Old 07-09-2013, 07:00 AM   #43
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
I've also read that Sport mode increases throttle (pedal) response, and that Snow mode starts the transmission in 2nd to avoid slippage in low gear.
I don't have my FR-S yet, but I suspect Sport mode works exactly like the ECT PWR (Electronic Controlled Transmission Power) on my IS300 which I drive with on at all times. This button was also equipped on the IS250/350.
A similar thread can be seen asking same question in the 06-13 IS. http://www.clublexus.com/forums/is-s...ntinuosly.html
One member stated a few Toyota Technical Masters told him to "you SHOULD use it in PWR mode ALWAYS. It'll make your transmission last longer. It firms up the shifts, and generates less heat. less heat = more tranny life"
- Not sure about the credibility of above sentence, maybe someone else can chime in
FiRStsc10n is offline   Reply With Quote
Old 07-09-2013, 10:04 AM   #44
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Originally Posted by carbonBLUE View Post
im always in manual mode, better than both...
Why did you buy the AT then?
Efferalgan is offline   Reply With Quote
Old 07-09-2013, 09:11 PM   #45
typericey
WRX to BRZ
typericey's Avatar
I guess another way of putting it would be:
Normal mode = fuel economy as first priority (w/c doesn't make sense for a sports car)
Sport mode = the original intention/design of the engineers (i.e. the real normal mode)
typericey is offline   Reply With Quote
Old 07-10-2013, 02:05 AM   #46
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
Perhaps because no clutch and all shifts are perfect...
Eau Rouge is offline   Reply With Quote
Old 07-24-2013, 05:12 AM   #47
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Originally Posted by Eau Rouge View Post
Sport mode moves the automatic shift points to a higher rpm. Manual mode lets you decide when to shift so would override anything to do with leaving sport mode switched on at the same time except for maybe the way the anti-stall downshifting operates. I'll have to try it out now that it's been brought up.
Reading this thread leaves me with a couple of questions...
1.) So in terms of fuel economy, cruising at 6th gear in manual mode actually saves gas when compared to normal Drive?
2.) When the sport button is on, do manual mode downshifts change in nature?
3.) What is snow mode, does it actually change the ride quality or dull the car's shifts?
4.) If snow button is activated on manual mode, and the gear starts at 2, wouldn't that be more efficient in terms of power and gas if you were driving on manual?
5.) What's faster from 0-60mph, D on sport mode, or the normal 1st - 2nd - 3rd gear shift to redline?
This is my first auto w/ manual mode :s
KelvinBRZ is offline   Reply With Quote
Old 07-24-2013, 06:48 AM   #48
FiRStsc10n
FiRStsc10n's Avatar
You bring up a valid point. I chose an AT because I have a 50 mile round-trip commute to work everyday. Sometimes I'd like to just not worry about it if there is traffic, and the added bonus of the fuel economy difference was hard to pass up. But when I feel like I want to drive racecar and burn a little fuel, I have that option as well.
Old 07-25-2013, 01:14 PM   #49
BostonJohn
I'm comming from a Mini Cooper S with a similar auto transmission to the BRZ/FRS. I don't believe i've seen it mentioned here, but some Mini owners chose to re-wire their sport buttons to essentially hardwire it into a sport mode button press.
I wonder how complicated it would be the switch the BRZ button such that it defaults to "On" and then you need to press the button to disable sport mode. If the ECU is involved then it may be something a tuner can modify.
Anyone have a circuit diagram for the button by chance?
BostonJohn is offline   Reply With Quote
Old 07-25-2013, 04:40 PM   #50
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
1) Cruising in sixth will save mileage if you're cognicent of not lugging up steep hills, etc.
3) Snow mode doesn't change ride quality. In snow mode the car will start in second gear, and the throttle response is less aggressive (pedal feels "slushy" so as to not upset the rear tires. Don't know if this is via actual TPS % alteration or through ignition advance). I think the upshifts feel smoother/softer too.
5) On mine sport mode in D is notably faster for dragracing. Upshifts are quicker and perfect redline shifts each time. I always seem to have a slight hesitation on upshifts in manual mode comparatively, but this could just be me.
In regards to the sport button... I've seen pictures of people running a small box on the firewall wired in that disables traction/VSC. I've never seen data though on a DIY. Would be awesome to have sport mode on and TC/VSC off right out of the gate.
Nightbringer is offline   Reply With Quote
The Following User Says Thank You to Nightbringer For This Useful Post:
KelvinBRZ (07-25-2013)
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 10:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 03:40 AM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 10:25 PM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 07:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
