Drives: 2013 BRZ Limited
DI Failure Issue
So, I've been reading a number of threads on this, and I'm somewhat confused:
1)Is it the injectors that fail, or is it actually a seal that fails? 2)Are people just replacing the seal and remedying the problem? 3)If its just a seal replacement, is it an oem revised seal? |
#2 |
Drives: slow
we DON'T need another thread on this.
Read the existing threads, all the info is there (with multiple pictures). This post only further reduces the likely hood that the search feature will find relevant information. |
| The Following 6 Users Say Thank You to topazsparrow For This Useful Post: | FRSBRZGT86FAN (07-09-2013), SkullWorks (07-10-2013), strat61caster (07-09-2013), suaveflooder (07-09-2013), vgi (07-09-2013), Wes (07-09-2013) |
#3 | |
Drives: Some rust bucket
http://www.ft86club.com/forums/showt...t=40951&page=7 |
#4 | |
2. it's a bandaid. 3. no |
#5 | |
By Stu of gt86ownersclub.co.uk
| The Following 17 Users Say Thank You to CSG Mike For This Useful Post: | ayau (07-09-2013), bestwheelbase (07-09-2013), Clipdat (07-09-2013), Deepseadiver (07-09-2013), denkigrve (07-09-2013), Doborder (07-14-2013), hmong337 (07-10-2013), mit_peid (07-09-2013), normancw (11-09-2013), RehabJeff86 (07-11-2013), schtebie (07-11-2013), Sigh-on-Rice (07-09-2013), Taber (07-09-2013), Tainen (07-12-2013), TofuJoe (05-21-2017), vgi (07-09-2013), whataboutbob (07-10-2013) |
#7 | |
#8 |
Godzilla Konvert
Drives: DMG BRZ Limited 6MT 2013
The question is how do you get this fixed by Subaru or Toyota dealership?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel |
#9 |
Drives: 2013 Limited DGM BRZ
You don't. They have not acknowledged that this is a real issue... i.e no TSB
BRZGrincherhood |
#10 |
#11 |
| The Following User Says Thank You to Taber For This Useful Post: | bestwheelbase (07-09-2013) |
#12 |
Godzilla Konvert
Will running 100 octane at the track help? M
Decrease chance of detonation?
CO>CA Cartel |
#13 |
So if I get this straight if you are above 5200rpm and do a fairly aggressive up-shift (say from 1st to 2nd) and step on the gas, you could cause the injectors to fail?
#14 |
| Trunk release failure - BRZ | Smilez | CANADA | 35 | 07-15-2019 10:15 PM |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 11:25 AM |
| 100% DI Failure with Nurburgring rentals | regal | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 10-07-2013 05:18 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
