Old 07-09-2013, 09:26 PM   #589
JordanInnovations
Drives: Forced Induction and LSx Swaps!
^^ Nope, you sure it's melted? Maybe the nut got tightened down and the pipe has something pushing it down?
JordanInnovations is offline   Reply With Quote
Old 07-09-2013, 10:27 PM   #590
charged86
charged86's Avatar
Originally Posted by pheoxs View Post
Has anyone else had the rubber bushing for the maf pipe melt on them? Should there have been washers or something?
I know it gets warm in there maybe you had it too tight combined with heat and it split. I think melted you would see bubbles in the rubber. how many miles on your kit.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-10-2013, 04:34 AM   #591
ft86me
ft86me's Avatar
Drives: 2013 FRS
anyone running a koyo rad with vortech and a aftermarket header? i'm hoping p&l fits but i know that one bracket is fairly large. input please!!!
ft86me is offline   Reply With Quote
Old 07-10-2013, 08:30 AM   #592
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Hmm I'll double check it, I think I tried using it to hold the pipe up a bit higher since I was concerned about clearance of the belt, maybe it was too much pressure on it and it split.
Not many, 1 week so like ~500km
pheoxs is offline   Reply With Quote
Old 07-10-2013, 10:41 AM   #593
superstani
Drives: 12 TL
So I pulled the logs from my data logging and my butt dyno seems spot on.
3000 to 7000 rpm pulls vs time shows:
I'm assuming the time axis is in milliseconds in Ecutek logs? I don't see any other units that would make sense.
Visconti = 9283ms
FA20 = 8220ms
Will be curious to redo comparison once they've both been readjusted, this is the initial base tune sent by both so take it with a grain of salt.
Hopefully dynos in a couple weeks if I find time to head down to Calgary
so does this mean that FA20 tune makes more power? any knock count difference between the two?
superstani is offline   Reply With Quote
Old 07-10-2013, 10:50 AM   #594
v1ru5
Drives: BRZ D4S 6MT L Vortech
I am running a koyorad radiator and borla uel header. They fit fine.
v1ru5 is offline   Reply With Quote
The Following 2 Users Say Thank You to v1ru5 For This Useful Post:
ft86me (07-10-2013), guarapo (07-10-2013)
Old 07-10-2013, 11:20 AM   #595
pheoxs
According to my butt dyno, yes it definitely pulls harder. Hoping to get dynos down the road to back things up
I haven't seen a single knock on both tunes through various data logs and pulls
Old 07-10-2013, 11:29 AM   #596
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
did you say...compressor..upgrade...? do tell about this compressor upgrade. id be very interested in knowing what you guys offer to step up the gains to the next level. thanks in advance!
The V-3 H67B is quite capable of handling what most enthusiasts would require from it (skatery1989 is making 365rwhp on E85 with it). For someone looking to go more to the extreme (and has a setup built for the job), we can calculate what the proper compressor would be for that application.
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
ft86me (07-10-2013), skatery1989 (07-10-2013)
Old 07-10-2013, 11:34 AM   #597
ft86me
ft86me's Avatar
Drives: 2013 FRS
When I build my internals I'll come talk to you hahaha
The Following User Says Thank You to ft86me For This Useful Post:
Brian@Vortech (07-10-2013)
Old 07-10-2013, 05:16 PM   #598
charged86
charged86's Avatar
will and upgraded compressor boost sooner ? and will it fit the bracket
The Following User Says Thank You to charged86 For This Useful Post:
ft86me (07-10-2013)
Old 07-10-2013, 05:27 PM   #599
ft86me
ft86me's Avatar
Drives: 2013 FRS
Can this also be done on stock internals? 91?
Old 07-10-2013, 05:35 PM   #600
charged86
charged86's Avatar
365 whp?? I don't believe so. cant run much timing on 91 as far as I know
Old 07-10-2013, 05:40 PM   #601
Brian@Vortech
No, and yes. Bigger compressors will be great for higher output, but likely be less responsive on the low end of the spectrum. Any V-1, V-2, V-3, or even V-7 should fit into the Supercharger bracket. Again, almost no one will ever need to go beyond the output capability of the V-3 H67B included with the kit though. Going to a bigger blower just to have a bigger blower is not the right course of action here...you may actually lose power unless your setup is sufficiently built enough to make use of it.
It is all about the right tool for the job. Just like you wouldn't want to try nailing a picture to the wall with a sledgehammer, in most cases you would not want to put a compressor on a 2.0 Liter engine that is more suited for a 5.0 Liter engine. The H67B was designed for this FA20 engine, and seems to work quite well on them.
Old 07-10-2013, 05:45 PM   #602
charged86
charged86's Avatar
one time I used a sledgehammer open my beer :happy0180:
but serious note. do you think its possible to swap pulleys with my blower mounted.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
