#15 | |
Drives: FR-S 6MT
Now it's even easier for us because we have the rental car accelerated wear formula to determine the mileage of the failures. Maybe I'm being a bit harsh here... But all these ass-sumptions, are kind of worthless without knowing all the variables and conditions behind the failures. Info we don't have or only partially know about. The parent companies of these cars have much at stake on the line. I can't see them letting an issue like this get out of control. For all we know.. Running changes have already been implemented and the problem resolved. I will continue to use my car the way it was intended and use the warranty if the need arises. The sky isn't failing and I'm not going to worry about posts like this claiming epic failure ruin the experience.. |
#16 |
If it is a 100% failure rate and a safety issue as the OP claims I would expect massive lawsuits and full engine recall.
OP, my advice is to sell your car ASAP and get something reliable lke a Camry. |
#17 |
Thanks
If someone wants to pay a dealer to pull and inspect my DI and plugs, I'm all for it. 17k miles all street, double clutching not granny shifting of course >_^
#18 |
Drives: Raven FR-S 6MT
Am I the only one who thinks a 100% fail rate is better for 86 owners than something like 5%, since toyota will ABSOLUTELY have to fix the issue?
I don't think 2 rental cars being skullfucked on the 'ring is representative of all 86's. They were probably filling them with 87 or something. |
#19 | |
Drives: Scion FR-S/Toyota Yaris
They just have two back out the shop, read the post again. It was their whole fleet of twins and they are being gotten rid of due to this issue. I'm not saying the sky is falling just think people need to be aware of the issue, and Toyota needs to acknowledge it. Saying it only affects those who drive to redline and dismissing it is ridiculous.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#20 | |
Drives: FR-S 6MT
#21 | |
Drives: FR-S 6MT
How many had problems? I checked their website and the GT86 is still available for rent. You are taking hearsay from another post and quoting it as fact. Do you know for sure they are dropping these cars from the fleet based on one employees passed on say so? Maybe another employee is saying they just ordered 30 more.. you are spreading doom and gloom like a farmer spreads manure.. |
#22 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#23 |
Member of the year - 2016
Drives: Scion FRS
20K here and nothing so far.
A rental car having car problems? You guys new to the car world...?
#24 |
I have 10k on the clock 2k with supercharger. I mostly drive like a grandma. With a few wot here and there. Ill never track the car or do a 1-6 full throttle pull. If I pop my motor I will strip it to stock take it to dealer pray to have it fixed then trade the car in for a 370z or m3
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#25 | |||
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Race rental cars are very well maintained. You sign a liability form, of course, but no form will hold up to gross negligence. These cars get sold to the public after many miles and must pass TUV inspection with flying colors. To say these cars don't get maintained is like saying water isn't wet. Your ignorance let alone sheer lack of reading comprehension is awe inspiring, the fact that you two drive on public roads is more terrifying than the DI seal busting. (before either of you have a hernia - I KID I KID!)
#26 | ||
So you are accusing the OPer of hearsay, classy. How about utilizing the forums as a means to help correct the issue before it leaves a lot more dissatisfied customers instead of pointing fingers and hiding in denial? Something constructive maybe ?
#27 |
Thanks
If someone pays to do it I'll give my car to a dealer for the research, I have another car I can drive in the meantime.
Speculation is one thing but $ or silence is better. |
#28 |
Drives: 2013 Scion FR-S MT Ultra Marine
I am curious about the spark plug issue they are having. About a month ago I brought my car in for a check engine light. Under WOT Cylinder 4 was misfiring. The Toyota tech said that they switched the spark plug in cylinder 4 to cylinder 3 and that if the check engine light comes on for a misfire in cylinder 3 they will replace the spark plug. Since I have gotten the car back I haven't had any issues but I am still wondering if I am getting the full story.
Has anyone else had this issue?
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE |
| Tags |
| regalsurinalpost |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 11:25 AM |
| 86 rentals - 2013 era | bcj | AUSTRALIA | 11 | 04-23-2013 10:27 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 05:07 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
