Old 06-01-2013, 11:04 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by charged86 View Post
So first time I filled tank with new fuel pump and I smell gas. Not happy boy.
Ohh ohhh.... Maybe broken black gasket?? Let the car running idle in your driveway for some minutes, check leaks on the floor below fuel tank. I have the part number for the gasket.
Old 06-01-2013, 11:06 PM   #16
charged86
charged86's Avatar
Dang. And ok. Grr
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-01-2013, 11:25 PM   #17
Sportsguy83
Drives: Limited BRZ
Dang. And ok. Grr
Gasket Part no.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
charged86 (06-02-2013)
Old 06-02-2013, 12:23 PM   #18
charged86
charged86's Avatar
Gasket Part no.
car is now leaking in driveway on a left banked driveway. moved it to point down hill still leaking. it did not leak level parked. I think this gasket needs to be replaced everytime pump is pulled out.
Old 06-02-2013, 12:29 PM   #19
Sportsguy83
Drives: Limited BRZ
Yes, its very easy to damage it trying to install. I agree.
Also, how tight did you put the outer Ring? Did you hit it couple of times with a hammer and screwdriver?
Old 06-02-2013, 03:12 PM   #20
charged86
charged86's Avatar
yeah and today I tried to retighten got the drip to slow down got greedy went for more tight and worsened issue. put it back where it was I will at least pull it out and inspect when the level goes down
Old 06-02-2013, 03:27 PM   #21
Sportsguy83
Drives: Limited BRZ
Yeah, if tightening it made it worse, get that gasket ASAP. I had the SAME issue which was the occasion I needed to replace the gasket.
Old 06-03-2013, 09:27 AM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I had the same issue the first time I installed the fuel pump where I leaked fuel once I filled up the car. The spot in my culdesac is still there where I parked it and it leaked a ton of fuel. There is definitely a sweet spot as far as how much to tighten the white lock ring. I was watching Xtreme 4x4 on the Powerblock this weekend and the guy actually had the tool designed to remove and install the white lock ring. It allowed him to torque it to spec as well. I might see about purchasing one.
kiichiro (04-19-2014)
Old 06-21-2013, 08:34 AM   #23
charged86
charged86's Avatar
Let us know if you find this tool
Old 07-02-2013, 11:36 PM   #24
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Also guys the pump lid must be oriented one way only so mark it when you remove! You have to be patient and work the two gaskets together as you push the lid down. You may have to pull the lid up a few times to work the lid gasket inside the tank gasket. If you do it right the lid will push down more easily.
Now the most important part to ensure you did it correctly and that is the arrow on the locking ring must line up with the small dots cast into the tank. If all done correctly the ring will screw on by hand about 75-80% of the way and then you'll have to tap the ring with a punch/large flat head screw driver and hammer.
If you can't get the arrow to line up take it back off and check the gasket and lid orientation.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
Sportsguy83 (07-03-2013)
Old 07-15-2013, 03:16 AM   #25
cf6mech
Drives: FRS Silver LS1 swapped.
I'm assuming the sending unit is in the canister,..if so the orientation of the arrow and dots makes sure your quantity reads correctly right?,...I have an issue with that.
cf6mech is offline   Reply With Quote
Old 08-15-2013, 12:39 AM   #26
1slowbrz
1slowbrz's Avatar
Drives: 2017 WRB BRZ PP
Accident post.
1slowbrz is offline   Reply With Quote
Old 08-29-2013, 05:46 PM   #27
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
anyone ID this tool?
448hpsti is offline   Reply With Quote
Old 08-29-2013, 06:25 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nope, but a quick google search later, and I think this one will work:
[ame="https://www.youtube.com/watch?v=71Hr3TuSJac"]63000 Fuel Tank Lock Ring Tool - Lisle Corporation - YouTube[/ame]
Sportsguy83 (09-01-2013)
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
