Old 06-20-2013, 04:09 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
5th Gear Grind at Freeway Speeds?
I noticed that my car have a slight grind, more so than any other gear. In local streets I never feel anything but when downshifting or upshifting into 5th going 65 or 70+ I feel grinding when trying to push the shift knob into fifth and requires a little more of a push to get it in. Does anyone else have this problem? Would changing transmission fluids alleviate this kind of issue?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-25-2013, 03:04 PM   #2
l0aded
Addicted
l0aded's Avatar
no one else with this problem? =(
I guess I'll try swapping the fluids and see before bringing to dealer.
Old 06-25-2013, 03:47 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
No, it's happening to me too. Was wondering if I was the only one.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 06-25-2013, 06:11 PM   #4
gotchobo
Drives: Firestorm FR-S
I get this also just for 5th.
gotchobo is offline   Reply With Quote
Old 06-25-2013, 08:03 PM   #5
chae
Drives: Frs
Same here
chae is offline   Reply With Quote
Old 06-25-2013, 08:12 PM   #6
scioneric
scioneric's Avatar
I have a customer do have the same issue. Car is only 2-3k. 5th gear grind when above 4k shifting what ever slow or fast gear change. He brought his FRS to our service department. Service guy test drove it, Parts manager test drove it and a Guy from Scion Canada test drove. Need to change whole gear box. Not sure why. Order the gear box right away. Just arrive last week. My customer will replace his gear box next week. I've been told it grind in any speed now. See if I have a change to test drive his car before switching his gear box next week.
I have 5th gear grind once awhile not often. Not sure if some time my leg is lazy for the clutch.
scioneric is offline   Reply With Quote
Old 06-25-2013, 09:11 PM   #7
chae
Drives: Frs
Try this and you will have 5th gear grind 100% of the time. Drive at a highway speed while in 6th gear, pop it out in neutral and let the rpm drop and attempt to put it back in 5th gear, you will grind.
Old 06-25-2013, 10:29 PM   #8
Carwhisperer
Drives: A lot of supercars.
Mine grinds when I downshift into 5th going 70mph+ or when im going 100mph+ shifting into 5th
Carwhisperer is offline   Reply With Quote
Old 07-01-2013, 01:51 AM   #9
l0aded
Addicted
l0aded's Avatar
By the sound of it this is a pretty widespread problem.. It's not a huge deal but if it causes transmission failure in the future I would want to get it taken care of while I am still in warranty.
Old 07-01-2013, 04:27 PM   #10
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Yes! I have this too, and I am very good with my revmatching so I know it's not that. I have 6k miles.
sittinSideways is offline   Reply With Quote
The Following User Says Thank You to sittinSideways For This Useful Post:
TouchMyHonda (07-03-2013)
Old 07-03-2013, 11:09 AM   #11
gvan1998
Drives: Blue FRS
I took it the dealer and they replicated the problem. They said they need to contact Toyota to get a approval and direction how to fix the problem
gvan1998 is offline   Reply With Quote
The Following User Says Thank You to gvan1998 For This Useful Post:
Shagaliscious (07-03-2013)
Old 07-03-2013, 05:25 PM   #12
l0aded
Addicted
l0aded's Avatar
Please keep us updated.
Old 07-03-2013, 05:57 PM   #13
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Holy fucking balls I have the same exact situation.
TouchMyHonda is offline   Reply With Quote
Old 07-03-2013, 06:14 PM   #14
OrbitalEllipses
Drives: Attitude
5th definitely requires more force to get into at freeway speeds (65-75) either up or down; I have grinding issues once in a blue moon, but definitely disconcerting.
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 10:39 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 03:47 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 03:41 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
