Old 05-28-2013, 09:05 AM   #323
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Originally Posted by Scooby South View Post
It was nice to finally meet you Holly.. good fun.
Bill
<--- Dave. Not sure if Holly's on here. Either way, it was nice to meet you too!
trippinbillies40 is offline   Reply With Quote
Old 05-28-2013, 09:44 AM   #324
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by Kido1986 View Post
I know that's the case in reality but I didn't want to give the idea that rule bending will be okay on the bigger level. You can do it and likely get away with it but it's not the best method.
I was more focused on the fact that locally that no one will likely say anything. If someone gets beat by a newish person and blames a minor brace like that, I'd laugh til I pissed myself.
Good point.
I think it is very bad practice to get into the expectation that rule bending is OK at a higher level (and to some extent even at the locals) and expect that no one will protest you. Part of the reason this sport is fun is because to some extent people trust everyone else in their class is being honest and is following the rules. If the attitude drifts too far to this expectation that rule bending is fine as long as you aren't blowing people out of the water, we are setting ourselves up for extra scruteny and a lot of bad attitudes. I know noone wants to want to have to protest people, but the rules are there to provide as level a playing field as possible.
I had an interesting conversation with some very in-the-know folks at the last local about the legality of reversing your headrest... basically I was reversing mine, and they were not, as that is an illegal seat-modification. Thought that was interesting and I don't really have anywhere in the rulebook I could point to that would allow it.
There was a volvo running at yesterday' s local missing a headlight and had his air cleaner hanging out and definitely had a BOV and probably some other turbo-related modifications.. oh and he was running H-Stock
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 05-28-2013, 09:52 AM   #325
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
@Sccabrz192 I could have sworn there was a provision allowing a headrest to be reversed in the rulebook.
Edit: 2013 rulebook, stock rules, section 13.2J
Sent from my Nexus S using Tapatalk 2
The Following User Says Thank You to Ninjin For This Useful Post:
Sccabrz192 (05-28-2013)
Old 05-28-2013, 09:57 AM   #326
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
apparently I didnt look very closely...
Driver restraints as outlined in Section 3.3.1 are allowed. Seats may
not be cut to allow for the installation of alternate seat belts or harnesses.
Passive restraint systems may not be removed.
Removeable
seat headrests may be repositioned using the original mounting
hardware only if the OE components permit it with no modifications.
This includes removing a headrest and reinstalling it backwards.
you are correct. Thanks for making me go back and re-search for it!
Old 05-28-2013, 10:02 AM   #327
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
That would be one hell of an asinine rule if reversing the headrest was illegal. Not a single performance benefit. Infact, it's safer if it allows the driver to be in better control I'd think.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-28-2013, 11:37 AM   #328
rx3
Originally Posted by ABQautoxer
9" is a much better fit for a 245 than an 8" is all. Also fitting a 245 is going to be harder with a 8" and clearing the stock strut arrangement with any amount of negtiave camber and not poking. Been there, done that. I would get a 17x8 ET42 or so and run a 225/45/17 instead.
I went with 17x8 ET45 235/40/17 because of the stock strut clearing in the front. The stock class here (central Europe) allows any size of wheels but coil overs and aftermarket springs are not allowed.
I think one could also consider to go with 17x8 ET45 235/40/17 front and 17x9 ET45 245/40/17 rear. (With the stock set-up and camber bolts the car is prone to over-steer and a staggered set-up could possibly reduce this somewhat).
rx3 is offline   Reply With Quote
Old 05-28-2013, 01:06 PM   #329
Kido1986
Dodging cones
Kido1986's Avatar
Stagger will rarely end with correct handling on this car. Use alignment and tire pressure to change behavior IMO
The Following User Says Thank You to Kido1986 For This Useful Post:
BlaineWasHere (07-05-2013)
Old 05-28-2013, 01:39 PM   #330
rx3
The stock set-up doesn't really offer any alignment options apart from the camber bolts.
The S2000 or M3 or even the Smart come with a staggered set-up in the stock configuration. So why not? I don't want to hijack this thread but is there a technical explanation why a staggered set-up would not work with this car?
(I do run 3 psi less pressure in the rear and still primarily deal with over-steer).
Old 05-28-2013, 02:18 PM   #331
Kido1986
Dodging cones
Kido1986's Avatar
I used a front sway bar to help stop oversteer. You want as much front contact patch as possible.
Factory cars come with staggered to cause understeer as the general population shits themselves when rear ends slide.
In a race/autocross, the rear out is typically easier to drive around that the front.
Front sway bar + rear toe in help with oversteer while leaving huge front contact patches with 9" wheels
Old 05-28-2013, 03:23 PM   #332
rx3
Yes the front swaybar would probably help a lot, since it would put more burden on the outer front wheel (and less on the rear).
The non-stock class FR-cars are always on three wheels (monster swaybar in the front or something):
But unfortunately they don't allow them here in the stock class (which is also why I've been thinking about the staggered set-up. But then again in the last autox event it was wet and it that case it may even have been counterproductive).
It's a lot of fun to drive with all this over-steer, but I think it would be faster if it wouldn't.
Old 05-31-2013, 08:38 PM   #333
derek1ee
Drives: BRZ/FRS/STI/M3
Question re: master cylinder brace
If I install the brace, but back the bolt off during autox so the brace is not holding MC while breaking), will it be legal for STX? Or do I have to remove the entire thing completely?
Thanks,
Derek
derek1ee is offline   Reply With Quote
Old 05-31-2013, 09:17 PM   #334
xwd
Those cars which lift the front inside wheel on power out of a turn usually have a better weight distribution than we do. You see it a lot with BMWs in particular which are very close to 50:50. That Opel n the pic looks like it has no droop in the front suspension, that wheel is still sitting right on the fender. On our cars, and almost all Subarus, a stiffer rear will have you lifting the inside rear. It was worse on the older ones which had struts in the rear, they would do it stock with the distribution like 60:40.
Most of the weight reduction people are doing is off the rear of the car as well which shifts it even further forward.
S2000 in particular uses a staggered setup stock due to the short wheelbase and if it wasn't staggered people would probably be crashing them much more often. In stock autox class people run a square setup with a huge front swaybar. I know a national champ who tried a staggered setup on a CS frs and it didn't work well, he went back to a square setup.
Old 06-17-2013, 03:36 AM   #335
rx3
I have meanwhile driven this car at an unofficial Slalom event which resembled more an US Autocross and there I actually dealt with more understeer than oversteer. Especially in Sweepers and fast directional changes. At that event I actually wished it was more tailhappy. I will upload a video later in my other thread.
In those fast official Slaloms where one sometimes even needs to shift in 4th gear, it always felt loose and was never pushing. (Which is why I even ran in VSC Sport mode when it was raining, since those sometimes very sudden outbreaks of the rear made me feel uneasy given the fact that trees were often not too far away.)
I think these are the explanations for it:
1. So far it has always been cold on those fast courses and the rear tires may have never gotten up to temperature (they were definitely always colder than the front tires).
2. At fast 3rd gear turns the car probably gets some aerodynamic downforce on the front axle and the contrary on the rear axle.
3. On a fast course you are more likely to induce trail-braking.
In short: I have definitely given up on the staggered tire set-up idea.
But I think it would make sense to change the suspension set-up depending on what kind of course one is running at.
Also, I have noticed a substantial braking performance difference between braking in slight a turn and braking on a straight (also no trail-braking occured at that event). Can it be that the ABS is set too conservatively?
Old 07-05-2013, 01:00 PM   #336
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Maybe i'm reading something wrong but shouldn't we be in STS vice STX....or am i looking at an older rule set and they don't have sts anymore?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
