Old 07-07-2013, 03:47 AM   #575
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by Dezoris View Post
Glad to see you finally got it done!!
Also if you dont mind can you email me your some of your logs you sent? I want to take a look compare to those I have.
You have any pictures? Initial impressions?
External oil system?
Initial impressions is this makes the car so much more fun and just a blast to drive. Makes me wonder why it didn't come like this from factory to be honest.
pheoxs is offline   Reply With Quote
Old 07-07-2013, 12:41 PM   #576
Dezoris
Dezoris's Avatar
Pheoxs helped me with some logs last night thanks.
Does anyone have a full throttle log from a Visconti tune running (base map 1) they can send me.
Also it would be best if the log has Coolant temps below 95C and oil temps below 95C.
Old 07-07-2013, 12:44 PM   #577
ft86me
ft86me's Avatar
Drives: 2013 FRS
I have one that I did for him but then he did something to it then sent me another file. Not sure if mine would help. I have a koyorad and Perrin oil cooler if that helps
ft86me is offline   Reply With Quote
Old 07-07-2013, 01:05 PM   #578
Visconti
Drives: 05 STi
Why
Visconti is offline   Reply With Quote
Old 07-07-2013, 01:41 PM   #579
Dezoris
Dezoris's Avatar
Why
Transparency, oversight.
Old 07-07-2013, 03:58 PM   #580
Visconti
Drives: 05 STi
If you buy a tune you can have a log
Old 07-07-2013, 04:03 PM   #581
nelsmar
Wait oil can be below 95c ?! (Lol I live in Arizona)
My flickr - Canibeat
Local magazine scout
Old 07-07-2013, 04:49 PM   #582
pheoxs
So I pulled the logs from my data logging and my butt dyno seems spot on.
3000 to 7000 rpm pulls vs time shows:
I'm assuming the time axis is in milliseconds in Ecutek logs? I don't see any other units that would make sense.
Visconti = 9283ms
FA20 = 8220ms
Will be curious to redo comparison once they've both been readjusted, this is the initial base tune sent by both so take it with a grain of salt.
Hopefully dynos in a couple weeks if I find time to head down to Calgary
Old 07-07-2013, 05:12 PM   #583
Dezoris
Dezoris's Avatar
Haha yeah small window for that, if you don't have an oil cooler.
Visconti = 9283ms
FA20 = 8220ms
Dynos will be your best bet for sure to see the real differences but, Viscontis tune is running less timing on his base map than FA20 so that's going to make a big difference in that 4000-7000 range.
But you want to monitor how the car drives normally including MPG as well which is equally important.
Old 07-07-2013, 05:18 PM   #584
Dezoris
Dezoris's Avatar
Or you could donate a few logs for reference like the other tuners and owners have to me.
But if your prefer I pay you for that privilege I can do that, however the stipulation is you provide the Vortech owners your methodology on your tunes so we can build a proper FAQ.
Old 07-07-2013, 07:53 PM   #585
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
why didnt it come from factory this way......simply put, price point had to be under 25k
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 07-07-2013, 10:01 PM   #586
nelsmar
I was trying to research the squeak I was having, and found that video.
Dont know if it was someone on here or not. When it stops sounds like high pressure fuel pump.
I have tried to pay attention as I had tried to just ignore this while my car was completely stock. But it seems I have had this sound @ around 3,200RPM (may be at other rpms as well but consistently around this mark) for as long as i can remember. It may however now be louder than before. I have tried reving a few times in the past to see if i could duplicate without loud and i haven't. I will try again later and see if i can replicate without load.
Old 07-08-2013, 12:49 AM   #587
Dezoris
Dezoris's Avatar
I just added some tuner comparison logs on my review thread, and will continue to add to it as I am able to get more data from tuners:
http://www.ft86club.com/forums/showp...7&postcount=58
MOST AGGRESSIVE BASE TUNES: (TIMING)
1. FA20CLUB
2. PERRIN
3. VISCONTI
Old 07-09-2013, 09:10 PM   #588
pheoxs
Has anyone else had the rubber bushing for the maf pipe melt on them? Should there have been washers or something?
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
