Old 07-09-2013, 02:42 PM   #1
Taber
Drives: 2013 BRZ Limited
DI Failure Issue
So, I've been reading a number of threads on this, and I'm somewhat confused:
1)Is it the injectors that fail, or is it actually a seal that fails?
2)Are people just replacing the seal and remedying the problem?
3)If its just a seal replacement, is it an oem revised seal?
Taber is offline   Reply With Quote
Old 07-09-2013, 02:49 PM   #2
topazsparrow
Drives: slow
we DON'T need another thread on this.
Read the existing threads, all the info is there (with multiple pictures). This post only further reduces the likely hood that the search feature will find relevant information.
topazsparrow is offline   Reply With Quote
Old 07-09-2013, 02:51 PM   #3
ayau
Drives: Some rust bucket
See post #147.
http://www.ft86club.com/forums/showt...t=40951&page=7
Old 07-09-2013, 03:03 PM   #4
CSG Mike
CSG Mike's Avatar
1. Bad factory tune causes the seal to fail, which ultimately causes the injector to fail.
2. it's a bandaid.
3. no
Old 07-09-2013, 03:06 PM   #5
CSG Mike
CSG Mike's Avatar
By Stu of gt86ownersclub.co.uk
There's so much misinformation and paranoia floating around about this issue. The American forum has gone banzai about it without truly understanding the problem. I appreciate dealerships there are just as bad as here though with a) acknowledging a problem, b) understanding it and c) fixing it successfully (without taking your car on a 200+ mile jolly).
The issue is transient det damaging the seals. It's not when you lift the throttle the problem occurs, it's when you go back on it quickly. This is called "tip-in". When you rapidly change the throttle angle, you need "tip-in fuel" and "tip-in spark". Because sensors (and the ecu) takes a few milliseconds to react to these changes, you have to put in predictive tables which ensure the engine gets the right amount of fuel and spark during those big-change transient conditions.
Now our engines, with calibrations 700, and A00 DO have transient spark tables, however for some reason (which we will never understand/find out), the transient spark table was disabled above 5200rpm. This means that if you change gear rapidly above this engine speed you are able to 'get ahead' of the ECU and get a little crack of tip-in det/knock. This isn't usually dangerous, but it appears the seals used on the direct injectors (of which I am confident are perfectly up to the job) do not appreciate the det and over time wear and cause a leak and eventually total seal/injector failure requiring replacement.
The fix in calibration A01 is to move the upper bound remit of the transient spark table from 5200 rpm to 10000rpm (e.g. always) and the actual table itself has been populated with some meaningful spark angles so it does its job up top now its actually activated.
Here's a copy of the stock 700/A00 transient spark table, as you can see it's not doing any retarding over 4000rpm:
Here's a copy (leeched from ft86club) of the Toyota docs on the issue:
Old 07-09-2013, 03:17 PM   #6
ayau
Sounds like @CSG Mike mashes the gas pedal very quickly after an upshift
Old 07-09-2013, 03:23 PM   #7
CSG Mike
CSG Mike's Avatar
Sad part, is that it doesn't even have to be a mash... just enough to put a decent load...
Old 07-09-2013, 03:39 PM   #8
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
The question is how do you get this fixed by Subaru or Toyota dealership?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 07-09-2013, 03:41 PM   #9
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
You don't. They have not acknowledged that this is a real issue... i.e no TSB
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 07-09-2013, 04:02 PM   #10
CSG Mike
CSG Mike's Avatar
You can't.... yet. Unless you live overseas in an area where Toyota has released an updated ECU flash that specifically addresses this.
Old 07-09-2013, 04:14 PM   #11
Taber
Awesome information. Thank you so much.
Old 07-09-2013, 04:52 PM   #12
Doborder
Godzilla Konvert
Doborder's Avatar
Will running 100 octane at the track help? M
Decrease chance of detonation?
CO>CA Cartel
Old 07-09-2013, 05:12 PM   #13
thill
So if I get this straight if you are above 5200rpm and do a fairly aggressive up-shift (say from 1st to 2nd) and step on the gas, you could cause the injectors to fail?
Old 07-09-2013, 05:16 PM   #14
ayau
According to the article, 0.6s or less to upshift may cause damage to the seals.
Trunk release failure - BRZ Smilez CANADA 35 07-15-2019 10:15 PM
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
100% DI Failure with Nurburgring rentals regal Scion FR-S / Toyota 86 GT86 General Forum 538 10-07-2013 05:18 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
