Old 07-03-2013, 06:50 PM   #15
DJCarbine
Thupercharged
DJCarbine's Avatar
I've had grinding into 5th maybe 5 times total over 6K miles.
I always thought my leg was just not cooperating and I was letting the clutch out too soon, but now I will have to keep a closer eye on this...
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
fx35s (05-25-2015)
Old 07-03-2013, 07:07 PM   #16
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
I get it every once and a while I just try to make a mental note to be careful upshifting to 5th. I have only expreienced the grind on quick upshifts.
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 07-03-2013, 07:31 PM   #17
Shagaliscious
Drives: Firestorm FR-S (MT)
Well, this definitely happened the other day. After it happened I slowed down, downshifted into 4th, and was able to recreate it. I was going probably 60-70, and it was a fast upshift into 5th with a slight grind. I am going to change the transmission fluid next oil change, see if that helps.
Old 07-03-2013, 07:55 PM   #18
Gen
Drives: Scion FR-S
Mine always grinds into 4th over 4k RPM. It has gotten better to a degree with time, however.
Gen is offline   Reply With Quote
Old 07-06-2013, 08:20 PM   #19
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Took my car into the dealer and left it with them overnight. Next day they said they compared it against another FR-S and it also had the problem so it isn't a "problem" with my specific car rather something that is on all of them. Looks like there is no fix though.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-06-2013, 09:27 PM   #20
gvan1998
Drives: Blue FRS
Dealership told me to bring th car back to the dealer. Toyota told the dealership to video record the problem and send it to Toyota Headquarters. A day later I get a response stating that there is no fix as of now, and take the car home. They will figure out a solution and give me a call. Its sounds like Toyota knows the problem exists but no solutions.
gvan1998 is offline   Reply With Quote
Old 07-06-2013, 09:39 PM   #21
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Originally Posted by l0aded View Post
no one else with this problem? =(
I guess I'll try swapping the fluids and see before bringing to dealer.
I have this exact problem. Swapping fluids did not fix it. Just taking it easy on 5th for now.
tech4pdx is offline   Reply With Quote
Old 07-06-2013, 09:41 PM   #22
tech4pdx
Make love
tech4pdx's Avatar
Maybe the problem is an inherent design decision that can't easily be fixed without Toyota eating a shit load in warranty repair costs.. Hmmm.
Old 07-08-2013, 03:53 AM   #23
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
When downshifting Into 5th, don't force it place slight pressure and let it engage on it's own, it won't grind. ( not too good on explaining it) there was another thread about this
RD1428 is offline   Reply With Quote
Old 07-08-2013, 02:12 PM   #24
PCaddict
Drives: FRS Black Raven
same problem
I noticed that my car have a slight grind, more so than any other gear. In local streets I never feel anything but when downshifting or upshifting into 5th going 65 or 70+ I feel grinding when trying to push the shift knob into fifth and requires a little more of a push to get it in. Does anyone else have this problem? Would changing transmission fluids alleviate this kind of issue?
I experience the same problem then you my car have 1 year and 26 000km and start to do this last week. The car are at the dealer right now for some test... Did you get the 1st gear unable to get in when cold and have to release the clutch a little bit to get in?
PCaddict is offline   Reply With Quote
Old 07-08-2013, 02:14 PM   #25
OrbitalEllipses
Drives: Attitude
That's normal for 1st gear in most cars. Sometimes gotta roll back or forwards an inch or two to line everything up when cold. Especially prevalent on reverse, which has no synchros if I recall (and/or is straight cut vs. helical cut for the forward gears).
tech4pdx (07-10-2013)
Old 07-08-2013, 02:18 PM   #26
PCaddict
allright and in quebec the temperature can be very cold but for the grinding at 5 gear i will see what the dealer will tell me today.
Old 07-08-2013, 02:29 PM   #27
l0aded
Addicted
l0aded's Avatar
I never had this problem but it doesn't get very cold where I am. It can feel a bit notchy but not to that point. There is a thread about that somewhere saying if you switch to a different transmission fluid it helps that problem.
http://www.ft86club.com/forums/showthread.php?t=21818
or
http://www.ft86club.com/forums/showthread.php?t=16604
Old 07-08-2013, 03:38 PM   #28
PCaddict
answer from the dealers
for the 5 gear problem the dealer flush and change the oil but doesn't fix the problem now he waiting the authorization from toyota to replace the whole transmission
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 10:39 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 03:47 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 03:41 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
