Old 06-25-2013, 04:19 PM   #281
Tirewarmer
Originally Posted by topazsparrow View Post
Ah, that's enlightening. Didn't mean to rustle anyone's jimmies. I just interpreted the situation wrong.
No problem at all. I figured that you didn't see all of the details.
Tirewarmer is offline   Reply With Quote
Old 07-06-2013, 06:43 AM   #282
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by ft_sjo View Post
I'm not really sure why a VVT related TSB is being posted in a fuel injector thread.
EXACTLY MY THOUGHT ! WTF ?
cf6mech is offline   Reply With Quote
Old 07-06-2013, 10:22 AM   #283
regal
Drives: Scion FR-S/Toyota Yaris
Maybe the cams have a bit to do with detonation? Remember the South Aftrical TSB was issued 4 months ago, so obviously Toyota has no corporate universal agreement to the problem. Subaru may have found the cause with the cam sensor shim, unfortunately it isn't a realistic procedure for most Subaru dealers to perform and obviously Scion isn't signing up for it.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-06-2013, 01:15 PM   #284
Lonewolf
Lonewolf's Avatar
Drives: Moped
I really wish that we weren't so in the dark with everything, and it is kind of disconcerting to see two manufacturers presumably do different things to try and combat the same issue...
I just want to buy my FRS, but I won't as long as these unresolved engine issues remain (seals, injectors, oil leak, stock tune is still garbage)....
Old 07-06-2013, 01:24 PM   #285
Hanakuso
I wonder if Subaru South Africa has the TSB
Hanakuso is offline   Reply With Quote
Old 07-07-2013, 12:10 PM   #286
mrk1
Drives: Sterling BRZ Ltd
What do this injectors and seals cost? Obviously I believe Subaru/Toyota should cover the costs but I haven't seen it mentioned.
I'm curious what will happen to guys who have through out the warranty with FI
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-07-2013, 01:04 PM   #287
regal
Its been posted that the seals and gaskets required to be replaced when pulling the injectors are completely out of stock nation-wide and back ordered for months.
Mods:
Old 07-07-2013, 01:06 PM   #288
mrk1
Yes I read that, I'm more curious as to the price of the parts.
The Build Thread
Old 07-07-2013, 03:36 PM   #289
bestwheelbase
Drives: 1985 P-Type
You're not the only one. Early adopters expect this sort of thing, but there's an even larger number of consumers who watch what happens during the first or second model year and base purchasing decisions off those experiences. It will be interesting to see how widespread this becomes.
Old 07-07-2013, 06:48 PM   #290
yuicebox
Drives: Asphalt FRS
I don't currently have this problem. I'm at ~1400 miles and still on factory oil.
Once I change my oil should I drive the living hell out of this thing to make sure any problems arise during the warranty period? Definitely worried about this one.
We as owners really need to stick together here and do whatever it takes to get Toyota/Subaru to acknowledge and rectify this problem.
yuicebox is offline   Reply With Quote
Old 07-08-2013, 12:28 AM   #291
bestwheelbase
Drives: 1985 P-Type
If you're concerned these issues will impact other owners, you need to file a complaint at the link below and make sure that they are all filed under the same category. It is these complaints that lead to recalls.
https://www-odi.nhtsa.dot.gov/ivoq/
The Following User Says Thank You to bestwheelbase For This Useful Post:
yuicebox (07-18-2013)
Old 07-18-2013, 05:23 PM   #292
Carwhisperer
Drives: A lot of supercars.
Car just threw P0351 - Ignition Coil "A" Primary Control Circuit/Open. The same CEL I got a couple of months ago right before I started getting firecrackers. Awesome.
Carwhisperer is offline   Reply With Quote
The Following User Says Thank You to Carwhisperer For This Useful Post:
Astroboy (10-02-2014)
Old 07-18-2013, 05:28 PM   #293
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Wow bud
Lemon car?
The Following User Says Thank You to whitefrs For This Useful Post:
Old 07-18-2013, 05:51 PM   #294
Carwhisperer
Originally Posted by whitefrs View Post
Wow bud
Lemon car?
Going that route now.
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
