950 rpm hot, trims on the full blown tune are worse than what i saw on your base map ( -27 at idle range from -20 to +35 at cruise).
He's got some mechanical issues that need to be sorted before any tune is going to be solid.
Old 07-10-2013, 02:48 PM   #69
Sportsguy83
Drives: Limited BRZ
David
Ok, thats true.
Still, listen to @mad_sb, he knows his shit about tuning. Good luck man!
Old 07-10-2013, 03:02 PM   #70
mad_sb
For my car, FBM's tuning fixed the issues I was having.
So after my DI and Spark Plug Issue
My car wasnt running right.
Rough Idle
Fuel trims were maxxed out
Car didnt wanna Start
I first went with Visconti,
Hes tune was fine at the beginning but after my issue he just couldnt get it right
So i went and tried toni from fA20
He was saying that i had a mechanical issue and thats why i had a rough start and starting problem
So i ask LJ @FullBlown and he offered to help me
He sent me a base map
And boom car started right up,
We did some datalogs he touch it up and all after just 1 datalog my car was running perfect at 7-7.5 psi.
No rough idle or hard start
Now we are at 11 psi and my AFR and Fuel Trims are perfect,
No rough idle or Hard Start at all
Car pulls so nice and i really dont wanna stop driving it and the best part was that it was Free yes Freee!!!!!!!!
I spent 1000.00 on Both tuners and let me tell you, what a waste of Money
So all you Existing and New Full Blown Customers
Talk to Lj about Tuning, you wont regret it
So, I know you really want your car sorted out man, it has been a long frustrating road i am sure. But it is not "fixed". It may run ok under boost but you still have serious fuel trim issues at idle and cruise.
You mentioned it has always idled at 900 rpm since the turbo install and stated some other turbo's were seeing the same idle.. i guess that is normal... However, i see no reason in the world why that should be normal but if some others can chime in and that does turn out to be normal... you can cross that off the list of symptoms.
As i said from the begining, your car, your money, your choice. If your happy with the car now that great but please be aware you still have some issues to sort out and please keep an eye on your data logs for the sake of your motor.
Driver door alignment issue--fixed kingping Issues | Warranty | Recalls / TSB 14 03-26-2019 10:46 AM
Visconti Tuning Sportsguy83 User/Vendor/Sponsor Reviews, Feedback, Comments 44 10-11-2013 07:15 PM
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 04:00 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 12:49 PM
