Old 07-02-2013, 04:34 PM   #1
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results.
2013 FR-S.
Full Blown Motorsports stage1 turbo kit.
4th gear pull.
Mustang dyno. AWD-150-SE (De-coupled in 2wd mode)
91 CAN pump gas.
7.8psi.
Infamous Performance is offline   Reply With Quote
Old 07-02-2013, 04:48 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I am assuming this is Gen's car. The numbers still seem off to me. Can we get a boost plot or some AFRs? I know that awesome AWD-150-SE has the capability to log both.
Old 07-02-2013, 04:55 PM   #3
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
mustang dyno, 91 octane and 8 psi, seems about right. Is it stock exhaust or no?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 07-02-2013, 08:07 PM   #4
Dont know who Gen is.
Stock exhaust.
We did not install the kit or tune the car. Customer complained of low out put numbers on the dyno that it was tuned on. It made 156whp the first pull on my dyno. Car came in with a major fueling issue and a huge exhaust leak. We fixed both and then re-ran it on the dyno.
AFR is 11-12.
Boost holds at 7-7.8psi.
Shop that tuned the car said they wanted a second shot at the tune (they think there is 10-15more whp to be had). So, customer is taking it back for a re-tune.
Old 07-02-2013, 08:14 PM   #5
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Stock exhaust.
AFR is 11-12.
That AFR seems a little low to me. Shouldn't it be closer to 14?
Trashed675 is offline   Reply With Quote
Old 07-02-2013, 08:31 PM   #6
sw20kosh
Drives: 2013 Black FR-S
No not under WOT and boost. 11-12 is right.
The Following User Says Thank You to sw20kosh For This Useful Post:
Trashed675 (07-02-2013)
Old 07-02-2013, 08:58 PM   #7
14.7 when not on boost. 10.7-11 is normal (depending on tune/tuner) for pump gas on boost.
Old 07-02-2013, 10:58 PM   #8
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Id be pissed at 157 on dyno after tune n turbo lol
sosick is offline   Reply With Quote
Old 07-03-2013, 07:46 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
175 wtq you mean?
Old 07-03-2013, 11:29 AM   #10
I think he was referring to the original pull, when we immediately realized there was a big problem. AFR's in the 17-18 range at WOT. We stopped it short, but the car was only making 156whp at that point. After correcting the fuel pump issue and the exhaust leak we were able to safely complete some pulls.
The Following User Says Thank You to Infamous Performance For This Useful Post:
Sportsguy83 (07-03-2013)
Old 07-03-2013, 08:52 PM   #11
sosick
fastest frs in sbg
sosick's Avatar
I think he was referring to the original pull, when we immediately realized their was a big problem. ARF's in the 17-18 range at WOT. We stopped it short, but the car was only making 156whp at that point. After correcting the fuel pump issue and the exhaust leak we were able to safely complete some pulls.
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience King Tut Forced Induction 196 09-04-2016 09:47 AM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 08:27 AM
Full Blown Motorsports Turbo Kit INSTALLATION at Real Auto Dynamics! Kevin@RAD Forced Induction 70 04-24-2013 08:47 PM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
