Old 07-02-2013, 10:19 AM   #57
Dezoris
Dezoris's Avatar
Also in terms of temps it takes my car nearly 14 minutes to reach 175F with the cooler. at the 12 to 14 minute mark go on boost to 5000rpms wot twice or 3x and watch it go to 185F rather quickly.
Old 07-04-2013, 06:17 PM   #58
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by Dezoris View Post
I will be curious how you get your aeroquip lines run down past the airbox and piping without rubbing on the vortech airbox/bracket and abs module Mine are horribly tight. I am considering switching to stainless because of it.
Here you go!
20130704-HomeBrewOilCoolerSandwichPlate-001 by VictorN07, on Flickr
The zip tie hits the airbox. I'm not that concerend by it.
20130704-HomeBrewOilCoolerSandwichPlate-002 by VictorN07, on Flickr
I had to go back to the OEM filler cap
20130704-HomeBrewOilCoolerSandwichPlate-003 by VictorN07, on Flickr
The thermostat does make contact with that steel/aluminium line
20130704-HomeBrewOilCoolerSandwichPlate-004 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
charged86 (07-04-2013)
Old 07-08-2013, 12:41 PM   #59
swift996
swift996's Avatar
Someone make this a kit! I'm too lazy to piece together even with this incredible amount of detail.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-08-2013, 12:46 PM   #60
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I agree; that's why I ordered a Perrin kit. Only a little over $100 more for a complete kit with lines already cut with fittings for true plug and play with support in case something goes wrong. Their new shipment of pressure tested Mocal cores will also be black. Worth it, IMO.
Still major props to @F1point4 and anyone else who goes the homebrew route, you are all much braver than I. Saving money is also a great thing.
Old 07-08-2013, 12:57 PM   #61
F1point4
Photo Specialist
F1point4's Avatar
This. The extra hundred bucks is totally worth it for the mounting brackets and support. I totally would have went this way myself.
However at the time, the silver core killed it for me. I can take apart a car but paint? no thanks.
ATL BRZ (07-08-2013)
Old 07-08-2013, 01:00 PM   #62
xxscaxx
Drives: 2013 SWP BRZ
lol I can paint but a 100 bucks is a 100 bucks...why waste it when you don't have to. If it was like 20 i'd be more inclined to just buy the kit.
What I like about piecing it together is you can choose whatever you want to use.
Still nice to just be able to buy something and have everything to install it without worry
I say this yet knowing me will end up buying some type of kit
xxscaxx is offline   Reply With Quote
Old 07-08-2013, 02:54 PM   #63
brillo
Drives: 2013 Firestorm FR-S
I'll be installing my home brew oil cooler kit on a naturally aspirated car this Saturday with Victor's help. I'll be sure to post some pics as well as test results in humid high 90s / low 100s Houston summer weather
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
F1point4 (07-08-2013)
Old 07-08-2013, 03:52 PM   #64
deange
Drives: Black 2013 BRZ Limited Automatic
If they did actually support it I'd agree. I bought one and sent it back because they weren't going to do anything about the bad core they sent me... besides just tell me to wait around for at least 3 weeks. Maybe it will be better in the future, but I'm just going to buy the parts and save the money. If I do have an issue I can just call BAT (the guys that Perrin get the parts from) and have them address it directly. In addition you can get the color cooler you want too.
deange is offline   Reply With Quote
Old 07-13-2013, 06:51 PM   #65
F1point4
Photo Specialist
F1point4's Avatar
Local Homebrew Oil Cooler Install
@brillo is a local member to me and wanted to participate on the homebrew oil cooler action. His car is naturally aspirated and largely unmodded. Overall it was fairly easy to install. We finished in 4 hours from start to finish! Super quick
I'll make some basic comments, but leave the detailed feedback to him.
Was trying to go for a dreamy feel to the photos
Let's go!
We were testing fitment of the cooler. He wanted to keep something similar to my placement so we went with offside. Note the tape is there to mark how far over to the drivers side we can go.
20130713-ADOilCoolerInstall-002 by VictorN07, on Flickr
We drilled the holes using a Unibit and started placing the bolts and polyurethane. @brillo cut the polyurethane using a dremel.
20130713-ADOilCoolerInstall-006 by VictorN07, on Flickr
Closeup of the polyurethane standoffs. I purchased material that fit together well. Note the polyurethane and bolts were a perfect fit
20130713-ADOilCoolerInstall-018 by VictorN07, on Flickr
Here is the cooler mounted to the plastic tray
20130713-ADOilCoolerInstall-026 by VictorN07, on Flickr
We cut the polyurethane spacers too short so we were running out of thread. He had these flat cap nuts around so we used them as spacers. It works.
20130713-ADOilCoolerInstall-031 by VictorN07, on Flickr
@brillo went with Aeroquip fittings instead of Mocal largely because he has a firestorm. It looks mostly the same to me except colour
20130713-ADOilCoolerInstall-044 by VictorN07, on Flickr
My favorite picture of the lot. Oil Cooler Dreams! I find its best to install all the fittings and hose onto the cooler before remounting the plastic tray. The pushlok style fittings are not easy to place on in tight quarters.
20130713-ADOilCoolerInstall-049 by VictorN07, on Flickr
You can see the lines run inside the crash beam
20130713-ADOilCoolerInstall-057 by VictorN07, on Flickr
This picture kinda shows the very tight clearance between OEM airbox and the fittings. I think he has to undo the filter and rotate the sandwich each time he wants to check his air filtre.
20130713-ADOilCoolerInstall-078 by VictorN07, on Flickr
Last one. He ended up adding another quart of 0w-20 to his machine.
20130713-ADOilCoolerInstall-079 by VictorN07, on Flickr
Old 07-13-2013, 06:51 PM   #66
F1point4
Photo Specialist
F1point4's Avatar
Let's go!
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
afx (03-24-2015), charged86 (07-14-2013)
Old 07-13-2013, 11:06 PM   #67
brillo
Couple of initial impressions as I've only drove around a bit and haven't been able to warm the car up truly cold.
car warmed up about the same as before with daily driving, oil never got over 186 degrees in 90 temps. Car felt the same, no strange noises or NVH.
I had a slight oil leak drip on one of the aeroquip fittings near the sandwich earlier, after some additional tightening it appears to have gone away, although I felt a hint of oil on the fitting after driving this evening.
Oil level is stable. Do the aeroquip fittings take time to seal? We used lock tight on all the threads, I don't want to over tighten them. Ill monitor the car over the week as I drive it but I'm assuming I'm good to go. No noticeable leaks or issues with the core.
Old 07-14-2013, 02:36 PM   #68
brillo
Couple of other thoughts / notes:
1. Oil cooler fittings / lines near the sandwich will block access to the stock air box in terms of filter changes. You will have to remove the sandwich to change the filter.
2. Washer fluid bottle - hoses run right by it, not sure if the heat will be an issue with the neck, hopefully not, I'll be watching it.
3. Poly mounts - victor bought a cylinder of poly to cut for the mounts, cutting it is a bitch, I would suggest having a very sharp bandsaw or a dermel handy (we used a dermel).
4. Hose length - end up ordered 12ft but only using about 6 ft total. I would say 8 feet is plenty assuming a side mount (I mounted as close to the right side as I could to keep the lines short).
5. Thermostat Sandwich Hex Nut - you may need to file down one side of this nut to clear the high pressure fuel line and provide additional flexibility in terms of position and orientation.
F1point4 (07-14-2013)
Old 07-14-2013, 04:43 PM   #69
brillo
The picture below shows the thermostat sandwich. with the stock oil filler cap part of the sandwich touches the metal line in the picture. I'm not sure what this metal line is. I'm going to get a lower profile oil cap to allow me to rotate the sandwich away from the line to be safe. Not sure what extended vibration/touching may do.
Old 07-15-2013, 11:04 PM   #70
brillo
It's raining in Houston most of this week so I haven't had time to finish the install and test my cooler as I can't figure out how to get the sandwich to not touch that metal line (which I think is a high pressure fuel line) due to the air box and the stock oil cap. I can move the sandwich into a position where I get about a papers width of clearance but I'm not sure that's enough if stuff moves or shifts.
More to come....
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
Apexi Oil Temp Meter, and Setrab Oil Cooler Moto-P Scion FR-S / Toyota 86 GT86 General Forum 5 07-09-2013 01:58 PM
Mocal Oil Cooler swift996 Engine, Exhaust, Transmission 11 07-01-2013 04:00 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
