Old 07-05-2013, 01:44 PM   #337
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by StormTrooper View Post
Maybe i'm reading something wrong but shouldn't we be in STS vice STX....or am i looking at an older rule set and they don't have sts anymore?
LSD... thats the difference.. not allowed in STS
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
whataboutbob (07-05-2013)
Old 07-05-2013, 06:08 PM   #338
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
hhhhmmm thought i saw something in sts about an LSD....
Also i keep reading about headers being STX legal. how is a header not legal if you can put the cat in the Downpipe and meet the rules??
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-05-2013, 06:32 PM   #339
StormTrooper
So i guess i don't understand:
K. Limited Slip Differentials
STC, STS, STF – No limited slip differentials are permitted except for
factory standard viscous coupler type units.
when did a torsen become better than a mechanical LSD??
GR86 MT premium
Old 07-05-2013, 06:32 PM   #340
StormTrooper
double post.....
GR86 MT premium
Old 07-05-2013, 07:05 PM   #341
Scooby South
Conedancer
Its not better.. and be be upgraded as per the rules.. to a Clutch type.. since it is a torsion, its better than the Viscous coupler type.. thats why its not allowed in STS/STC or STF.. I know of some members thats upgraded to the OSGiken...which is a full Clutchtype.. me personally am trying to finds the fundage for a Guard Transmission Diff which I think will be the ultimate.. @MattMonson
Old 07-06-2013, 09:47 AM   #342
StormTrooper
Some headers require fans or coolant reservoirs to be moved...looks like that puts you into SP which i think is pretty dumb on a modern car.
Yes I answered my own question.
GR86 MT premium
Old 07-07-2013, 12:01 AM   #343
dvsidboy
So the Packwood National tour is next week and I am planning on running. However, I have added a few things and I want to insure I am within the rules but they are at times hard for me to follow.
Would someone be so kind to let me know if I fall in the rules for STX
Mods I think I am within Rules on:
Perrin ECUTek Tune
Perrin CAI
Perrin Oil Cooler
Perrin 3" Cat Back Exhaust (w/hangers)
Perrin 2.5" Down Pipe / Mid Pipe
Perrin Front and Rear Sway
Perrin Front / Rear Endlinks
Perrin Streeting Rack Bushings
Perrin Motor Mounts (Not Solid)
H&R Sport Springs
Whiteline Strut Tower Bar
Whiteline Front Camber Bolts
Where I have questions:
Perrin Front Control Arm Brace (2 Points)
Whiteline Rear Sway Brace (2 Points)
HT Autos Front Lip (STI Rep) - Removable if needed to be on the safe side.
Thanks in advance!
dvsidboy is offline   Reply With Quote
Old 07-07-2013, 12:16 AM   #344
Scooby South
Conedancer
Perrin Oil Cooler... not legal..sorry...I assume you are running STX.. Everything else seems ok. I would have to see the motor mounts to ensure legality there... not familiar with Perrin's mounts. I am running Cusco ones in mine.
Any engine or transmission mount is allowed provided it attaches
only to the original mounting points, does not relocate the engine/
transmission (other than incidental to changes in compliance material),
and weighs no less than the OE mount. All components between
the engine/transmission and the mounting structure are considered
to be part of the mount assembly.
Old 07-07-2013, 01:22 AM   #345
whataboutbob
AutoX-10/10ths every run
Perrin ECUTek Tune
Perrin CAI
Perrin Oil Cooler
H&R Sport Springs
Thanks in advance!
Those Perrin front control arm braces and the Whiteline rear sway braces are not legal for STX.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
EN2_Squirrel (07-07-2013), Scooby South (07-07-2013)
Old 07-07-2013, 11:34 AM   #346
dvsidboy
Thanks for the help guys, so it's remove these items our go play in SM. Oh what fun.
Old 07-07-2013, 11:50 AM   #347
whataboutbob
Come to SM. We have candy.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 07-07-2013, 12:23 PM   #348
dvsidboy
LOL!
Now, can I find R-Comps in 7 days?!?!?! That is the next challenge.
Old 07-07-2013, 12:31 PM   #349
whataboutbob
LOL!
Yeah. Debating R-Comps @$1100 or another set of Z2s @$850...R-comps are supposed to last 40-70 runs, my Z2s have 170ish and aren't dead, yet.
Build thread:Here
Old 07-07-2013, 02:12 PM   #350
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
So here is a setup question:
Couple of bolt on's, stock suspension other than the Strano 22mm front bar, running on 225 ZII's on stock rims, in STX and am modding up slowly.
After installing the Strano bar I have loved it, really did a great job of combating the oversteer. I have found now that on some of the tighter courses I am running into too much understeer on the sweepers where I can carry some speed. I have played with tire pressures a bit, and still cant quite find something that I love, though something around 36 square has been good so far.
I thought about picking up the Perrin 16mm rear bar and running it on the softest setting (a 30% stiffness difference from stock) to try to dial back a bit of the understeer. What do you guys think? Good idea? Bad idea?
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
